Old 14th March 2009, 03:09   #1141  |  Link
That doesn't look like the latest driver. Point me to the URL that you are using.
This looks like the latest to me:
http://www.nvidia.com/object/winxp_182.08_whql.html
Guest is offline
Old 14th March 2009, 03:33   #1142  |  Link
squid_80
Originally Posted by harissa View Post
driver vr 6.14.11.8208
That is the latest driver.
squid_80 is offline
Old 14th March 2009, 03:40   #1143  |  Link
@harissa
Do you have MY nvcuvid.dll in the same directory as DGAVCIndexNV.exe *AND* CUVIDServer.exe?
Guest is offline
Old 14th March 2009, 06:09   #1144  |  Link
harissa
yes the dll is in the same dir
i just wanna know if there s something that might cauz this , so i can avoid havin this crash
harissa is offline
Old 14th March 2009, 15:22   #1145  |  Link
deets
would using a faster card make any difference to encoding speed if using the card to do the deinterlacing? im thinking difference between 8800gt and 216
deets is offline
Old 14th March 2009, 15:49   #1146  |  Link
@harissa
You did not answer my question.
Anyway, assuming you do have MY DLL in both the directories, then I cannot think of any cause and suggest that you contact Nvidia for support.
@deets
I don't know. You'd have to ask Nvidia or do some experiments.
Guest is offline
Old 14th March 2009, 19:17   #1147  |  Link
Sagekilla
x264aholic
@neuron2: Do you use the VP2 engine on the cards for hardware acceleration + deinterlacing? If you do, then it's fixed performance across all the various cards I believe.
Sagekilla is offline
Old 14th March 2009, 19:45   #1148  |  Link
The VP2 is used for decoding. I don't know what does the deinterlacing.
Guest is offline
Old 15th March 2009, 03:23   #1149  |  Link
meatwad
meatwad's Avatar
@Sagekilla,
I read a rumor that you were possibly taking over the StaxRip project. If this is true, can you make it easier to incorporate neuron2's tools into the gui. Stax was kind enough to have added avs script importing into the last beta, but I still have .net crashes when I use DGMPGIndexNV if I run back to back encodings. I don't have an issue with DGAVCIndexNV because I was able to add it to the GUI and not use the avs importer. Anyway, it would be a nice addition and I hope the rumors are true.
meatwad is offline
Old 15th March 2009, 03:35   #1150  |  Link
Sagekilla
x264aholic
I'd like to take up the project, yes. I need to get it to import properly into VS 2008 properly. If I can get that going, I'd like to update a few things and I would like to see good support of the DG*NV tools.
Don't mean to hijack this at all, so I'll just say further questions should be directed towards the StaxRip dev thread.
Old 18th March 2009, 09:04   #1151  |  Link
lucassp
If somebody is still searching for an alternative to MS Remote Desktop that works with DG NV Tools, I can tell you that Team Viewer works fine.
[Intel] Core i5 8500|[ASUS] ROG STRIX Z390-I GAMING|[Noctua] NH-U12S|[GSkill] DDR4 2400 2x16GB|[MSI] RTX2060 Super Gaming X|[Samsung] 970 Pro 512Gb|[Seasonic] Focus SGX 650|[NZXT] H400|[LG] 27GL850
lucassp is offline
Old 18th March 2009, 13:46   #1152  |  Link
I seem to recall that TightVNC works too.
Guest is offline
Old 28th March 2009, 08:08   #1153  |  Link
xopowo
A little Update
I reported earlier that I was BSOD'ing while using the program.
It turns out that my video card was dying. I have a new one now and it's working fine.
However, I am wondering if anyone else is having an issue with GPU use and possibly killing video cards? This is the third card I've had now! I encode a lot and I always use purevideo for my deinterlacing. Does this put a lot of stress on the vid card? Excessive is more of the word that I want to use, but I'm curious if anyone else is killing cards?
xopowo is offline
Old 28th March 2009, 11:21   #1154  |  Link
nm
Yes, advanced deinterlacing with PureVideo is a relatively heavy task, although the more powerful cards handle it easily. If temperatures get too high, you risk damaging the GPU. You need to make sure that the card is cooled properly and that there is good airflow within the case. Check the GPU temperature while encoding.
nm is offline
Old 31st March 2009, 13:26   #1155  |  Link
pelle412
Pinhead
pelle412's Avatar
I believe I'm experiencing the same problem as Harissa. I have an 8600 GT card with 512MB, driver 182.08, using either DGAVCDecNV v1.0.13 or DGVC1DecNV v1.0.6. After reading through all the threads here, I believe it's an infrequent problem that occurs with some video cards. After seemingly a random number of frames into the encoding process, or it sometimes doesn't happen at all, the process stops with a cuvidMapVideoFrameError.
Since I can never reproduce the problem with a particular video segment, I'm guessing it's the video card. It's not overclocked, nor is my CPU.
Perhaps I'll get another card someday, or a new NVIDIA driver will somehow correct the problem. If the problem occurs, I usually revert back to DirectShowSource (corecodec) or the non-NV version of DGAVCDec.
pelle412 is offline
Old 3rd April 2009, 07:29   #1156  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
FR : able to open/close the CUVIDServer via command line...
Kurtnoise is offline
Old 3rd April 2009, 14:22   #1157  |  Link
You can open it already:
c:\cuvidserver
Guest is offline
Old 3rd April 2009, 14:59   #1158  |  Link
Kurtnoise
Kurtnoise's Avatar
I don't get your point...my cuvidserver.exe is not in c:\
I meant open it & close it in the dgavcindexnv command line...something like that:
DGAVCIndexNV -i d:\files\movie.avc -o d:\MyProject.dga -f 2 -e -s e:\path\cuvidserver.exe
where -s is able to open & close exec after file creation...
Old 3rd April 2009, 18:28   #1159  |  Link
Esurnir
You need cuvidserver during indexing O_o;?
I thing something is wrong there....
Esurnir is offline
Old 3rd April 2009, 20:44   #1160  |  Link
rack04
No you don't but I think MeGUI automatically opens the script after indexing. Maybe that's what he going for.
rack04 is offline
