Old 21st November 2017, 09:54   #14501  |  Link
jpsdr
Do you intend by any chance to update some " old DLL" (ffmpeg, flac, ...) to newer versions ?
For exemple, dcadec is now implemented into ffmpeg, so all improvements of it are not anymore in the standalone version.
jpsdr is offline
Old 23rd November 2017, 23:55   #14502  |  Link
wiggaz
I still get a corrupt video (Passengers) with the latest version (3.34). Am I missing something?
Thanks in advance.
wiggaz is offline
Old 24th November 2017, 10:35   #14503  |  Link
madshi
Can you post a small video extract with which I could reproduce the problem? Thanks!
madshi is offline
Old 24th November 2017, 15:39   #14504  |  Link
tormento
Acid fr0g
tormento's Avatar
Invalid bitstream format on DTS
Sometimes I get Invalid bitstream format error with DTS to AC3 conversion and I have to use ffmpeg.
I want to supply you an example, so probably a fix will be out.
eac3to.exe eng.dts eng.ac3
DTS Master Audio, 5.1 channels, 24 bits, 48kHz
(core: DTS, 5.1 channels, 1509kbps, 48kHz)
Decoding with libDcaDec DTS Decoder...
Remapping channels...
Encoding AC3 <640kbps> with libAften...
Creating file "eng.ac3"...
libDcaDec reported the error "Invalid bitstream format".
Aborted at file position 372244480.
@turment on Telegram
tormento is offline
Old 24th November 2017, 17:34   #14505  |  Link
wiggaz
First of all, thanks for your answer.
Since I thought maybe it was the source corrupted, I tried muxing the m2ts directly and it was flawless, so it couldn't be the disc.
And that's why there are two sample: one muxing the .h265 extract with eac3to [corrupted], and the second muxing directly the m2ts (only the video of course) [flawless].
They are 120s each.
http://www.mediafire.com/file/ts3fsb...sample-001.mkv
http://www.mediafire.com/file/6x3tli...sample-001.mkv
eac3to is update to 3.34 with Useac3to at 1.28 and mkvtoolnix is update to 18.0.0.
Thanks in advance again.
wiggaz is offline
Old 24th November 2017, 18:12   #14506  |  Link
madshi
Thanks. But what I really need is to be able to reproduce the problem on my PC, so I can double check if the problem is really fixed. So I need an extract of the m2ts file.
madshi is offline
Old 24th November 2017, 19:01   #14507  |  Link
wiggaz
The second file is the m2ts file muxed into mkv, with all the tracks disabled except of the video.
Or should I give you the mux with all the tracks, divided into a small piece (120sec like the others) with mkvtoolnix?
wiggaz is offline
Old 24th November 2017, 19:26   #14508  |  Link
madshi
I don't need the mux, I need the original m2ts file (a small part of it)!
madshi is offline
Old 24th November 2017, 19:34   #14509  |  Link
sneaker_ger
@wiggaz
You can use DGSplit to cut e.g. 50 MB from the beginning of the m2ts.
sneaker_ger is offline
Old 24th November 2017, 20:10   #14510  |  Link
madshi
That should work, but only if the corruption is right at the start of the movie?
madshi is offline
Old 24th November 2017, 20:13   #14511  |  Link
wiggaz
Here's, splitted with DGSplit as suggested (thx sneaker_ger): http://www.mediafire.com/file/24om27...3/00001_0.m2ts
And this is an example:
wiggaz is offline
Old 24th November 2017, 20:38   #14512  |  Link
madshi
Thanks! And the problem also occurs with this small m2ts file, correct? (Don't have time to test right now.)
madshi is offline
Old 24th November 2017, 20:44   #14513  |  Link
sneaker_ger
@wiggaz
I can't reproduce the problem with the "00001_0.m2ts". Only with "eac3to_sample-001.mkv". Please check again that you really are on eac3to 3.34 and not 3.32.
Old 24th November 2017, 23:20   #14514  |  Link
wiggaz
allright. I'm a moron.
I had two eac3to folders. One updated, and another one from which I extracted the movie, who wasn't.
Now I have only one folder, updated, and with it I extract the movie flawlessly.
Sorry I have wasted your time.
At least everything is fine now. Thanks anyway
wiggaz is offline
Old 25th November 2017, 01:56   #14515  |  Link
tebasuna51
tebasuna51's Avatar
Your example seems corrupted.
Using Arcsoft show the same message:
The ArcSoft DTS Decoder reported an error while decoding. <ERROR>
Aborted at file position 372244480. <ERROR>
Using ffmpeg also show a error (but continue decoding):
[dca @ 000000000050fb40] Invalid bit allocation index
Error while decoding stream #0:0: Invalid data found when processing input
Don't exist a fix for that.
tebasuna51 is offline
Old 25th November 2017, 06:08   #14516  |  Link
pstn
Does anyone know if it is still necessary to do eac3to in.dtshd out.dtshd -21ms after converting PCM > DTS-HD with DTS Master Suite?
pstn is offline
Old 25th November 2017, 12:57   #14517  |  Link
tebasuna51
tebasuna51's Avatar
Like all encoders DTS Master Suite can add a initial delay to the encoded stream, but the output have a special global header than show some global info than include the delay used.
Whith my tool LeeAudBi4 can read that info, for instance:
File ........: D:\tmp\DTSENC.dtshd
Size ........:  3330600 bytes
---------------------------------------------- Header Info
ChunkID .....: DTSHDHDR (Length: 16)
SubchunkID ..: CORESSMD (Length: 12)
Core SampleR :  48000
Core Bitrate :  1509
Core ChMask  :  2059 (L,R,C,LFE,Lss,Rss)
Core FrameLen:  2012
SubchunkID ..: EXTSS_MD (Length: 8)
Ext. Avg. Bit:  388
SubchunkID ..: AUPR-HDR (Length: 24)
Samplerate...:  48000
Num. frames..:  1315
Samples frame:  512
Num samp. ori:  671919
Channel Mask.:  2123 (L,R,C,LFE,Lss,Rss,Lsr,Rsr)
Samples Delay:  1024                                 [1]
SubchunkID ..: STRMDATA (Length: 3324188)
Offset data .:  140 (Extrachunks at end of file: 6272 bytes)  [2]
------------------------------------------ End Header Info
Delay .......:  21.333 ms., (2 frames)               [1]
Duration ....:  14.027 sec., (0h. 0m. 14.027s.)
Avg. Bitrate :  1896 Kb/s.
------------------------------------------------- End Info
eac3to remove the global header DTSHDHDR and also the final Extrachunks [2], but don't apply the delay [1].
Then yes you can remove it with the parameter -21ms
Old 25th November 2017, 15:31   #14518  |  Link
pstn
That's great thanks,
I just tried it on a DTS HD file made with DTS Master Suite,
this is what I got :
File ........: C:\Users\pstn\Desktop\track2_eng.dts
Size ........: 691429400 bytes
----------------------------------------- First Frame Info
CRC present .................: 0 (Not)
Number of PCM Sample Blocks .: 15 ( 512 samples/frame)
Primary Frame Byte Size .....: 2011 ( 2012 bytes/frame)
Audio Channel Arrangement ...: 9 (5 C + L + R + SL + SR)
Core Audio Samp. Frequency ..: 13 (48 kHz)
Transmission Bit Rate .......: 24 (1536 Kb/s)
Embedded Down Mix Enabled ...: 0 (Not)
Embedded Dynamic Range Flag .: 0 (Not)
Embedded Time Stamp Flag ....: 0 (Not)
Auxiliary Data Flag .........: 0 (Not)
Mastered in HDCD format .....: 0 (Not)
Extension Audio Descr. Flag .: 0 (Channel Extension XCh)
Extended Coding Flag ........: 0 (Not)
Audio Sync Word Insert. Flag : 1 (Sub-sub-frame)
Low Frequency Effects Flag ..: 2 (Present, interpolation factor 64)
Predictor History Flag Switch: 1 (Yes)
Multirate Interpolator Switch: 0 (Non-perfect Reconstruction)
Encoder Software Revision ...: 7 (Current)
Copy History ................: 1 (Definition deliberately omitted)
Source PCM Resolution .......: 0 (16 bits)
Front Sum/Difference Flag ...: 0 (Not)
Surrounds Sum/Difference Flag: 0 (Not)
Dialog Normalization Param. .: - 0 dB
--------------------------------------------- Revised Info
Final bytes after core: 716
Total Frames ......: 236770
Duration ..........: 2525.547 seconds. ( 0 h. 42 m. 5.547 s.)
Master A. min./max.: 68 / 2620 (HD-MA subframe bytes)
For some reason it doesn't show me the delay, but it was made with DTS Master Suite, so it should have one I think right? I used "extended info" in your app.
pstn is offline
Old 25th November 2017, 17:58   #14519  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by pstn View Post
I just tried it on a DTS HD file made with DTS Master Suite:
You need use a .dtshd just encoded with DTS Master Suite, after mixed in a container the global header DTSHDHDR disapear.
EDIT:
MkvMerge and tsMuxer remove the global header (and end Extrachunks) of a .dtshd just created with DTS Master Suite, but don't apply the delay.
You can't know if you need apply the -21ms or not.
Old 25th November 2017, 19:23   #14520  |  Link
pstn
EDIT:
I see, thank you
pstn is offline
eac3to
