9th January 2013, 09:27 | #2803 | Link |
I just upgraded a PC from Windows XP SP3 (32 bit) to Windows 7 SP1 (64 bit). Started DGIndexNV.exe (rev. 2044, 32 bit), opened a *.264 file ... "Invalid license". The same license which used to work already. Generated in Sept. 2010 (the licensing upgrade was in June 2010). Same result for the "x64 Binaries" when I copy my license.txt file there.
I'll try to check my licenses when I am able to find my User ID again... either Donald can resend it to me, or I will have to wait for the weekend when I get back home. But we have another user in the german doom9/Gleitz forum who just recently registered, received his license, and it was reported to fail. So I will try to check if he made a mistake creating the license file. Users today may expect a little support from applications by accepting serials via own dialogs. Creating a simple text file with correct content and location appears to be harder than most developers would expect... |
9th January 2013, 15:12 | #2807 | Link |
Unfortunately, due to the unreliable Copy function in Windows (I bet there are more people who remember occasions when they hit Ctrl+C, but the marked area was not copied, the Clipboard persisted to contain a previous content), I checked an older machine code again; so I have now the same machine code registered twice. Your generator obviously does not care about duplicates. So I'll have to be careful in the future... |
9th January 2013, 15:43 | #2810 | Link |
My boss just confirmed that he knows this issue too... well, I could make a poll about it in our german board. But not in this thread, fearing the wrath of Donald...
BTW, a similar issue happens when I paste an URL and immediately want to close a BBtag with ] (AltGr+9 on a german keyboard); the keyboard driver seems to need a safe pause between releasing Ctrl and pressing AltGr to separate them reliably... Last edited by LigH; 9th January 2013 at 15:57. |
9th January 2013, 16:12 | #2812 | Link |
No need to fear me guys!
In every instance I know of where a cut and paste into the boxes of the license generator fails, it is because the copy actually included an extra space at the end. I include a warning about that in the instructions, but I should try to find time to make my perl script automatically delete extra spaces. |
9th January 2013, 16:33 | #2813 | Link |
Got a few questions:
1.a: "Activation of a screensaver or standby mode may interfere with proper operation of the DGNV tools. They should be disabled during use of the DGNV tools." 2. : "The DGSource() source filter supports multiple instantiation, however, the number of instantiations is limited by available memory on the nVidia video card. As always, more is better!" -> how much memory is normally needed to decode 1080i material? 3. : "Use with Windows Remote Desktop is not supported." -> What about VNC? would be nice if someone could help in answering the other questions. Cu Selur Last edited by Selur; 9th January 2013 at 18:01. |
9th January 2013, 18:35 | #2815 | Link | ||
Thanks Groucho2004.
9th January 2013, 19:02 | #2816 | Link |
2. Yes, it's OK, subject to memory constraints.
3. Should be OK. Please report your results. 4. TightVNC or any other one that doesn't deinstantiate the video driver will be OK. 5. You can put the licenses corresponding to each configuration all in the one license.txt file. The right one will be found and used. 7. No, but DGAVCDecDI is software based. |
10th January 2013, 13:30 | #2817 | Link | |
DGIndexNV -i "H:\Input\VTS_01~1.MP4" -o "H:\Temp\23913844mp4_deb1536f480475f7d593219aa1afd74c_41.dgi" -h -e |
10th January 2013, 15:36 | #2819 | Link |
No file also crashes DGDecNV if I use the GUI mode, here you go: http://goo.gl/pD6yj
Did nothing special aside from using a newer mp4box version to multiplex the file,... (used GPAC version 0.5.1-DEV-rev4273, will try other mp4box version to check if this is the problem) Last edited by Selur; 10th January 2013 at 15:40. |
