Old 20th July 2016, 02:55   #4001  |  Link
Barough
Barough's Avatar
Originally Posted by nakTT View Post
Is this the same as the one that can be found in the webpage below?
https://builds.x265.eu
No. It's 'my' compiles made through media-autobuild suite.
Sent from my Samsung Galaxy S7 edge via Tapatalk
Old 20th July 2016, 10:16   #4002  |  Link
sneaker_ger
Originally Posted by littlepox View Post
OK here is a good demo about x265's max-tu-size 16 bug:
Is this a regression of 2.0? It reminds me of the problems with tune grain. Wondering if they are related.
http://forum.doom9.org/showthread.ph...53#post1762253
Old 20th July 2016, 15:52   #4003  |  Link
brumsky
Originally Posted by Leo 69 View Post
@brumsky
Can you provide a problematic sample? I'd be glad to play with it.
Hey Leo 69, thanks for the offer it turns out to be faulty hardware. It started doing the same thing in everything.
brumsky is offline   Reply With Quote
Old 21st July 2016, 06:12   #4004  |  Link
bin.n2f
--tune film Update:
--crf 18 --ctu 32 --pbratio 1.2 --cbqpoffs -3 --crqpoffs -3 --no-sao --subme 3 --b-intra --no-amp --weightb --aq-mode 3 --aq-strength 0.9 --rd 4 --psy-rd 2.5 --psy-rdoq 4.0 --rdoq-level 2 --rc-lookahead 80 --qcomp 0.65 --no-strong-intra-smoothing --limit-modes
Reintroduce --ctu 32 since further tests suggest the buggy term is --max-tu-size 16, while --ctu 32 is innocent.
Increase psy 2.0:3.0 to 2.5:4.0 which should further reduce blurriness, enhancing visual quality. (bit-rate should increase as well, but worthy)
Add --limit-modes in case someone enables --rect at preset medium (which I strongly DISRECOMMEND; --rect should only be used at preset slower or above)
At the same time, here we go for a --tune animation:
--crf 18 --ctu 32 --ref 4 --bframes 6 --pbratio 1.2 --cbqpoffs -3 --crqpoffs -3 --no-sao --subme 3 --b-intra --no-amp --weightb --aq-mode 3 --aq-strength 0.8 --rd 4 --psy-rd 1.8 --psy-rdoq 1.5 --rdoq-level 2 --rc-lookahead 80 --qcomp 0.65 --no-strong-intra-smoothing --limit-modes
hi,sir
thanx for your recommendations
what would you suggest for less than HD 720p resolution?
greetings for all doom9rs, x265 developers & Staxrip
bin.n2f is offline   Reply With Quote
Old 21st July 2016, 08:43   #4005  |  Link
gamebox
@divxmaster: Thanks for sharing your experience with pre-sharpening. I've browsed the complete list of AviSynth sharpening plugins/scripts, and will test some to see the results on both sharpening and resulting bitrate (whether image complexity increases as well). For now, "adaptive" sharpening seems to me as the most appropriate direction to go. I've started using Lanczos4resize which improves sharpness (though it introduces halo as well, unlike Lanczos3). Also, decreased deblock from -1 to -2, and am currently testing -3 as image quality improved after I discarded qg size 16 parameter and artifacts stopped "accumulating" in smaller image blocks containing sharp, pronounced details where they were overly visible.
I compress using modified "slower" profile - me star, subme 7, rd 6, ref 6, bframes 9, aq-mode 2/strength 2, psy rd 2, psy rdoq 1, no rskip, rect, no sao, no strong intra smoothing. Speedup options are limit modes, limit refs 3, no weightb, no amp, max merge 2.
gamebox is offline   Reply With Quote
Old 21st July 2016, 17:58   #4006  |  Link
littlepox
Originally Posted by bin.n2f View Post
hi,sir
No idea, never tested that case.
littlepox is offline   Reply With Quote
Old 21st July 2016, 20:49   #4007  |  Link
youli
youli's Avatar
Source (BD3D) info:
DISC INFO:
Disc Title:     AVATAR (Ext-3D-2D)
Disc Size:      51*965*373*624 bytes
Protection:     AACS
BD-Java:        No
Extras:         Blu-ray 3D
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 2:57:57.083 (h:m:s.ms)
Total Bitrate:          38,94 Mbps
VIDEO:
Codec                   Bitrate             Description
MPEG-4 AVC Video        21857 kbps          1080p / 23,976 fps / 16:9 / High Profile 4.1
MPEG-4 MVC Video        10966 kbps
AUDIO:
Codec                           Language        Bitrate         Description
DTS-HD Master Audio             Russian         4096 kbps       5.1 / 48 kHz / 4096 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           Russian         0,847 kbps
BDRip OverUnder HEVC/H.265 mediainfo:
General
Unique ID                                : 253356374572038614152649260802854783875 (0xBE9AA9AFD08939C68C293ACFBDDE8B83)
Complete name                            : E:\temp\Avatar (2009) 1080p HEVC 3D-ab.mkv
Format                                   : Matroska
Format version                           : Version 3 / Version 2
File size                                : 22.1 GiB
Duration                                 : 2 h 57 min
Overall bit rate                         : 17.8 Mb/s
Movie name                               : Avatar (2009) 3D Full-T&B (x265)
Encoded date                             : UTC 2016-07-21 19:26:29
Writing application                      : mkvmerge v9.2.0 ('Photograph') 64bit
Writing library                          : libebml v1.3.3 + libmatroska v1.4.4
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5@High
MultiView_Count                          : 2
MultiView_Layout                         : Top-Bottom (left eye first)
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 15.9 Mb/s
Width                                    : 1 920 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 0.889
Original display aspect ratio            : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.160
Stream size                              : 19.8 GiB (90%)
Title                                    : 3D Full-T&B (x265)
Writing library                          : x265 2.0+2-70581d6cd065:[Windows][GCC 5.3.0][64 bit] 10bit
Encoding settings                        : wpp / ctu=64 / min-cu-size=16 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=2 / subme=7 / merange=25 / no-rect / no-amp / max-merge=2 / temporal-mvp / early-skip / rskip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=24 / lookahead-slices=6 / bframes=6 / bframe-bias=0 / b-adapt=2 / ref=1 / limit-refs=0 / no-limit-modes / no-weightp / no-weightb / aq-mode=3 / qg-size=32 / aq-strength=0.60 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=0.90 / rdoq-level=1 / psy-rdoq=2.50 / no-rd-refine / no-signhide / no-deblock / no-sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=crf / crf=23.0 / qcomp=0.80 / qpmin=0 / qpmax=51 / qpstep=4 / vbv-maxrate=100000 / vbv-bufsize=100000 / crf-max=0.0 / ipratio=1.10 / pbratio=1.00
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.709
Audio
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Mode                                     : 16
Format settings, Endianness              : Big
Codec ID                                 : A_DTS
Bit rate mode                            : Constant
Bit rate                                 : 1 509 kb/s
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 93.750 FPS (512 spf)
Bit depth                                : 24 bits
Delay relative to video                  : 21 ms
Stream size                              : 1.88 GiB (8%)
Title                                    : Russian (DTS 5.1 48KHz)
Language                                 : Russian
Default                                  : Yes
Forced                                   : No
x265 encode log:
Encoding movie in 3D
Movie: Avatar (2009)
Encoding started 20.07.2016 15:45:02,70
E:\temp\Avatar (2009)\00000>"D:\Install\MKV\BD3D\BD3D2MK3D v0.92\toolset\avs2yuv
.exe"   "__ENCODE_3D_MOVIE.avs" -frames 255994 -o -     | "D:\Install\MKV\BD3D\B
D3D2MK3D v0.92\toolset\x265_10bit_x64.exe"   --crf 23 --preset ultrafast   --lev
el-idc 5 --high-tier --me umh --subme 7 --scenecut 40 --aq-mode 3 --aq-strength
0.6 --no-sao --no-deblock --rd 3 --psy-rd 0.9 --b-adapt 2 --ctu 64 --min-cu-size
 16 --rc-lookahead 24 --bframes 6 --merange 25 --ipratio 1.1 --pbratio 1.0 --qco
mp 0.8 --rdoq-level 1 --psy-rdoq 2.5 --lookahead-slices 6   --sar 2:1 --range li
mited --colorprim bt709 --qpfile chapters_3D.qpfile --frames 255994 --fps 24000/
1001   --output "00000_3D.265" --y4m -
__ENCODE_3D_MOVIE.avs: 1920x2160, 24000/1001 fps, 255994 frames
y4m  [info]: 1920x2160 fps 24000/1001 i420p8 sar 2:1 unknown frame count
raw  [info]: output file: 00000_3D.265
x265 [info]: HEVC encoder version 2.0+2-70581d6cd065
x265 [info]: build info [Windows][GCC 5.3.0][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
x265 [warning]: Specifying a decoder level with constant rate factor rate-contro
l requires
x265 [warning]: enabling VBV with vbv-bufsize=100000kb vbv-maxrate=100000kbps. V
BV outputs are non-deterministic!
x265 [info]: Main 10 profile, Level-5 (High tier)
x265 [info]: Thread pool created using 8 threads
x265 [info]: frame threads / pool features       : 3 / wpp(34 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 16
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge         : umh / 25 / 7 / 2
x265 [info]: Keyframe min / max / scenecut       : 23 / 250 / 40
x265 [info]: Lookahead / bframes / badapt        : 24 / 6 / 2
x265 [info]: b-pyramid / weightp / weightb       : 1 / 0 / 0
x265 [info]: References / ref-limit  cu / depth  : 1 / off / off
x265 [info]: AQ: mode / str / qg-size / cu-tree  : 3 / 0.6 / 32 / 1
x265 [info]: Rate Control / qCompress            : CRF-23.0 / 0.80
x265 [info]: VBV/HRD buffer / max-rate / init    : 100000 / 100000 / 0.900
x265 [info]: tools: rd=3 psy-rd=0.90 rdoq=1 psy-rdoq=2.50 early-skip rskip tmvp
x265 [info]: tools: fast-intra strong-intra-smoothing lslices=6
x265 [info]: frame I:   2774, Avg QP:21.94  kb/s: 44087.67
x265 [info]: frame P:  65676, Avg QP:22.51  kb/s: 29397.44
x265 [info]: frame B: 187544, Avg QP:23.86  kb/s: 11273.49
x265 [info]: consecutive B-frames: 10.2% 5.7% 14.1% 50.6% 9.4% 9.4% 0.7%
encoded 255994 frames in 101320.68s (2.53 fps), 16278.82 kb/s, Avg QP:23.50
Encoding finished 21.07.2016 19:53:44,00
Screenshots comparisions BD3D and BDRip:
P.S. Playable on UHD TV LG 55UF85xx-Zx
youli is offline   Reply With Quote
Old 21st July 2016, 23:21   #4008  |  Link
brumsky
--tune film Update:
littlepox, What are the affects of the different aq-modes on speed?
While I haven't done many encodes using aq-mode 2 or 3 - it seems to be 25-35% slower.
thanks,
Old 22nd July 2016, 00:44   #4009  |  Link
Magik Mark
Im looking for a software that would display what encoding parameters were used. Can someone recommend one? Sometimes mediainfo doesn't show what parameters were used. Or this was intentionally deleted by the encoder?
Asus X99 Sabertooth - Xeon E5 2695 - Asus Strix GTX 960 4G - DDR4 16GB Predator - Pioneer KRP 600M (isf calibrated) - Yamaha A3030 - Windows 10 x64 - Kodi with DSplayer - Lav - MadVR - XYsubtitle
Magik Mark is offline   Reply With Quote
Old 22nd July 2016, 01:43   #4010  |  Link
birdie
birdie's Avatar
Any hex editor will do.
birdie is offline   Reply With Quote
Old 22nd July 2016, 05:30   #4011  |  Link
littlepox
thanks,
It should not be that large, during the test we did not even notice anything about their speed.
Furthermore, it is important to point out that larger bitrate itself means slower encode, when you have more bits for CABAC entropy encoding.
Old 22nd July 2016, 07:13   #4012  |  Link
LigH
LigH's Avatar
^ littlepox: And decoding higher bitrates can be slower too (compared with otherwise similar complexity).
_
@ Magic Mark: Not all encoders of the same target format may support storing encoding parameters as auxiliary data; there are more HEVC encoders than just x265. Also you can disable x265 writing them into the video stream (--no-info).
Some parameters could be analyzed from headers or GOP attributes. But others would be hard to discover from the video stream only.
New German Gleitz board
Old 22nd July 2016, 08:39   #4013  |  Link
aymanalz
I think there is some error in your compile, for the last binary you uploaded (2.0 - 8). Using it, I kept getting an error towards the end of the 2nd pass. (Error writing trailer of pipe.) Googling it suggests that it somehow relates to ffmpeg. But I don't get that error with the binary from x265.eu. (I've only tried 2.0 - 5.) Same settings and same media file, of course.
aymanalz is offline   Reply With Quote
Old 22nd July 2016, 08:46   #4014  |  Link
aymanalz
I notice that I am getting vastly improved encoding speeds with version 2.0, than I was with 1.9. Is this true for everybody?
Old 22nd July 2016, 10:53   #4015  |  Link
Barough
Barough's Avatar
Haven't got any errors myself with it. Works fine with CRF though. Will check if there is an updated version of the media-autobuild suite available.
Old 22nd July 2016, 12:43   #4016  |  Link
Barough
Barough's Avatar
x265-v2.0++9-2737c6ff5f80 (MSYS/MinGW, GCC 6.1.0, 32 & 64bit 8/10/12bit multilib EXEs)
Old 22nd July 2016, 14:25   #4017  |  Link
Ma
The 32-bit version hangs. It was reported some time ago https://bitbucket.org/multicoreware/...-x265-hangs-at
Solution for 32-bit GCC 6.1:
export CXXFLAGS="-march=pentium4 -mtune=generic"
*** build 32-bit x265 ***
export CXXFLAGS=
Ma is offline   Reply With Quote
Old 22nd July 2016, 14:38   #4018  |  Link
Barough
Barough's Avatar
Thnx for the info Ma, but it looks like that issue was set to 'Resolved' a couple of days after it was reported.
EDIT
Ahh..... It's a GCC 'issue'. Don't have a clue on how 2 fix that in the media-autobuild_suite.
Old 22nd July 2016, 14:50   #4019  |  Link
easyfab
@Barough
see last message here : https://github.com/jb-alvarado/media...ite/issues/358
It give you an example how to do this
easyfab is offline   Reply With Quote
Old 22nd July 2016, 15:20   #4020  |  Link
Barough
Barough's Avatar
@ easyfab
Thnx for the info/reply.
I had a look @ it but i've never done any modifying like that. I have basically no knowledge when it comes to that kinda stuff. That's why i went for the media-autobuild_suite.
