30th January 2017, 00:08 | #201 | Link |
How did you get that crash dump?
Also weird, you're right. I don't know why its not crashing now edit: haha I'm dumb as shit. I was loading a script that didn't exist. It still crashes, only now its when trying to load the signpost instead of the script.. how can I obtain a data dump like you posted? Last edited by osgZach; 30th January 2017 at 00:14. |
30th January 2017, 03:59 | #202 | Link |
So I also went back to AVFS distributed with R35
Vegas won't import AVS scripts unless I throw a ConvertToRGB() on the end, however that does also make AVFS crash. ConvertToRGB() will make it crash when trying to load the signpost ConvertToRGB24() will make it crash immediately upon trying to mount the script Oddly enough if I use DirectShowSource instead of AviSource, it will load the file, ConvertToRGB won't crash anything and the video track will import into Vegas just fine from what I can tell I hope this information is helpful |
13th March 2017, 16:24 | #203 | Link |
can AVFS expose a flagged interlace AVI file?
Hi to all, kindly I wonder if there is a way so that the virtual .AVI file have the interlace flag. My NLE recognize the AVFS output only as "progressive" also even if the content is interlace. Consequently I come to have a series of problems related to the treatment, if possibile I would like to have a virtual .AVI file (uncompressed YUY2 in my case) that looks like interlaced.. also for the mediainfo. Is this possible? thanks
13th March 2017, 18:35 | #204 | Link | |
Professional Code Monkey
17th March 2017, 00:43 | #205 | Link |
RAM usage by AVFS
Hi, I use AVFS to load 100/150 video clips (video only, no audio) and I have noted that for each clip loaded there is a RAM usage. When I have charged all the clips the PC is slow because freee RAM is too little. I wonder if is there a way to set avfs, possibly, to avoid ram usage or use only hard disk. Thanks
18th March 2017, 01:35 | #206 | Link |
RAM usage by AVFS
Hi, I use AVFS to charge 100/150 video clip (no audio) but I have noted that when the number of clip loaded is too high my PC become slow and the usage of RAM is a lot. Please I wonder if is there a way to don't use RAM for each clip loaded or if AVFS can use hard disk instead of ram. Thanks
21st March 2017, 19:58 | #207 | Link |
All bugs should now have been ironed out in VS R37. I can also blame them all on Avisynth 2.6 API changes. They're evil.
27th March 2017, 09:07 | #208 | Link |
can AVFS expose a virtual MJPEG stream?
kindly I wonder if there is a way to get as target .AVI a MJPG video file instead of YUY2 uncompressed. I know this process is not really cheap but to improve compatibily with some NLE software that can manage only mjpeg video file .. this is the only way. Is it possibile? thanks |
27th March 2017, 09:08 | #209 | Link | |
Filler.
27th March 2017, 20:08 | #210 | Link |
I understand, otherwise is there a way to get an interlaced .avi YUY2 uncompressed virtual file? I mean an .avi that is "flagged interlace" and represent a pure interlace video file recognized as well aldo by mediainfo. At the moment seems that AVFS expose only a progressive output, even if with a interlaced content... but NLE and all others "receiver" can see it only as "progressive". Is it possible that? thanks
27th March 2017, 20:43 | #211 | Link | |
28th March 2017, 21:33 | #212 | Link |
AVI doesn't have a standard way of flagging filed order, store timecode etc.(at least as far I know). Different companies do it different way using private headers etc.
I would rather see avfs supporting MOV (MXF is to complex I assume) which would make it more robust and better supported. I assume MOV formatter is not trivial either. Last edited by kolak; 28th March 2017 at 21:36. |
14th July 2017, 06:21 | #214 | Link | |
14th July 2017, 12:19 | #215 | Link | |
28th July 2017, 07:46 | #216 | Link |
My windows control panel shows I have 2015 visual C++ installed.
Then I installed 2017 C++ runtime x86 and x64. But avfs still auto exits when I try to mount an .avs. Goes straight back to command prompt. D:\encode>avfs frameserver.avs Press CTRL+C to exit. D:\encode> It just quits and doesn't mount anything. c:\volumes is empty. But i know pfm works because I mounted an iso file just fine. I tried both 1.006 and 1.007. Both auto quit. I'm running win10 x64. Help? my frameserver.avs code is simply AviSource("d:\encode\output.avi") premiere pro is frame serving to output.avi. Last edited by link626; 28th July 2017 at 07:53. |
28th July 2017, 19:21 | #217 | Link |
Some ideas:
29th July 2017, 08:06 | #218 | Link | |
ffmpeg can open and encode from the output.avi. virtualdub can open the avi. But I was trying to frameserve to handbrakecli, because that is what I always use to encode x264. Based on instruction from the web, I needed avfs and pfm in order for handbrakecli to be able to encode from the virtual file. -d switch doesn't show any output at all. it goes straight to "press ctrl c to exit" then quits. However, when I look at my c:\volumes folder, I see a frameserver.avs folder created for a split second, then it disappears. |
29th July 2017, 09:50 | #219 | Link |
I’m guessing you tried reading the “output.avi” file directly into handbrakecli, but it didn’t work, right? Here a couple more ideas:
