Old 13th June 2019, 02:37   #56541  |  Link
tp4tissue
tp4tissue's Avatar
Originally Posted by Alexkral View Post
The first screenshot is exactly the same in the SDR version. This kind of thing should be checked before blaming the conversion to SDR. As for the problems of oversaturation, there's not much you can do ATM apart from adjusting the color settings on your TV.
It's not a scene with natural skin tone, so I mean.
Based on what reference are we to say it's Over-saturated ?
Ghetto | 2500k 5Ghz
Old 13th June 2019, 04:54   #56542  |  Link
an3k
an3k's Avatar
Hi everybody,
after I finally got some UHD HDR content (that I cannot play because no HDR displays) I somehow got into experimenting instead of just using x265 / madVR and tried to implement mastering display coloring volume metadata into x264 (since the H.264 spec supports it). Even with some help from x264dev on freenode I wasn't able since I can't do C. In the end someone else wrote a patch with the missing bits.
x264 can do HDR now ... woohoo
Sadly madVR doesn't enable tonemapping as it does for x264 HDR content. I guess it's just not enabled for h264 content?
an3k is offline   Reply With Quote
Old 13th June 2019, 05:04   #56543  |  Link
Alexkral
Originally Posted by an3k View Post
Hi everybody,
You can use the hdr=on or transfer=hdr tags for that.
Alexkral is offline   Reply With Quote
Old 13th June 2019, 05:04   #56544  |  Link
madVR worked out of the box with VP9 HDR so is the format the same as x265 or did they change something?
my first look here would be at lav filter is it even shipped with that patch?
Old 13th June 2019, 05:42   #56545  |  Link
an3k
an3k's Avatar
Does the filter / decoder need to be aware of this? The HDR info is inside the bitstream as a SEI.
The patch is currently only on pastebin so basically nothing knows about it /is patched yet.
Old 13th June 2019, 05:47   #56546  |  Link
i'm not a developer for this but the meta data has to reach madVR.
if the source filter needs to repack the meta data for directshow so the renderer can see it you will need the patch.
lavfilter may not even look for the meta data for obvious reasons.
for VP9 a change in lavfilter was needed to get the meta data to madVR. madVR on the other side didn't care and just worked as soon as it got the meta data.
just wait for nev on this he should know. no need to speculate more on this.
Old 13th June 2019, 06:06   #56547  |  Link
Sebastiii
Hi, maybe the link to the patch can help?
Tapatalk
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355.
Sebastiii is offline   Reply With Quote
Old 13th June 2019, 06:18   #56548  |  Link
an3k
an3k's Avatar
Yes, that makes sense. Didn't thought about it but just thought it's just passed-through. Thanks for the insight
Tapatalk
Sorry, absolutely. Here it is https://pastebin.com/nRcBrM3M
Here's the output of h264_parse mpeg4ip version 1.5.0.1 of a file (HEVC HDR to x264 HDR) encoded with a patched x264 https://pastebin.com/cKtUbKUm
Old 13th June 2019, 06:26   #56549  |  Link
Sebastiii
Thanks
Tapatalk
Old 13th June 2019, 12:55   #56550  |  Link
VAMET
UTAVATU
VAMET's Avatar
Dear Friends
I own Lenovo Ideapad 320 i3-7100u with iGPU Intel 620 and GPU GeForce 940MX. I have tried to watch .mkv remux of Gladiator 2160p 23.976 HDR 10bit, but it's not smooth. Rendering is below 41.71ms, but there are lots of dropped frames. Notebook is conntected to my monitor LG 27UK600-W 4K HDR via HDMI cables via Onkyo TX-NR686 (HDMI 2.0b HDCP 2.2).
MPC-HC 1.8.6, madVR 0.92.17, LAV Filters 0.74.1
NVIDIA Control Panel set to maximum performance of 940MX, Windows 10 1809 also 940MX.
LAV Filters - Video Decoder - D3D11 and 940MX
This notebook hardware is to weak to have no frame drops or I am doing something wrong?
Thank you in advance for your help and replies.
Sincerely
VAMET
ALLEGRO BLOG FACEBOOK
VAMET is offline   Reply With Quote
Old 13th June 2019, 13:29   #56551  |  Link
Grimsdyke
Try D3D11 - Automatic/Native in LAV VideoDecoder and from what I read here 'maximum performance' is not recommend. Try 'balanced'.
Grimsdyke is offline   Reply With Quote
Old 13th June 2019, 14:42   #56552  |  Link
sneaker_ger
940MX is used for decoding (see settings window of active LAV Video instance)? According to Wikipedia 940MX is only VP6/Feature Set E, i.e. no good HEVC 10 bit decoding. Or are there more variants? i3-7100u (Kaby Lake) can do it, though.
Next thing is rendering via madvr. Create an empty folder called "ShowRenderSteps" in the madvr folder. Activate madVR OSD (ctrl+j), make a screenshot and post it here.
Old 13th June 2019, 17:01   #56553  |  Link
VAMET
UTAVATU
VAMET's Avatar
Dear Friends
I have reinstalled to the latest madVR and LAV Filters. I have change to default values both softwares and change LAV Video Decoder to D3D11 - Automatic/Native and now I have frame drops only on the launching of movie file and after few seconds there are no more frame drops. When I set LAV Video Decoder other then D3D11 I have frame drops. When I set D3D11 and other then Automatic/Native let say: NVIDIA 940MX or Intel 620 I have also frame drops, so the only one setting works for me Automatic/Native.
I don't know, why automatic exlusive mode is not working and why there is 8bit stated in madVR statistics.
Sincerely
VAMET
Old 13th June 2019, 17:08   #56554  |  Link
brad86
Hi. I have managed to check on a HDR display today, and I can say for certain that this DOES NOT happen.
There IS indeed an issue with the conversion, or setting somewhere, so I am still looking for help with this as my first post says.
brad86 is offline   Reply With Quote
Old 13th June 2019, 17:36   #56555  |  Link
madjock
@brad86
Since you are a long time lurker, do you not think more info from your side would help.
Graphics Card/Driver
Version of MadVR, are you using the latest Beta for HDR to SDR as it is still only Beta testing on it at the moment.
Sounds to me like an "overblown reds" if its an ATI card, but since you don't give any info apart from this is broke, please fix it, with no more input from your side,
There a lots of settings in the later Testing builds here, but as I said, they are still testing it, so there may be issues along the way still.
https://www.avsforum.com/forum/24-di...ector-201.html
Windows 10-1903 | i5-3570k | GTX 1070 Windforce OC Rev2 8GB : 430.64 | Yamaha RX-V377 | Philips 65PUS6703 - 65"
Old 13th June 2019, 17:57   #56556  |  Link
Alexkral
Evil Dead 2 Remastered BluRay > VLC snapshot.
https://drive.google.com/file/d/1shc...ew?usp=sharing
Old 13th June 2019, 18:52   #56557  |  Link
brad86
Another conversion error then.
Old 13th June 2019, 18:54   #56558  |  Link
brad86
Originally Posted by madjock View Post
@brad86
Using a GTX 970 latest non-beta MadVR ( tried beta too ) in conjunction with PotPlayer.
This issue is also present in MPV Player.
Old 13th June 2019, 19:02   #56559  |  Link
DMU
@Daicon
Save this as *.hlsl and load it in MPC-HC. It just convert the gamut to Rec.709 or DCI-P3. You can edit it as a text file, change the gamut option from the second line to DCI-P3 if you get oversaturation.
Do shaders work with madVR and HDR? They only starts with EVR CP.
DMU is offline   Reply With Quote
Old 13th June 2019, 19:05   #56560  |  Link
madjock
@brad86
https://forum.blu-ray.com/showthread...6#post15712176
Post 208.
You also say another conversion issue when someone showed you a screenshot of the "Bluray Remaster", you are not reading the posts.
To sum up its the UHD, nothing else.
And as far as Official/Beta/Testing for HDR to SDR, it has always been a work in progress.
