Old 5th July 2019, 15:47   #14841  |  Link
zeropc
Are we going to see a new version that supports HEVC? Last version is almost a year old
zeropc is offline
Old 5th July 2019, 16:39   #14842  |  Link
sneaker_ger
eac3to v3.32 "added support for h265/HEVC bitstream parsing". So your feature request seems too unspecific. Either way eac3to development seems pretty much stalled. Not much you can do except make a proper feature request on madshi's tracker and keep fingers crossed he finds time/interest to work on it again ...
sneaker_ger is offline
Old 15th August 2019, 18:20   #14843  |  Link
ryu34
Hey I'm trying to use a sony x700 uhd bd player to play back my 4k uhd remuxes from a usb flash drive. It doesn't support true-hd playback from mkv containers, it can only do true-hd from m2ts, however dts-hd ma works fine from either. I thought i could over come this by just using the m2ts straight from the rip but when i playback that file i lose the ability to seek or skip chapters, anyone have any suggestions barring getting a new playback device? Thanks
ryu34 is offline
Old 15th August 2019, 18:40   #14844  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Sadly... With regard to av file/container support, all hardware playback devices have their limitations. And just-so-you-know, the Panasonic UHD players are just as limited as the Sony's in this regard!
SeeMoreDigital is offline
Old 16th August 2019, 22:06   #14845  |  Link
ryu34
OK new question what kind of tools do i need to use with eac3to to demux 4k UHD dics rips and remux them into my own custom m2ts , edit i tried ts muxer and the audio desyncs from the video when using a true-hd track demuxed from the disc rip using eac3to.
ryu34 is offline
Old 17th August 2019, 11:25   #14846  |  Link
tebasuna51
tebasuna51's Avatar
I don't know any free tool to manage 4k UHD m2ts.
tsMuxeR can't do it, read this, now the source code is released and maybe it can work in the future.
tebasuna51 is offline
Old 17th August 2019, 23:49   #14847  |  Link
stax76
stax76's Avatar
Can somebody with a trustworthy reputation provide updated libraries?
https://github.com/staxrip/staxrip/issues/32
stax76 is offline
Old 18th August 2019, 00:44   #14848  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
you can use Rarewares for libflac update (remember to use only the x86 build for eac3to).
www.rarewares.org/lossless.php
They use latest library.
According to hydrogenaud.io forums, the only real differences for FLAC 1.3.2 and 1.3.3 is mainly for behind the curtain updates.
Nothing useful for the end-user and not worth re-compressing your existing library that has used 1.3.2 in the past.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Sparktank is offline
Old 18th August 2019, 03:22   #14849  |  Link
stax76
stax76's Avatar
Thanks, I found everything I needed.
stax76 is offline
Old 5th September 2019, 13:42   #14850  |  Link
samf88
Hi all... not sure if this doubles as a help thread but hoping someone can spot where I'm going wrong with eac3to. I searched and found others have had this error, but help threads have fizzled out before anything was resolved.
All I want to do is demux *all* video/audio/subs/chapters tracks from a BD playlist on my hard drive to a separate directory (obviously I don't want to demux within the BD structure). I don't want to convert or encode anything, but it seems to think that's what I want to do. Where am I going wrong?
C:\>"D:\eac3to.exe" "F:\BD\MOVIE" 2) -demux "F:\eac3toDemux"
M2TS, 1 video track, 1 audio track, 6 subtitle tracks, 0:21:02, 24p /1.001
1: MPEG2, 1080p24 /1.001 (16:9)
2: AC3, English, 2.0 channels, 192kbps, 48kHz
3: Subtitle (PGS), English
4: Subtitle (PGS), Chinese
5: Subtitle (PGS), Dutch
6: Subtitle (PGS), French
7: Subtitle (PGS), Italian
8: Subtitle (PGS), Spanish
Track 2 is used for destination file "".
This audio conversion is not supported.
I understand I can manually select each track and give it a filename, but I was hoping to do that stuff further on in my workflow as this isn't a one off job.
All of the eac3to help pages seem to imply the -demux flag is for demuxing *everything* so I'm not sure where I'm going wrong. Thanks in advance!
samf88 is offline
Old 5th September 2019, 22:04   #14851  |  Link
tebasuna51
tebasuna51's Avatar
If tou want specify a separate directory try:
"D:\eac3to.exe" "F:\BD\MOVIE" 2) "F:\eac3toDemux\title.*"
Old 24th September 2019, 14:34   #14852  |  Link
stax76
stax76's Avatar
Has anybody experienced:
The program can't start because hs is missing from your computer.
It first occurred after updating the DTS library. So far only one user reported it.
https://forum.doom9.org/showthread.p...44#post1885544
stax76 is offline
Old 25th September 2019, 02:58   #14853  |  Link
tebasuna51
tebasuna51's Avatar
Nope. I never see that message with eac3to 3.34 (W 10).
What is the eac3to version included in Staxrip 2.0.2.0 than work?
Old 29th September 2019, 01:13   #14854  |  Link
stax76
stax76's Avatar
Sorry about the late reply, the versions were probably the same, the difference was an updated DTS library I had compiled. The problem was solved meanwhile, it had something to do with a VC++ runtime dependency.
stax76 is offline
Old 29th September 2019, 23:52   #14855  |  Link
tebasuna51
tebasuna51's Avatar
... the difference was an updated DTS library I had compiled. The problem was solved meanwhile, it had something to do with a VC++ runtime dependency.
Please let us know if the updated library work with eac3to better than old one.
Old 8th October 2019, 16:57   #14856  |  Link
kws53
I do this all the time.
1) Create a directory for the new files
2) Right click on the directory listing (at top) in Windows File Explorer, and select "Copy as Text"
3) In your CLI (Command Prompt in Windows), navigate to the correct DRIVE for your copied directory listing (typically type Drive letter, then colon), type "CD", then Right click and paste the directory text. Hit Enter.
4) Then in that directory, put in the location of your eac3to executable and the optical (or MOUNTED hard drive) that your ISO file is on.
5) For example: create a directory "Martian_1080" on Drive D. In Explorer, right click and copy this directory as text. Then in Command Prompt, type "D:", then ENTER. Then "CD ", then right click, paste. Then ENTER. You are now in the directory you wish to save your files.
Here is what it would look like: D:\Martian_1080>F:\video\eac3to a: 1) -demux (Actually omit the "1) -demux" portion initially to get a listing of all of the MPLS streams. Then select the appropriate stream 1), 2), etc.)
This will demux EVERYTHING on the ISO on drive a: and put it into D:\Martian_1080\
kws53 is offline
Old 12th October 2019, 16:07   #14857  |  Link
Harrenkyym
Hola, tebasuna, ¿qué tal? Escribiré en inglés, for everyone, but I miss so much mundodivx...
I have a question, as always, I keep building my own video library. When I want to sync the spanish audio with microhd movie, I get for example: 2: stdout.wav +6240ms -25.000 -changeTo23.976 | qaac -V 99 --ignorelength --adts --no-delay -o %_2eng.aac - At this point everything is OK, both movies have the same fps and I have calculated the difference between them, but what happens when everything is set and i discover that the audio in the spanish movie comes with a delay of 600ms already? How do I have to proceed? Thank you.
Harrenkyym is offline
Old 14th October 2019, 10:42   #14858  |  Link
tebasuna51
tebasuna51's Avatar
Hello Harrenkyym! I don't know you with this nick in dead spanish forum mundodivx.
I can't explain 600ms but maybe less.
eac3to always apply the delay before the time expansion (25 -> 23.976), no matter if you use diferent parameter order:
is the same than
-25.000 -changeTo23.976 +6240ms
Then the delay is expanded also to 6240 * (25*1,001/24) = 6506 ms
266 bigger than 6240
If you want a final delay of 6240 ms you must use:
+5984ms -25.000 -changeTo23.976
Old 28th October 2019, 05:15   #14859  |  Link
SquallMX
Special SeeD
Seamless branching for new 4K titles seems to be broken. Audio goes out of sync, subtitles are also affected.
SquallMX is offline
Old 28th October 2019, 08:46   #14860  |  Link
l00t
Where's my loot?
Not just for new titles, but for almost every seamless branched UHD discs. For these it is recommended to use DGDecNV or MakeMKV.
l00t is offline
eac3to
