Old 16th June 2019, 16:48   #56601  |  Link
Stuck on 1080 on my OLED until my amp gets updated, banged in some 48Gbps HDMI cables for good measure. Most of my stuff is 1080 anyway so I can deal for now, but damn OLED is so God damned clean/pure in picture quality, get that 4:4:4 poppin and lord almighty, it's glorious. 10-bit is a waste of time based on the Pana OLED with my limited testing.
just use 2 cables.
Old 16th June 2019, 21:16   #56602  |  Link
toki
I meant I've tried 2 different cords in 2 different spots on the tv and they're both the same. 4.2.0 8 bit. I can't even get RGB, let alone 8 bit 10 bit and so on. I've tried looking for the magic mode to put it in, but haven't found it yet.
toki is offline   Reply With Quote
Old 16th June 2019, 21:29   #56603  |  Link
QBhd
QB the Slayer
QBhd's Avatar
He meant 2 cables as in one to the amp and one to the TV
QB
QBhd is offline   Reply With Quote
Old 16th June 2019, 21:40   #56604  |  Link
ryrynz
ryrynz's Avatar
just use 2 cables.
Already do, just to amp then to tv. Cable length might be an issue doing it that way but might as well do this in the meantime, can always switch out one of the shorter leads since I don't need the bandwidth anyway. Cheers.
Old 16th June 2019, 22:28   #56605  |  Link
mambans
Hello, recently I have noticed a lot of stuttering but it could be because of the the new win 10 update (1903) since it started around that time, but I'm still wondering if anyone else have noticed it? Here are some stats, I noticed I have 20k presentation glitches after 10min.
http://https://i.imgur.com/xcWMXDl.png
https://i.imgur.com/4fjKpIy.jpg
My second question, I'm wondering what's your preferred settings for motion/smooth playback?
Nvidia Gsync on/off?
Smooth motion on/off?
Present a frame for every Vsync?
My specs:
i7-8700k
Gtx 1080Ti
1440p 144hz monitor
Thanks in advance.
mambans is offline   Reply With Quote
Old 16th June 2019, 22:36   #56606  |  Link
Asmodian
G-sync Off, madVR hates Gsync
Smooth motion ON, this takes some GPU power but keeps everything smooth without perfectly tuned refresh rates.
Present Frame for every Vsync On, I have had better luck with this option.
Do you have power set to "Adaptive"? The drivers default to Optimal Powder, which is not good. Also, do you have the newest Nvidia drivers? The older ones had a bug that used a lot of CPU.
A test with D3D11 disabled and with windowed overlay enabled might be useful.
madVR options explained
Old 16th June 2019, 22:51   #56607  |  Link
mambans
Ah oke, I turned off Gsync, set the power to Adaptive and enabled Vsync and that seems to have fixed the stuttering and presentation glitches.
Thanks a lot for the help!
Old 16th June 2019, 23:02   #56608  |  Link
Asmodian
Glad it was so easy. Happy to help.
Old 16th June 2019, 23:19   #56609  |  Link
mambans
Oh, the stuttering/glitches are back. They came back after I restarted the player around 3 times.
Tried disabling D3D11 but that just makes the whole screen black and turning Vsync off didn't help.
Since it worked in the beginning it seems to be fixable but can't find anything else to test. hm..
Old 16th June 2019, 23:21   #56610  |  Link
Asmodian
Disabling D3D11 made the screen black after restarting the player?! Do you have G-sync fully disabled?
Old 16th June 2019, 23:25   #56611  |  Link
mambans
I tried both, disabling for just Pot-player and disable it globally and same result.
Old 17th June 2019, 03:12   #56612  |  Link
alps006
Did you try MPC-BE or MPC-HC instead of Potplayer as Potplayer is known to have issues with madVR in some cases.Even though it is working fine in my system. I have MPC-HC, MPC-BE, Potplayer, Jriver MC and Zoom player installed in my two HTPCs. Every player is configured to use madVR and LAVfilters and I have all these players working fine with madVR. If one player has issues, any one of the other always works.
alps006 is offline   Reply With Quote
Old 17th June 2019, 13:58   #56613  |  Link
mambans
I haven't tried them now but I did try them when I decided media player in the beginning and I didn't quite like them but I might try them again if I can't solve my Potplayer+Madvr problem. But since Potplayer have been working fine for years I do think my problem is fixable somehow
Old 17th June 2019, 14:11   #56614  |  Link
mambans
It seems that 'Philips hue Sync' causes some presentation glitches. So far I've gotten no glitches when Hue Sync is turn off but I will test it a bit more before I'm sure it's fixed.
Old 17th June 2019, 14:32   #56615  |  Link
juanej
Originally Posted by juanej View Post
Hi, my player has been crashing lately when I try to play movies from my laptop connected via hdmi to my onkyo receiver, this is my madvr crash report:
Any thoughts on this? I can't even use MPC now
juanej is offline   Reply With Quote
Old 17th June 2019, 15:07   #56616  |  Link
madjock
The attachments are still awaiting approval, so no one will be able to help with that. Maybe try another upload site and share links, then I am sure the experts here can help you.
It would be good if you shared your full setup as well.
Windows 10-1903 | i5-3570k | GTX 1070 Windforce OC Rev2 8GB : 430.64 | Yamaha RX-V377 | Philips 65PUS6703 - 65"
Old 17th June 2019, 16:13   #56617  |  Link
SirMaster
Originally Posted by Asmodian View Post
Also, 8bit RGB 2160p60 is better quality than 12 bit YCbCr 4:2:2. This is not true if watching via a bluray player but it is when using madVR. I use 8bit RGB 2160p60 most of the time, over HDMI 2.0, on a LG C7 and now a C9.
HDMI 2.1 allows RGB 2160p120, which I am very much looking forward to when a GPU with HDMI 2.1 comes out.
You won't even need a new GPU.
https://www.anandtech.com/show/14535...i-21-converter
SirMaster is offline   Reply With Quote
Old 18th June 2019, 08:17   #56618  |  Link
svengun
Originally Posted by oldpainlesskodi View Post
Yeah, I've updated all my cables in the chain to 48Gbps versions too.
Why would you do that ? 18GB calbes are 100% capable of the requirements with HDMI 2.0b
48GB cables are intended for HDMI 2.1 (8K / 120hz)
Am I missing something ?
Livingroom: Ryzen 7 1700@3.9ghz - Win Insiders Fast Ring - MSI RTX 2700 Gaming - Philips 65OLED803 | Bedroom Ryzen 3 1200 - Win 8.1 - GTX1060 - LG OLED EG920V 55" > All with MadVR latest test build
svengun is offline   Reply With Quote
Old 18th June 2019, 08:19   #56619  |  Link
svengun
just use 2 cables.
was thinking exactly the same thing
2 cables from GPU (one to TV, other to Amp)
Or if the cable is long and you don't wanna run 2 cables, then you could use ARC from the TV to the Amp
Old 18th June 2019, 08:21   #56620  |  Link
oldpainlesskodi
I'm sure by the book you are correct...odd though, when I swapped the new cables in, my card recognized it as a brand new connection, and I had to redo all my nvidia settings...never seen that before swapping cables....
Sapphire RX 5700 XT (19.7.5) Ryzen 7 3700x, PRIME X570-Pro, Win 10 x64 (1903), Silverstone LC13B-E, Pioneer SC-LX501 Elite D3, Samsung UE55KS8000, Mission M33i speakers, Kodi Dsplayer 17.6 X64
oldpainlesskodi is offline   Reply With Quote
