Old 18th June 2009, 21:29   #9001  |  Link
qyot27
qyot27's Avatar
What?
Don't exist difference between Dolby 5.1 and DTS 5.1 or any 5.1 config, is always 3 front channels, 2 surround channels and LFE.
The Surround channels must be at +-120º from Central channel (more or less)
With 7.1 config the order in wav files is: FL FR FC LF BL BR SL SR
and mean:
BL BR = Back Channels at 150º (more or less)
SL SR = Side Channels at 90º (more or less)
Like you can see don't exist (in wav specs) a exact correspondence with Surround channels in 5.1 (120º)
Before XP SP2 the FL FR FC LF BL BR maskchannels was used for 5.1, after the FL FR FC LF SL SR was recommended but the previous one is also accepted.
I figured that the difference between Back and Side channels were their angle compared to the Center, and that the difference does matter in 7.1 far more than it does in 5.1.
I took that Dolby/DTS snippet from one of Microsoft's pages detailing Channel Masks (albeit in the case of WMA 9 Pro):
"The 5.1 and 7.1 Dolby configurations make use of SL and SR speakers, while the 5.1 DTS system, the default used by Windows Media, places the side speakers in the back (BL and BR). The 7.1 SDDS configuration, which is the default used in Microsoft Windows® XP, makes use of five front speakers. Although this configuration is used commonly in large commercial theaters, it may not provide the best experience in a home system."
qyot27 is offline
Old 19th June 2009, 00:32   #9002  |  Link
tebasuna51
tebasuna51's Avatar
I never see this:
5.1 (DTS) FL, FR, C, LFE, BL, BR (63)
5.1 (Dolby) FL, FR, C, LFE, SL, SR (1551)
Of course is a big absurdity, the users don't need move the surround speakers to 90º whe listen AC3 and to 140º when listen DTS.
tebasuna51 is offline
Old 19th June 2009, 10:43   #9003  |  Link
Momber
Originally Posted by xkodi View Post
TMT 3 has version 1.1.0.1 of "dtsdecoderdll.dll"
TMT 3.5 has version 1.1.0.10 of "dtsdecoderdll.dll"
have you tried this new versions?
the latest 1.1.0.10 doesn't work with eac3to though. anyway, it's interesting if they fixed the problem with DTS-HD MA tracks reported by eac3to as "7.1 (strange setup)". as you know such tracks are not bit-perfect decoded by old 1.1.0.0 versions of "dtsdecoderdll.dll"
Ugh! So what is the version of choice we should all use?
I just confirmed I'm still on 1.1.0.0 - will I need to update? Can I replace just this dll (I don't really want to update the whole TMT software suite, because they keep on getting worse as the build numbers progress).
Momber is offline
Old 20th June 2009, 14:04   #9004  |  Link
Chumbo
Chumbo's Avatar
@madshi,
When you have time and get back to eac3to, would you be kind enough to add a switch to be able to turn off the audio alerts please? I was watching one of my shows with eac3to running some operations in the background and it was really annoying to hear the alerts over the program. Thank you.
Chumbo
Chumbo is offline
Old 20th June 2009, 14:13   #9005  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
remove all .wavs
Atak_Snajpera is offline
Old 20th June 2009, 14:13   #9006  |  Link
TinTime
If you delete the success and error wavs then this will silence eac3to.
EDIT - Atak_Snajpera beat me to it!
TinTime is offline
Old 20th June 2009, 20:27   #9007  |  Link
hubblec4
Matroska find' ich toll
Originally Posted by Chumbo View Post
@madshi,
delete the success.wav and the error.wav
hubblec4 is offline
Old 21st June 2009, 05:59   #9008  |  Link
hoju3508
Nick and Norah's Infinite Playlist chapters
eac3to is reporting 189 chapters when there's only 16 reported by BdInfo.
What kind of information should I send to madshi?
eac3to v3.16
command line: "C:\RipBot264v1.14.2\Tools\eac3to\eac3to.exe" "D:\" 1)
M2TS, 1 video track, 6 audio tracks, 17 subtitle tracks, 1:29:33, 24p /1.001
1: Chapters, 189 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB
(embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB)
4: TrueHD/AC3, French, 5.1 channels, 48khz, dialnorm: -26dB
(embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -26dB)
5: AC3, Spanish, 5.1 channels, 640kbps, 48khz, dialnorm: -26dB
6: TrueHD/AC3, Portuguese, 5.1 channels, 48khz, dialnorm: -26dB
7: AC3 Surround, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
8: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
9: Subtitle (PGS), English
10: Subtitle (PGS), English
11: Subtitle (PGS), English
12: Subtitle (PGS), French
13: Subtitle (PGS), Spanish
14: Subtitle (PGS), Portuguese
15: Subtitle (PGS), Arabic
16: Subtitle (PGS), Dutch
17: Subtitle (PGS), French
18: Subtitle (PGS), Spanish
19: Subtitle (PGS), Portuguese
20: Subtitle (PGS), Dutch
21: Subtitle (PGS), English
22: Subtitle (PGS), French
23: Subtitle (PGS), Spanish
24: Subtitle (PGS), Portuguese
25: Subtitle (PGS), Dutch
hoju3508 is offline
Old 21st June 2009, 19:21   #9009  |  Link
setarip_old
setarip_old's Avatar
Can "eac3to" be used to "timestretch" (or shorten) an .AC3 audiostream of a BluRay?
If so, how?
setarip_old is offline
Old 21st June 2009, 19:40   #9010  |  Link
buzzqw
HDConvertToX author
-slowdown or speeup
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 21st June 2009, 19:59   #9011  |  Link
setarip_old
@buzzqw
Hi!
Thanks for the suggestion(s), but based on their definitions ("-slowdown convert 25.000 and 24.000 content to 23.976 fps"
"-speedup convert 23.976 and 24.000 content to 25.000 fps") they appear to be specifically for NTSC to PAL and PAL to NTSC conversion. (If my interpretation is incorrect, please advise)
What I'm seeking at the moment is to evenly, over the duration of the audiostream, shorten the audiostream by 700ms...
Old 21st June 2009, 21:44   #9012  |  Link
rapscallion
NY Frame of Mind
rapscallion's Avatar
See the 2nd link, in the quote, below. If your's is dated 4/25/08 vs 4/21/08, then you're OK. If not, then you should update to the dll ver 1.1.0.1
You need use ArcSoft decoder.
This:
"Using eac3to with ArcSoft decoder there are a problem, the Side and Back channels are interchanged"
Was solved with a more recent version of dtsdecoderdll.dll <-----
rapscallion is offline
Old 21st June 2009, 22:17   #9013  |  Link
rapscallion
NY Frame of Mind
Hey guys, I'm looking for a simple program that will display volume levels of an audio track (DTS, AC-3) graphically, I suppose.
There's a VU meter built into either VLC or MPC, but it's indicators hardly move so there's no easy way to compare tracks. I've done a search and can't find anything. Thanks
Old 22nd June 2009, 04:15   #9014  |  Link
Chumbo
Chumbo's Avatar
remove all .wavs
Thank you all. Believe it or not, I actually thought of that after I posted the message. It would still be a useful switch though. I find the audiible warnings useful except under certain circumstances. It would be easier to not have to delete or rename them just for those cases.
Chumbo
Chumbo is offline
Old 22nd June 2009, 06:20   #9015  |  Link
Midzuki
Unavailable
Midzuki's Avatar
AC3Filter and/or MatrixMixer should be able to do the trick.
But if you prefer the stupid nerdish methods ,
you could as well "AudioDub" a BlankClip and apply
Histogram("AudioLevels") onto it.
{ http://avisynth.org.ru/docs/english/.../histogram.htm }
Midzuki is offline
Old 22nd June 2009, 14:29   #9016  |  Link
rapscallion
NY Frame of Mind
Thanks ! MatrixMixer works great.
"Talk to me Goose"
Old 22nd June 2009, 17:14   #9017  |  Link
htpc@rischer.at
Originally Posted by htpc@rischer.at
1.0 Channels 64 kpbs
Hi!
I want to demux the german audio E-AC3 1.0 64 kbps.
I tried to convert to .wav and to .ac3. Everytime ffmeg allerts that it cannot do it.
Have anyone an idea?
command line: eac3to h: bruce.log
EVO, 1 video track, 6 audio tracks, 12 subtitle tracks, 1:42:33
"Feature Presentation"
1: Joined EVO file
2: Chapters, 29 chapters with names
3: VC-1, 1080p24 /1.001 (16:9) with pulldown flags
4: E-AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
5: E-AC3, French, 1.0 channels, 64kbps, 48khz, dialnorm: -27dB
6: E-AC3, German, 1.0 channels, 64kbps, 48khz, dialnorm: -27dB
7: E-AC3, Italian, 1.0 channels, 64kbps, 48khz, dialnorm: -27dB
"Italian"
8: E-AC3, Spanish, 1.0 channels, 64kbps, 48khz, dialnorm: -27dB
"Cast"
9: E-AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
"Producer Commentary"
Originally Posted by jruggle View Post
This now decodes properly with libavcodec from FFmpeg's current SVN.
Thanks madshi for contacting me directly about this file. It does use spectral extension. I had implemented the feature in the "sandbox" repository from the original Google Summer of Code project, but had not merged to FFmpeg SVN because I only had 1 sample file to test... until now!! With this sample and another (also provided by madshi) working properly, I decided to merge the changes to FFmpeg SVN.
@jruggle:
Do you remember my problem?
Do you have some informations how do convert the file into another format like .wav?
I tried it with ffmpeg 0.5, but i failed.
thank you very much...
htpc@rischer.at is offline
Old 23rd June 2009, 23:55   #9018  |  Link
Thunderbolt8
how can I transform a .thd track to .dts again? when I enter it that way 'eac3to source.thd dest.dts' then I get 6 wav files first, but which are apparently not accepted by the surcode dts encoder and the process is cancelled.
Thunderbolt8 is offline
Old 24th June 2009, 07:45   #9019  |  Link
AnryV
How can I disable "Patching bitdepth to 24 bits..." during extracting Core from DTS-HD?
AnryV is offline
Old 24th June 2009, 09:20   #9020  |  Link
christinedawson
Thanks for the tool.
It's good to know that it's finally possible to convert TrueHD.
As I've been playing around with Nero these past days, could you tell what sort of working graph permit the decoding of TrueHD ?
Is it Nero Splitter -> Nero Audio Decoder 2 ?
Do you need to specify anything in the Nero Audio Decoder 2 options ?
Christine Dawson,
-- Spam-Links removed by Koepi --
christinedawson is offline
eac3to
