Old 4th April 2011, 22:41   #1  |  Link
jemm54
jemm54's Avatar
Quality compression problem
Hello guys, im having a problem with a compression of a video in h264 with staxrip & Zarxgui,
The problem is that whenever I have a poor quality output, but use quality mode 1 (which should give a quality "lossless") but always noticed that the quality is not as good as it should
here is a sample of what my avisynth script and the resulting Q: 1
Script
http://img851.imageshack.us/img851/8914/snapscript.png
Result Q:01
http://img851.imageshack.us/img851/5...0416h16m16.png
the problem is mainly in the blanket, it lose all the debanding
My codec settings:
http://i.imgur.com/7DK4Y.jpg
http://i.imgur.com/oxR3d.jpg
Apreciate any help you could give me to understand why this happens. Thanks
(Sorry for my bad english)
jemm54 is offline   Reply With Quote
Old 5th April 2011, 18:57   #2  |  Link
Selur
Selur's Avatar
if you output 10bit instead of the normal 8bit that shouldn't happen,... with 8bit use debanding during playback.
(only decoder atm that supports 10bit is the one from mainconcept)
+ there should be a bunch of posts in the forum about the whole banding topic
compression, h264, quality, staxrip, zarxgui
