30th June 2010, 23:43 | #1841 | Link | |
The problem is that VideoRedo is sending recovery point SEIs before the PPSs. It's legal but very unusual, and it confuses my current code. I will make a fix for it and release it in the next build. Usual is: SPS PPS RPS I but your stream has: SPS RPS PPS I It's just something I did not anticipate and never occurred in the wild until now. Last edited by Guest; 1st July 2010 at 00:26. |
1st July 2010, 01:28 | #1844 | Link |
Yes, that means support. Instead of reading 100+ posts to see if something has been posted, you ask in the support thread. And the author or someone here can answer in a polite manner. If some of you spend their entire day hunting posts on forums, that's your business. I'm a busy man, I come home late and tired, I can't stay all night fishing for posts. I think I was very polite when I asked and I haven't broken any posting rules. So, please, show me the same respect. neuron2 was kind enough to answer me, so your intervention was not appropriate.
1st July 2010, 01:34 | #1845 | Link |
Let's stay on topic please guys. GearX, I appreciate your comment but I can look after my own affairs. crl2007, see it from my side and ask whether I should have to repeat the same thing for every user who won't read available instructions.
When I attain perfection, then I will (perhaps) be justified in asking it of others. I haven't attained it yet. So I try my hardest not to get upset at people who honestly have no bad intentions, as crl2007 clearly doesn't. Anyway, he used a smilie, which is a get out of jail free card. I now pause 30 seconds before hitting submit, and almost always delete some silly, snarky comment. It's just nonproductive; it's that simple. You may speculate what I almost wrote to crl2007. Last edited by Guest; 1st July 2010 at 01:40. |
1st July 2010, 01:39 | #1846 | Link |
Acid fr0g
258.69 drivers crashes video too.
Don't know why after 257.12, using DGMultiSource_x64 AND any DXVA, CUDA or anything similar crashes video. Just try to encode a video and play one in Media Player Classic HC. Neuron: do you thing is a nvidia or your issue?
@turment on Telegram |
1st July 2010, 06:43 | #1850 | Link |
Acid fr0g
Neuron, a little question. There are avisynth filters that are currently not well "multithreadable". I am going to bypass the problem splitting the job in multiple ones with different parts of the video. Is there a simple way to tell DGIndex to create 3/4 DGI with frame accurate splitting in the lateral points? Using the graphic interface seems error prone to me.
1st July 2010, 08:36 | #1853 | Link | |
1st July 2010, 09:26 | #1855 | Link |
HM ... DGIndexNV V2017 gives me errors now. "GPU Decoder: Failed to create Video Decoder (1)".
I changed nothing on my System.. only updated from 2013 to 2017.... Chris Edit: Oh i see.. u changed it again... Regenerating License.... |
1st July 2010, 10:42 | #1856 | Link |
I don't think this is actually a problem ... 'cause the first frame included in the trimmed part will be decoded correctly no matter what kind of frame it is in the source video stream. Anyway, if you select the first frame of a new scene by direct-inspecting of the stream (e.g. via AvsP / AvsPmod), it will (almost surely) be a reference frame.
1st July 2010, 11:53 | #1858 | Link | ||
1st July 2010, 13:47 | #1859 | Link |
Build 2018
Keeping those crackers on their toes!
* Fixed case of recovery point SEI appearing before the PPS. This fixes AVC streams cut with VideoRedo. http://neuron2.net/dgdecnv/dgdecnv.html |
