3rd August 2017, 03:46 | #44501 | Link |
Yes.
madVR options explained |
3rd August 2017, 16:25 | #44504 | Link | |
- no difference when disabling or enabling "present several frames in advance" - no difference when disabling or enabling "disable desktop composition" - removed madVR including all registry entries and settings.bin. Reinstalled it and enabled "use direct3D 11 for..." -> no luck - Problem also occurs with Media Player Classic. So it doesn't seem to be related to Zoom Player. Are there any settings in Windows 7 or Nvidia display driver which could interfere? |
3rd August 2017, 19:21 | #44507 | Link |
Aero/DWM is enabled?
https://superuser.com/questions/4795...dwm-is-enabled |
3rd August 2017, 19:56 | #44508 | Link | |
Many thanks for all your help here! A great community! Much appreciated. |
4th August 2017, 00:24 | #44509 | Link | |
Naturally, I had also done a bunch of updates so the red herrings were running wild. |
4th August 2017, 16:05 | #44510 | Link |
Hi madshi, Hi community,
unfortunately i've noticed some issues with madVR (?). I hope, sombody can help and give me some support. Global Settings: Windows 10 PRO / 1703 Intel HD-Grafik 630 / current driver madVR v0.91.11 LAV Filters 0.70.2 HTPC -> Yamaha RX-V681 -> LG49UB856V (HDMI Connection) 1. In MPC-HC HD (LAV) Audio Bitstreaming doesn't work with refreshrate changer (madVR) enabled. This issue i've already reported in Mediaportal Forum and sebastiii could fix it in MediaPortal ->Link<-. With refreshrate changer disabled or EVR all is working fine. 2. With MediaPortal / madVR my 4K movies seems to be downscaled, -> although display resolution is reported by TV as 4K. Playback of the same movie with MPC-HC and the same madVR settings isn't downscaled. Is it a wrong setting or am i doing something wrong? 3. Playback of frame packed 3D movies (MVC) unfortunately is completely broken in MPC-HC and Mediaportal (LAV 3D Plugin installed). If i start a 3D mkv, i get heavy flickering and stuttering. I have uploaded a 1 minute video (very bad, but you can see, what i mean) to dropbox ->Link<-. Playback with my "old" HD 4600 and similar driver settings is working fine. As i said before, it would be great, if somebody could help me to find a solution. Thanks in advance Helios Last edited by Helios61; 4th August 2017 at 16:19. |
4th August 2017, 16:08 | #44511 | Link | |
Basically, this needs to be fixed in your player. It needs to handle High-DPI scenarios.
4th August 2017, 17:44 | #44512 | Link | ||
Thanks nevcairiel for your answer.
I should better read the specifications before i buy . So only not working audio bitstreaming is left. |
4th August 2017, 19:26 | #44513 | Link |
Anyone else seeing some strange stutter in video after updating to nvidia 384.94 drivers?
Looks like it's happening once and than everything is back to normal. It almost looks like the hard drive is buffering something for 3 seconds and video is running at 10fps or so. |
4th August 2017, 21:25 | #44514 | Link |
Visual Novel Dev.
Hey Everyone!
I've been out of the loop for a while now, What type of NGU is closest to Softcubic, or rather, what type of NGU is recommended for Anime if I want smooth textures and the least aliasing possible? Thank you!
Visual Novels! https://www.facebook.com/seventh.heart.studios/ https://audiophile-heaven.blogspot.com/ https://www.youtube.com/watch?v=27VWU3ydRY8 |
4th August 2017, 23:36 | #44517 | Link | |
Actually NGU sharp doubling on anime even with "full hd" content on my full hd screen and downscaled using bicubic 150 looks quite nice, I just wouldn't use it for low res stuff. Last edited by ryrynz; 5th August 2017 at 00:02. |
5th August 2017, 07:06 | #44519 | Link | |
I can explain what i have seen and doing a workaround on MP. Somehow, when a refresh is done for this GPU and on 4K resolution only, the Intel Audio/Video is reinit quickly. So what was happened on MP, it was lost to not find the correct Audio device, so the workaround was to add a delay before start the playback (in fact a delay to analyse again the Audio renderer device) then Audio device is correct and playback too. The base of the issue seems to be drivers or something and didn't happen for HD res (1920x1080).
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
5th August 2017, 08:42 | #44520 | Link |
Hi, I need a little help here ...
This happened to me several times. If I advance the movie many times, the render times are increased (from 30ms to 75 or 90ms) and never again are as at the beginning (For example the normal render time is 24ms in fullscreen for this movie and it increases to 90ms or more than 100ms). This happens with luma quadrupling set to direct quadruple -> very high for 720p movies: I try other versions of Madvr, also re install nvidia drivers, nothing works. The only way is to re start Windows or disabling luma quadrupling. Anyone have an idea what may be going on? I already tried to check basic things, but I can not find what the problem may be. I do not know if I explain well what the problem is. Any ideas? Hard config Alienware 17R4 Core i7 7820hk - 32gb RAM - ssd 960 Pro 1tb Graphic Amp + Aorus GTX 1080ti Xtreme Soft Windows 10 Pro + K-lite Code Pack 13.4.0 + Madvr v0.91.11 with 3DLut file Nvidia Drivers 384.94 MSI Afterburner (last version) Before, normal render time After advance the movie many times (3 or 4 times) Thank you in advance!!!
"To infinity, and beyond!" Last edited by Oguignant; 5th August 2017 at 10:07. |
