Old 7th September 2008, 12:21   #6101  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by asarian View Post
+ DTS-Core
- DTS-ES +
- channelNo 6
- lfe 1
- channelDescr 6.1
@madshi
Standards DTS-ES (encoded with DTS PRO SERIES SURROUND ENCODER) are decoded by libav and Arcsoft like 5.1 (with Cs mixed in Ls-Rs). Maybe if you expect by 6.1 and only have a 5.1 ...
Old 7th September 2008, 12:26   #6102  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by nautilus7 View Post
I tested tebasuna51's samples with Sonic. The updated list is below:
Thanks Nautilus7. I don't like install Sonic again.
btw, tebasuna51, is that you on the samples?
Yep, I make myself the samples.
Old 7th September 2008, 12:39   #6103  |  Link
rica
@madshi
Do you mean Libav decodes DTS-HD(HR or MA) as well and both Arcsoft and Libav creates just 5.1? (even the source 6.1 or 7.1)
rica is offline   Reply With Quote
Old 7th September 2008, 13:58   #6104  |  Link
odin24
odin24's Avatar
Location: The Great North (the better half of North America)
Using the command eac3to input.thd output.thd+ac3 make a BD compatible TrueHD stream, would a similar command work for a E-AC3 stream?
eac3to input.eac3 output eac3+ac3?
Thanks, O
odin24 is offline   Reply With Quote
Old 7th September 2008, 15:43   #6105  |  Link
nautilus7
nautilus7's Avatar
No, it won't.
To use E-AC3 on BD you must have a 7.1 stream. And to make it BD compatible, you need an E-AC3 encoder. It 's not like TrueHD + AC3 (individual tracks), but 5.1 AC3 core with E-AC3 extensions for the additional channels. 5.1 E-AC3 tracks in HD DVD are replaced by 5.1 AC3 in BD.
nautilus7 is offline   Reply With Quote
Old 7th September 2008, 17:29   #6106  |  Link
tebasuna51
tebasuna51's Avatar
I say DTS-ES, not HD (HR or MA), 6 physical channels (5.1) but 7 logical channels (6.1) with Cs mixed in Ls-Rs
Old 7th September 2008, 17:32   #6107  |  Link
madshi
Originally Posted by rebkell View Post
I asked earlier, but it probably got forgotten in all the posts
You got a reply to your question *directly* under your question. Put your glasses back on!
Originally Posted by xkodi View Post
i know for only two problematic samples:
- Edward Scissorhands Blu-ray DTS-HD MA 3/1 track
- Q-tec Hi-Definition Reference Demo Disc DTS-HD MA track
Edward will work with the next eac3to version and all channels will have the correct volume, but the surround channel will not be bit perfect (the other 3 channels will be bit perfect) when decoding with ArcSoft. Decoding with Sonic will result in all channels being bit perfect with the next eac3to version.
Unfortunately there's nothing I can do about the Hi-Def demo DTS track.
Originally Posted by Beastie Boy View Post
This doesn't work for me. If I specify a bitrate, eac3to errors with 'This audio conversion is not supported'.
Strange, it works for me. Please post your command line and the full eac3to log.
I don't think that's right. DTS-ES Matrix is decoded as 5.1 by all decoders. DTS-ES Discrete 6.1 is correctly decoded to 6.1 by the ArcSoft decoder, I think (if you're sure that I'm wrong here I'd be happy about a sample). The Sonic decoder decodes DTS-ES Discrete 6.1 to either 5.1 or 6.1, depending on which channel extension is used. Sonic supports 6.1 XCh, but not 6.1 XXCh. libav DTS decoding is generally limited to 5.1.
Okay, I reran the thing again (adding -sonic, too). And this was the result:
+ DTS-Core
- frameSize 2012
- DTS-ES +
- channelNo 6
- lfe 1
- channelDescr 6.1
- samplingRate 48000
- bitDepth 24
- bitrate 1536000
- dialNorm 4
- extAudio XXCh
- samplesPerFrame 512
- copyHistory 1
Yeah, that explains the problem. The Sonic DTS-Decoder doesn't support XXCh. That's why this DTS track is decoded as 5.1, only, while eac3to thought it would be decoded as 6.1. I guess I need to make eac3to aware of that Sonic sometimes decodes 6.1 as 5.1 and sometimes as 6.1... <sigh>
If possible, a small sample of the DTS track would be a nice addition for my sample collection.
Old 7th September 2008, 17:34   #6108  |  Link
madshi
There is DTS-ES 5.1 (also called "DTS-ES Matrix") and DTS-ES 6.1 (also called "DTS-ES Discrete"). These are two very different things. For a decoder DTS-ES Matrix looks like normal 5.1 with just the "ES" flag set. But DTS-ES Discrete has an XCh or XXCh extension in the DTS stream which contains a full separate channel. You can use "eac3to some.dts -logdts" to get exact information about what extensions are contained in your DTS files.
Old 7th September 2008, 18:02   #6109  |  Link
rebkell
Nautilus cheated, he edited his answer after I had already read it
rebkell is offline   Reply With Quote
Old 7th September 2008, 18:19   #6110  |  Link
nautilus7
nautilus7's Avatar
Yes, that's true, but I hoped you would have a look in my post again.
Old 7th September 2008, 18:31   #6111  |  Link
rebkell
No problem, I sub to the thread and it goes to the newest post and it works great, but if someone edits a post it doesn't show up as a new post, even though it has a later time/datestamp than the newest post.
I have a different scenario than the majority in this thread(I suppose). I record with the HD-PVR, then reencode with x264(to get some better IDR frames for scenecut purposes) and then mux it back into a ts with tsmuxer, then I cut out commercials with h264ts_cutter and I used to occasionally get some a/v sync problems. So there is no telling what kind of audio overlaps and gaps end up in the cut file.
Old 7th September 2008, 19:49   #6112  |  Link
rica
Why do you use another cutter while TSMuxer exists?
Cut while remuxing and merge the files with eac3to. (another tip, btw there is no VC1 cutter except TSMuxer afaik.)
Old 7th September 2008, 19:54   #6113  |  Link
tebasuna51
tebasuna51's Avatar
@madshi, you are right, I was talking about DTS-ES "Matrix" (with Cs mixed in Ls-Rs) encoded with DTS PRO SERIES SURROUND ENCODER, well detected by eac3to -logdts like:
+ DTS-Core
- frameSize 2013
- DTS-ES +
- channelNo 5
- lfe 1
- channelDescr 5.1
I don't have samples "DTS-ES Discrete"
Old 7th September 2008, 19:55   #6114  |  Link
madshi
You can create them with that Pro encoder you mentioned, I think.
Old 7th September 2008, 19:58   #6115  |  Link
madshi
eac3to v2.61 released
http://madshi.net/eac3to.zip
* added read/write support for Sony wave64 (*.w64) format
* added read/write support for RF64 wave64 (*.rf64) format
* added write support for AGM format
* true bitdepth (e.g. 18 bits) is written to extensible wav header now
* when reading 16/24 (true/storage) WAV files, zero bytes are stripped now
* added HDCD detection for WAV and FLAC files
* added HDCD detection for PCM tracks in VOB/EVO/m2ts containers
* added HDCD decoder written by Christopher Key
* added new option "-decodeHdcd" to decode HDCD information
* HDCD track -> lossy format: HDCD decoding is automatically activated
* when DTS-MA and TrueHD tracks are decoded, a check for HDCD is done
* fixed some incorrect DTS channel masks
* added automatic libav DTS channel remapping
* added automatic ArcSoft DTS channel remapping
* added channel map manipulation to make funny DTS tracks decode with Sonic
* added channel map manipulation to make funny DTS tracks decode with ArcSoft
* added channel volume modification to undo ArcSoft mono surround splitting
* for TrueHD+AC3 creation AC3 delay and gap correction are disabled now
* fixed: DTSWAV and DTSAC3 readers reported too long runtime
* fixed: sometimes processing aborted with a "bitdepth reducer" complaint
Many thanks to Christopher Key for providing the HDCD decoder!
Old 7th September 2008, 20:04   #6116  |  Link
Thunderbolt8
guess I might have missed, but what exactly is HDCD (good for)? according to wikipedia it seems to be some kind of technology for accounstic improvement for CDs and DVDs? does someone who just wants to convert the lossless tracks of movies to flac need this somehow?
thanks again for new!
Old 7th September 2008, 20:07   #6117  |  Link
nautilus7
nautilus7's Avatar
And many thanks to you for all the new features and excellent support of this program.
One question though... Is this the 1st step for adding support for the official DTS encoder?
Old 7th September 2008, 20:13   #6118  |  Link
madshi
Some audio CDs are encoded with HDCD. On a normal CD player they play just like a normal CD in 16 bit. However, there are CD players which can detect and make use of the HDCD coding. Which results in the audio tracks being enhanced to something more than 16 bit (something between 16 bit and 20 bit). This technology is usually only used for audio CDs and not for movies. Now eac3to can detect HDCD tracks and decode them which basically means increasing the bitdepth from 16 bit to something a little bit higher than 16 bit. If you have hardware which supports HDCD you will not want eac3to to decode HDCD, but let the hardware decode it instead (that saves space). But if your hardware can't do HDCD and you do have some HDCD audio tracks, eac3to can now decode them to full bitdepth.
Old 7th September 2008, 20:14   #6119  |  Link
madshi
Maybe. Or maybe not.
Old 7th September 2008, 20:18   #6120  |  Link
nautilus7
nautilus7's Avatar
I see.
btw, that encoder can do DTS-ES Discrete 6.1 (and Matrix 6.1).
eac3to
