20th September 2011, 19:55 | #9821 | Link | |
Also, since you compared to DXVA, of course it'll use more CPU then before. The Splitter creates one thread for every stream (audio, video, subtitle), and the decoders usually just decode on that thread, causing the info you see. Its only because LAV Splitter created the thread that its being blamed for them, but the highest CPU thread is probably video, and the second the audio decoder.
20th September 2011, 20:14 | #9822 | Link | |
Forget about my old .3dlut stuff, just use mpv if you want accurate color management |
20th September 2011, 20:16 | #9823 | Link | ||
Anyway its not like I have a problem, I'm just curious. |
20th September 2011, 20:24 | #9824 | Link | |
properties: PC levels (0-255) 8 bit (or higher) calibration: disable calibration controls for this display display modes blank line & everything below unchecked. color & gamma everything disabled decoding everything disabled scaling: Softcubic 60, Spline 4, Spline 4. general settings: No - use managed upload textures (XP only) Yes - delay playback start until render queue is full Yes - enable automatic fullscreen exclusive mode No - disable desktop composition (Vista and newer) No - use a seperate device for presentation (Vista / Windows 7 only) exclusive mode settings: Yes - show seek bar Yes - delay switch to exclusive mode by 3 seconds No - present several frames in advance 8 - how many backbuffers shall be used flush flush & wait (sleep) don't flush don't flush trade quality for performance: everything disabled
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
20th September 2011, 20:30 | #9825 | Link |
^ that setting causes it to use the "old" exclusive mode 7% is high? From all i know, that could as well be the audio decoder decoding some complicated HD audio, putting the video at 4%. Without knowing anything about the system, judging how much 4 or 7% actually is, is really not possible either.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 20th September 2011 at 20:36. |
20th September 2011, 20:44 | #9826 | Link |
Well, I figured the 7% is what you'd get from software decoding. I get around 15% on average 1080p material (8-bit) but my system is quite dated.
20th September 2011, 21:23 | #9829 | Link | |
I would try to check out the differences between "old" and "new" since I don't know the difference. At first glance I see presentation glitches now and then, about one each five seconds or so.
21st September 2011, 06:09 | #9830 | Link | |
21st September 2011, 06:45 | #9831 | Link |
As a general rule of course, if windowed mode works fine for you, then don't worry, be happy.
Some users need exclusive mode for fluid playback without tearing, if you don't - great!
21st September 2011, 13:39 | #9832 | Link | |
I was doing some testing upscaling some 1080p content to 4K recently, and none of the available algorithms really did a very good job of it. For some reason, the scaling issues were far more obvious than with DVD. Perhaps because the source material (good Blu-ray encodes) is that much more detailed to begin with. Everything, even Lanczos 8 and SoftCubic 100 was very aliased. (but the aliasing had soft edges) It makes me wonder just how much better even DVDs can get compared to how they are now. (and how they are now, is the best I have ever seen) I would love to see more advanced multi-frame super-resolution processing eventually, but I suspect that's far beyond the scope of madVR. |
21st September 2011, 15:32 | #9833 | Link |
In a related note, how about an emulation mode for the old XP option for a “single display mode” which would treat a multi-monitor setup as one large display?
For example, some users use an IBM T221 screen to display movies, which has a resolution of 3840 × 2400 and is connected using four DVI ports - Windows sees these as four separate 1920x1200 monitors. In XP, you could set it to work as a single display so running a fullscreen program would fullscreen it over all four “displays”, while Windows 7 lacks this feature - so fullscreen applications will only appear in a single quadrant.
22nd September 2011, 12:33 | #9835 | Link | |
Can't say I notice much of a difference for 1080p24 playback though. |
22nd September 2011, 19:17 | #9836 | Link |
I'm upgrading my HTPC to include an nVidia card (GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16), but the motherboard I wish to use has only a PCIe 1.1 x16 slot.
Will this make any difference in madVR (or LAV CUVID)'s ability to fully utilize the new card? I'm guessing even 1.0 has enough bandwith to render the images fine, as I think the real work is done in the GPU. But, before I get it all built, I thought I'd ask, since it's easier to change the motherboard before I install it thanks. |
22nd September 2011, 19:42 | #9837 | Link |
The bandwidth should be sufficient.
I have no idea if it works at all, but i guess it does.
22nd September 2011, 20:35 | #9838 | Link | |
Thanks. from my reading...
It seems the cards/slots are backwards compatible between versions, so I'll hopefully get it built tonight or tomorrow and finally get full hardware de-interlacing |
23rd September 2011, 04:17 | #9839 | Link |
I have two PC's with nvidia GPU but I'm seeing radically diffrent Present Times:
- GTS450 (ddr5): Present time is usually between 0.1 to 0.2ms in both Exclusive and Windowed Mode - GTX550Ti (ddr5): Present time is usually between 0.1 to 0.2ms in Exclusive Mode but blows out to 10 - 30ms (eg 100 times slower) in Windowed Mode so it drops frames. I've tried updating Drivers, Bios etc on the GTX550Ti but I have No Idea why the very high Present Times in Windowed Mode on this unit - any hints? Thanks Nathan Edit: Even my Laptop with a 320M has OK present times..... Last edited by jmone; 23rd September 2011 at 05:30. |
23rd September 2011, 06:39 | #9840 | Link |
EDIT - Fixed the issue by reapplying the Std Windows 7 Aero Theme (Control Panel --> Personalization). Seems if you have a "Basic" theme then the presentation times go up by x100. With the Aero Theme applied all is fine (no idea how I had a non-aero theme in the first place).
