Old 2nd December 2012, 14:55   #41  |  Link
zee944
Will try that, but meanwhile I have figured out an alternative way I'm rather excited about. Since I wanted a fool-proof method which can be used anywhere and anytime (sometimes I do adding/cropping in RGB32 space too), I thought that I could compare the luma and chroma edges after every "risky" operation, check the possible variations and choose the best match.
This is the raw idea. Using these customized functions for every operation worked alright so far (but I haven't tested fully yet):
function FixChroma(clip clp)
	clp
	GScriptClip("""
		LumaEdges=GreyScale().mt_edge("sobel", U=2, V=2)
		ChromaEdgesN6=MergeChroma(PointResize(width, height, 0,-6)).UToY.PointResize(width, height).mt_edge("sobel", U=2, V=2)
		ChromaEdgesN4=MergeChroma(PointResize(width, height, 0,-4)).UToY.PointResize(width, height).mt_edge("sobel", U=2, V=2)
		ChromaEdgesN2=MergeChroma(PointResize(width, height, 0,-2)).UToY.PointResize(width, height).mt_edge("sobel", U=2, V=2)
		ChromaEdges00=                                             UToY.PointResize(width, height).mt_edge("sobel", U=2, V=2)
		ChromaEdges02=MergeChroma(PointResize(width, height, 0, 2)).UToY.PointResize(width, height).mt_edge("sobel", U=2, V=2)
		ChromaEdges04=MergeChroma(PointResize(width, height, 0, 4)).UToY.PointResize(width, height).mt_edge("sobel", U=2, V=2)
		ChromaEdges06=MergeChroma(PointResize(width, height, 0, 6)).UToY.PointResize(width, height).mt_edge("sobel", U=2, V=2)
		subtitle("no shift")
		AverageLuma(Overlay(LumaEdges, last.UToY.PointResize(last.width, last.height).mt_edge("sobel", U=2, V=2), mode="subtract"))
\> AverageLuma(Overlay(LumaEdges, ChromaEdges06, mode="subtract")) ? clp.MergeChroma(clp.PointResize(width, height, 0, 6)).subtitle("shift +6") : last
\> AverageLuma(Overlay(LumaEdges, ChromaEdges04, mode="subtract")) ? clp.MergeChroma(clp.PointResize(width, height, 0, 4)).subtitle("shift +4") : last
\> AverageLuma(Overlay(LumaEdges, ChromaEdges02, mode="subtract")) ? clp.MergeChroma(clp.PointResize(width, height, 0, 2)).subtitle("shift +2") : last
\> AverageLuma(Overlay(LumaEdges, ChromaEdges00, mode="subtract")) ? clp.MergeChroma(clp.PointResize(width, height, 0, 0)).subtitle("no shift") : last
\> AverageLuma(Overlay(LumaEdges, ChromaEdgesN2, mode="subtract")) ? clp.MergeChroma(clp.PointResize(width, height, 0, -2)).subtitle("shift -2") : last
\> AverageLuma(Overlay(LumaEdges, ChromaEdgesN4, mode="subtract")) ? clp.MergeChroma(clp.PointResize(width, height, 0, -4)).subtitle("shift -4") : last
\> AverageLuma(Overlay(LumaEdges, ChromaEdgesN6, mode="subtract")) ? clp.MergeChroma(clp.PointResize(width, height, 0, -6)).subtitle("shift -6") : last
	""",  args="clp", local=true)
function smartConvertToRGB32(clip c) {
  c
  ConvertToYV24(chromaresample="point")
  MergeChroma(PointResize(width, height, 0, 1))
  ConvertToRGB32()
function smartConvertToYV12(clip c) {
  c
  ConvertToYV12(chromaresample="point")
function smartAddBorders(clip clp, int l, int t, int r, int b) {
  clp
  ss=2
  PointResize(width*ss, height*ss)
  AddBorders(l*ss,t*ss,r*ss,b*ss)
  PointResize(width/ss, height/ss)
  IsYUV ? last : clp.AddBorders(l, t, r, b)
function smartCrop(clip clp, int l, int t, int r, int b) {
  clp
  ss=2
  Crop(l*ss,t*ss,-1*abs(r)*ss,-1*abs(b)*ss)
  IsYUV ? last.FixChroma : clp.Crop(l, t,-1*abs(r),-1*abs(b))
Still need a few advices:
1. Is "UToY.PointResize()" and "VToY.PointResize()" (later) right? Will the chroma subtituting pixels be at their right place, and not shifted by one or half pixel in any direction?
2. Should I merge the edge mask of U and V (not just U)? Sometimes when the image has dull colors, none of them has enough edges to work with, though.
3. Would it be enough to check only +2 (or zero) shift all the time? Can the correction be different than +2 after numerous conversions and border operations?
4. I happened to notice that my source (DVD 720x480) has a chroma shift to begin with. "MergeChroma(PointResize(width, height, 0, 2))" is too much, "MergeChroma(PointResize(width, height, 0, 1))" would be ideal if there would be such thing as 1 pixel shift in YV12. Is replacing PointResize() with Lanczos4Resize() an accepted solution for that?
zee944 is offline   Reply With Quote
Old 5th March 2015, 08:08   #42  |  Link
Kein
Kein's Avatar
Originally Posted by natt View Post
yv12->yv24->yv12 can be lossless with pointresample of chroma, provided the algorithm is correct. avisynth's yv12->yv24 with chromaresample=point is rather incorrect.
Were there any changes on this field in avs' chromaresample since then?
Also, does anyone by any chance know what method Sony Vegas uses when converting imported media to RGB in its own editing space?
Originally Posted by zee944 View Post
[...] leads to heavy chroma shift, very noticeably on the red parts.
I also have a bit similar problem with red shift, but of different origin, any idea how to combat it (crop by even values)? I've been told that upscaling by 1.25 factor causes this and there is no way to avoid it. Colorspace conversion does not happen (all being kept in YvV2).
Kein is offline   Reply With Quote
Old 5th March 2015, 13:58   #43  |  Link
colours
colours's Avatar
Unfortunately Avisynth's PointResize semantics are plain wrong and will never be changed because it needs to keep backwards compatibility with all the scripts that utilise these wrong semantics (e.g. some old versions of Destripe).
Say no to AviSynth 2.5.8 and DirectShowSource!
colours is offline   Reply With Quote
Old 6th March 2015, 11:45   #44  |  Link
Warperus
It's a bit a of mess actually if you are asking about color transformation
http://www.glennchan.info/articles/v...s-9-levels.htm
Also add automatic deinterlace, pull down removal, external quicktime, vfw filters etc.
As for resize, it's bilinear or bicubic in pan/crop and track motion.
Warperus is offline   Reply With Quote
colorspace conversion, quality, rgb32, yv12
