Old 10th March 2019, 01:53   #6721  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by taz742 View Post
So the question is since which version the bug appear to know which old driver version is it safe to use ?
I don't know. I always see in DGDecodeNVManual the recomendation of use crops and resizes in mod-4.
BTW I can't recommend use a old driver only to crop in mod-2.
The standard AviSynth Crop can do the job.
Old 12th March 2019, 23:11   #6722  |  Link
Zetti
MKVToolNix v32.0.0 is released.
Zetti is offline   Reply With Quote
Old 13th March 2019, 12:40   #6723  |  Link
Zetti
x264 r2969 is released.
Old 15th March 2019, 12:09   #6724  |  Link
Zathor
Thanks, both have been updated
Zathor is offline   Reply With Quote
Old 12th April 2019, 22:30   #6725  |  Link
Zetti
MKVToolNix v33.0.0 is released.
Old 13th April 2019, 10:59   #6726  |  Link
imsrk48
imsrk48's Avatar
Please add a feature for add Logo using MeGUI
imsrk48 is offline   Reply With Quote
Old 15th April 2019, 10:41   #6727  |  Link
Zetti
MKVToolNix v33.1.0 is released.
Old 24th April 2019, 12:07   #6728  |  Link
Zetti
MediaInfo v19.04 is released.
Old 24th April 2019, 13:40   #6729  |  Link
imsrk48
imsrk48's Avatar
I'm facing problem with Encoding x265 to x264
https://mega.nz/#!EqpUAQAA!JOIFRxZzX...HY96eQewAkJGNE
Please Give Fix AOSP
Old 24th April 2019, 20:53   #6730  |  Link
sneaker_ger
For some reason the source is opened as RGB32 while an Y4M pipe (from AviSynth via ffmpeg to x264) can not handle RGB. The MediaInfo doesn't show if the source is RGB to begin with or you have your DirectShow decoder set up to decode to RGB32.
Try:
Open source via ffms2/ffvideosource() instead of DirectShowSource()
If that does not work add as last line:
ConvertToYV12()
Old 25th April 2019, 04:34   #6731  |  Link
imsrk48
imsrk48's Avatar
Try:
ConvertToYV12()
Already Tried ConvertToYV12()
After this MeGUI Says what is ConvertToYV12 () I can't understand something.
Old 25th April 2019, 04:36   #6732  |  Link
imsrk48
imsrk48's Avatar
Try:
ConvertToYV12()
How can i use your first method please explain Sir.
I really need to fix this. My Work Stopped because of this Issue.
Old 25th April 2019, 04:56   #6733  |  Link
imsrk48
imsrk48's Avatar
@Zathor Sir Please
Add FFmpegSource Selection Option in MeGUI In-built.
Add Option For Auto Download Required Avisynth Plugins that Needed in Scripts.
Old 25th April 2019, 05:55   #6734  |  Link
imsrk48
imsrk48's Avatar
Try:
ConvertToYV12()
I'm re-seted megui & Tried ConvertToYV12()
Now Video Encoding but Encoding Speed Is Very Slow.
Old 26th April 2019, 22:19   #6735  |  Link
Zetti
FFmpeg v4.1.3 is released.
Old 29th April 2019, 04:12   #6736  |  Link
bowlingbeeg
Strange FPS values in DVD rips
I've noticed that ever since the VFR support was added last year that when I encode North American DVDs to mkv and play them back on Plex or Kodi the refresh rate of my projector switches from 24p to 60p. It appears that the FrameRateMode is set to Variable in MediaInfo for North American DVDs and that causes the new support to create the timestamp file which ffmpeg uses. Now I'm not exactly sure where things go wrong from there but the result is that the Kodi and Plex seem to think they should be switching to 60p whereas older DVD rips will stay at 24p. Looking at Plex, it seems to think the actual file is 20FPS and when I look at the track info in MKVToolNix I do see a "default duration" of 20FPS. MediaInfo does say the framerate is 23.976 but that the frame rate mode is variable instead of constant like I see on older rips. I'm not entirely sure if this is a bug or not but it's certainly different behavior than what it used to do.
My work flow is that I use makeMKV to rip to a mkv with the MPEG2 video track. Then I use OneClick in MeGUI(2896) to select that mkv file. That encodes it to an h264 and re-muxes it back into an mkv with the original audio.
I've attached the log file if that's needed.
bowlingbeeg is offline   Reply With Quote
Old 29th April 2019, 07:20   #6737  |  Link
LigH
LigH's Avatar
It often takes a while to get attachments approved here. Can you upload the log to a pastebin as well?
New German Gleitz board
Old 29th April 2019, 11:09   #6738  |  Link
bowlingbeeg
@LigH - Here you go
https://pastebin.com/3eeMh3td
Old 29th April 2019, 11:34   #6739  |  Link
tebasuna51
tebasuna51's Avatar
The attached file is already approved.
The video input (from makemkv) and the video output (from MeGUI) have the same parameters:
FrameCount: 130288
FrameRate: 23.976
FrameRateMode: VFR
Duration: 01:30:34.095
Correct duration for 130288 frames at a CFR of 23.976
The audio extracted and merged have a coherent duration of 01:30:34.080
We need the timestamps file:
"G:\MainMovie\HOLMES_AND_WATSON\h2fkrskg.e0p\HOLMES_AND_WATSON_t00.mkv.timestamps.txt"
to see if there are some strange info to force a FPS of 20.
The MKVToolNix Header editor "default duration" show the "number of nanoseconds per frame"
For a 24000/1001 must show 41708333
For a 20 FPS must show 50000000 ns, is that correct?
Old 29th April 2019, 12:12   #6740  |  Link
bowlingbeeg
Here is the info from the MKVToolNix info:
| + Track size 126 data size 124
| + Track number: 1 (track ID for mkvmerge & mkvextract: 0) size 3 data size 1
| + Track UID: 1557705884751226684 size 11 data size 8
| + Track type: video size 3 data size 1
| + Lacing flag: 0 size 3 data size 1
| + Codec ID: V_MPEG4/ISO/AVC size 17 data size 15
| + Default duration: 00:00:00.050000000 (20.000 frames/fields per second for a video track) size 8 data size 4
| + Language: und size 7 data size 3
| + Video track size 24 data size 22
| + Pixel width: 720 size 4 data size 2
| + Pixel height: 360 size 4 data size 2
| + Display width: 875 size 7 data size 4
| + Display height: 360 size 7 data size 4
| + Codec's private data: size 45 (h.264 profile: High @L3.0) size 48 data size 45
I attached the timestamp file
