Old 13th September 2019, 05:26   #7021  |  Link
suarsg
Originally Posted by Wolfberry View Post
x265-3.1+11-de920e0-win64-static-multilib
x265 [info]: HEVC encoder version 3.1+11-de920e0a3183
x265 [info]: build info [Windows][GCC 9.2.1][64 bit] 8bit+10bit+12bit
x265 [info]: (libavcodec  58.55.101)
x265 [info]: (libavformat 58.31.104)
x265 [info]: (libavutil   56.33.100)
x265 [info]: (lsmash       2.16.1)
Added a new option --lavf to force the use of lavf demuxer regardless of file extension, but this option has no effect on Y4M files.
x265-3.1+11-de920e0-win64-static-multilib+svt (linked with SVT-HEVC, bigger file size)
Hello Wolfberry,
Did you change the order of the printed parameters in x265_param2string()? The "Encoding settings"-field in the produced metadata header from your binary is in a completely different order than what is the default on x265. It's really weird to see that when you're used to certain parameters being in a particular place. Can't say I'm a fan of this "customization".
suarsg is offline   Reply With Quote
Old 13th September 2019, 11:10   #7022  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Originally Posted by suarsg View Post
Hello Wolfberry,
Yes he did. Use builds from user barough
Old 13th September 2019, 11:31   #7023  |  Link
Barough
Barough's Avatar
x265 v3.1+19-c4b098f973e6 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.2.0)
https://bitbucket.org/multicoreware/x265/commits/branch/default
Barough is online now   Reply With Quote
Old 14th September 2019, 11:40   #7024  |  Link
redbtn
redbtn's Avatar
What about new option --selective-sao? Anybody knows should i disable it, like --no-sao earlier?
https://bitbucket.org/multicoreware/...f47?at=default
redbtn is online now   Reply With Quote
Old 14th September 2019, 20:31   #7025  |  Link
quietvoid
Yes, --selective-sao 4 (default) enables --sao even if you have --no-sao.
You can disable it all with --selective-sao 0 --no-sao
quietvoid is offline   Reply With Quote
Old 15th September 2019, 09:29   #7026  |  Link
Selur
Selur's Avatar
The confusing part is that
a. just using '--no-sao' doesn't disable SAO, you get
[warning]: SAO turned ON when selective-sao is ON
so to turn sao off you need to use '--selective-sao 0 --no-sao' ,'--no-sao' or '--selective-sao' on it's own isn't enough.
b. With 'selective-sao' is described as 'Disable SAO for all slices', what is SAO used on if you use '--selective-sao 0 --sao' ?
looking at the code:
if (!!m_param->selectiveSAO)
    Slice* slice = frameEnc->m_encData->m_slice;
    slice->m_bUseSao = curEncoder->m_frameFilter.m_useSao = 1;
    switch (m_param->selectiveSAO)
    case 3: if (!IS_REFERENCED(frameEnc))
                slice->m_bUseSao = curEncoder->m_frameFilter.m_useSao = 0;
            break;
    case 2: if (!!m_param->bframes && slice->m_sliceType == B_SLICE)
            break;
    case 1: if (slice->m_sliceType != I_SLICE)
            break;
else
here are a few conclusions:
  • '--selective-sao 0 --sao' and '--selective-sao 4 --sao' and '--selective-sao 4 --no-sao' all do the same thing, they do the same as the old '--sao' (should be no surprise this causes confusion)
  • only '--selective-sao 0 --no-sao' disabled SAO
  • '--selective-sao X' with X > 0
  • man, that is a fugly coding style
Cu Selur
Old 15th September 2019, 14:18   #7027  |  Link
Boulder
Pig on the wing
Boulder's Avatar
--no-sao should definitely mean switching SAO off completely. It's ridiculous to add some other parameter affecting the choice.
Old 15th September 2019, 21:57   #7028  |  Link
redbtn
redbtn's Avatar
Another issue with selective-sao is no space between rd and selective-sao
MediaInfo shows rd=4selective-sao=0
I don't know how propertly create issue on bitbucket.
Hex Editor:
Old 16th September 2019, 09:50   #7029  |  Link
LigH
LigH's Avatar
Possibly best choice to report a bug: x265 developer mailing list.
I forwarded your report, redbtn.
New German Gleitz board
Old 16th September 2019, 13:11   #7030  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Using the latest VS2019 AVX build (3.1+19-c4b098f) from here: http://msystem.waw.pl/x265/ crashes the encoder in the beginning. Does anyone else have the same issue? I'm using a Ryzen 1800X with AVX2 disabled in the x265 command line.
Old 17th September 2019, 10:26   #7031  |  Link
benwaggoner
The broader question is what are the psychovisual and compression efficiency impact of the different modes. The documentation is tragically light on the "why" of this feature. SAO is fast enough that I don't see any direct perf advantage of this, although perhaps it might help parallelization in some esoteric way to only do SAO on non-predicted frames or something.
But if SAO detail loss varies somewhat by frame type, only using it on intra stuff might enhance detail with less of a compression efficiency hit than turning it off outright.
Ben Waggoner
My Compression Book
Old 18th September 2019, 12:59   #7032  |  Link
LigH
LigH's Avatar
The media-autobuild suite now introduced experimental support for ccache.
About at the same time, I have issues building a multilib x265 encoder with the manually fiddled build script which usually worked for years already. But building in MABS passes without error.
I am not sure if I have too many linking flags which may interfere with either ccache or with the current development state of x265. It fails linking the DLL:
[ 84%] Linking CXX shared library libx265.dll
E:/MABS/msys64/mingw32/bin/../lib/gcc/i686-w64-mingw32/9.2.0/../../../../i686-w64-mingw32/bin/ld.exe: CMakeFiles/x265-shared.dir/objects.a(vec-primitives.cpp.obj):vec-primitives.cpp:(.text+0x2c): undefined reference to `x265::setupIntrinsicDCT_sse3(x265::EncoderPrimitives&)'
E:/MABS/msys64/mingw32/bin/../lib/gcc/i686-w64-mingw32/9.2.0/../../../../i686-w64-mingw32/bin/ld.exe: CMakeFiles/x265-shared.dir/objects.a(vec-primitives.cpp.obj):vec-primitives.cpp:(.text+0x39): undefined reference to `x265::setupIntrinsicDCT_ssse3(x265::EncoderPrimitives&)'
E:/MABS/msys64/mingw32/bin/../lib/gcc/i686-w64-mingw32/9.2.0/../../../../i686-w64-mingw32/bin/ld.exe: CMakeFiles/x265-shared.dir/objects.a(vec-primitives.cpp.obj):vec-primitives.cpp:(.text+0x4f): undefined reference to `x265::setupIntrinsicDCT_sse41(x265::EncoderPrimitives&)'
collect2.exe: error: ld returned 1 exit status
For a Win32 build, it fails only for the 8 bit precision library where assembler is used at all. For the Win64 build, it fails for all precisions as they all use assembler code.
Old 19th September 2019, 06:35   #7033  |  Link
aymanalz
Is it normal that x265 is about 20% slower on a Zen+ CPU than a Haswell, even though the Zen+ has a higher clock speed? I remember comments here about the AVX2 in AMD being only half as fast (?) as that in Intel, or something to that effect. Could that be the reason? Or could it be that the x265 developers haven't optimized the code for AMD as much as they have for Intel? It is a bit surprising, because this Zen+ architecture is from late 2018, a good few years later than Haswell.
aymanalz is offline   Reply With Quote
Old 19th September 2019, 08:46   #7034  |  Link
nevcairiel
Yes, the lack of full speed AVX2 is definitely a big factor, x265 uses a lot of it. Zen2 of course "solved" that shortcoming.
Old 19th September 2019, 16:20   #7035  |  Link
NikosD
Right on both.
Zen+ has a slower implementation of AVX2 than Haswell onwards, but x265 is also optimized for Intel and favors Intel vs AMD.
Actually, Intel published a paper along with x265 developers working together for AVX-512 optimizations (Intel-only) but they didn't manage to succeed in this, AVX-512 is so ineffective for x265 that most of the times you have to disable it according to Intel, not me.
x265 is an Intel-friendly project but Zen 2 architecture and Ryzen 3000 series managed to be a lot faster in x265 and beat Intel in its own favorite H.265 encoder.
Win 10 x64 (18362.388) - Core i3-9100F - nVidia 1660 (436.15)
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 19th September 2019, 20:14   #7036  |  Link
filler56789
SuperVirus
filler56789's Avatar
x265.exe 3.2_RC1+1-00d8df1b3bc6
(x64, multilib, GCC 9.2.0, upxed)
http://www.mediafire.com/file/k72pa2...b3bc6.rar/file
filler56789 is offline   Reply With Quote
Old 20th September 2019, 13:52   #7037  |  Link
LigH
LigH's Avatar
I borrowed the toolchain files from the CMake call in MABS, now it builds again.
Old 20th September 2019, 19:10   #7038  |  Link
mini-moose
The quotes on solved means they didn't solve it at all?
mini-moose is offline   Reply With Quote
Old 20th September 2019, 20:10   #7039  |  Link
Natty
Noob
no changelog for 3.2?
Natty is offline   Reply With Quote
Old 20th September 2019, 21:18   #7040  |  Link
MeteorRain
結城有紀
Means it wasn't really an issue. So usually you say they improved the performance.
MeteorRain is offline   Reply With Quote
