Old 29th May 2019, 20:04   #56381  |  Link
Asmodian
Originally Posted by chrisssj2 View Post
So which version should I be using?
430.86 has been working very well for me. 430.53 fixed that bug.
madVR options explained
Old 30th May 2019, 04:44   #56382  |  Link
ka
Hey guys on my laptop when I use madvr and MPC-HC some videos (not all of them, but most of the mkv's) became colors washed out in fullscreen. (btw this does not happen on my external monitor)
ka is offline   Reply With Quote
Old 30th May 2019, 07:40   #56383  |  Link
Charky
Washed out colors (or crushed blacks) usually come from a wrong 0-255/16-235 setup.
Check your driver and/or monitor settings.
Charky
"Rule #1 : If it works, don't change anything."
Charky is offline   Reply With Quote
Old 30th May 2019, 08:32   #56384  |  Link
Asmodian
On your laptop madVR should be set to output full range 0-255, but it only happens in fullscreen? If that was the issue it should not be only when fullscreen. Any more details, like OS, GPU, driver, laptop model, etc?
Old 30th May 2019, 13:14   #56385  |  Link
baker99uk
I'm wondering if there is any disadvantage to using CUVID in the LAV video filter? Is D3D11 better quality? The reaaon I ask is that D3D11 drops lots of frames at default settings in madVR, if I reduce everything I can just about get it working but then I get random artifacts, madVR doesn't report any presentation glitches though. With CUVID everything is perfect even with higher settings in madVR. I also noice huge cpu usage using D3D11 , I get similar results with dxva2 native or copy back to D3D11.
I'm trying to watch 4K HDR content in 3840 × 2160 resolution, 23Hz, RGB Full, 12 bit, using a 6GB Nvidia 1060, CPU is i5 6400, 16 GB of RAM, latest Nvidia drivers, I've tried both the standard LAV filters and the nightly builds. This is on MPC-HC. TV is LG C6.
If there's no negative effect to using CUVID I'll carry on using it, I just can't seem to find the answer searching around.
baker99uk is offline   Reply With Quote
Old 30th May 2019, 13:24   #56386  |  Link
el Filou
el Filou's Avatar
CUVID puts the GPU into higher performance state. Maybe that's why you get fewer dropped frames than with DXVA but it shouldn't happen.
Check that the power saving mode in NVIDIA control panel is on Adaptive.
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 30th May 2019, 13:27   #56387  |  Link
Originally Posted by garson View Post
Hello everyone.
Occasionally I am experiencing stuttering in moving scenes, but no dropped frames or presentation glitches.
How can I track what is causing this?
I enabled full screen exclusive mode, looks like it is helping a bit but still I see it.
Does FSE still makes sense?
I am using madVR v0.92.17 with latest MPC-HC on Windows 10 64 bit.
maybe start with a screen of the OSD.
Old 30th May 2019, 13:35   #56388  |  Link
clsid
CUVID puts your GPU in high performance mode (always highest clock speed). This is the only 'disadvantage', but only if your care about power consumption. Quality is identical to other decoders.
Adjust your NVIDIA settings to use "Adaptive" power mode. By default it uses "Optimal" which give bad performance.
If to other hardware decoders give high CPU, then they are probably not working correctly. Perhaps you have multiple GPUs? In that case, DXVA2/D3D11 have option to select the correct GPU.
Old 30th May 2019, 13:41   #56389  |  Link
clsid
Already using those ssettings.
Though I dont see a prefer nvidia on optimus setting.
Anyway these settings make 0 difference appearently.
The NVIDIA control panel doesn't show all options. The tool in the my download link does show it. That specific option is only relevant for Optimus laptops.
The included profile applies specifically to MPC and doesn't touch the global settings.
Old 30th May 2019, 14:56   #56390  |  Link
baker99uk
After a bit more digging it seems external LAV filters are only using video accelleration when CUVID is enabled, the internal filters with MPC-HC do all use video acceleration but of course there's no D3D 11 option. I'm guessing this is a question for the LAV forum rather than here.
Old 30th May 2019, 15:52   #56391  |  Link
baker99uk
For anyone else with the same issue - Using LAV 0.71 allows D3D11 hardware acceleration for me, any newer versions break it, also the adaptive power setting helps too as suggested above.
Old 30th May 2019, 17:42   #56392  |  Link
nevcairiel
Which OS are you on? There is no reason D3D11 should not work, it works for many other users just fine.
Would you report this in the LAV thread with all hardware, OS and video details?
nevcairiel is online now   Reply With Quote
Old 30th May 2019, 18:02   #56393  |  Link
Daicon
Originally Posted by Daicon View Post
The only option in Kodi to use MADVR with HDR goes through Kodi DSPlayer ???
There is no other?
anyy?
Daicon is offline   Reply With Quote
Old 30th May 2019, 18:04   #56394  |  Link
baker99uk
Will do, have been doing various tests all day so will try to do a thorough report in a bit
Old 30th May 2019, 20:57   #56395  |  Link
mclingo
anyy?
the only other way to do it is use kodi with a madvr supported external player like mpc-be, might as well just use kodi ds, its old but it still works fine.
OLED EF950-YAMAHA RX-V685-Win101809-4K 444 RGB 60hz-AMD RX580 19.9.2
KODI DS - MAD/LAV 92.14/0.74.1 - 3D / DIRECT3D11 / MADVR 10bit
Old 30th May 2019, 23:39   #56396  |  Link
ka
Intel HD 630, RTX 2080, GE75 Raider 8SG, Windows 10 1809.
Only some mkvs does that on laptop monitor when fullscreen. Everything is fine on external monitor.
Old 31st May 2019, 00:17   #56397  |  Link
garson
Sure, here it is. I think watching full hd (on full hd screen) I don't see this issue, but HD and SD I occasionaly see this.
Screenshot is 720p movie.
garson is offline   Reply With Quote
Old 31st May 2019, 01:37   #56398  |  Link
ryrynz
ryrynz's Avatar
Asmodian, how does HD upscaled to 1440P @ 120hz Smooth Motion look? Also is 4K worth downscaling with SSIM 2D to that res for 120hz SM? Just curious..
Old 31st May 2019, 02:00   #56399  |  Link
grendelrt
I have a weird issue. I used the report 2020 to display option to do some testing, and now even when I am on the desktop and in SDR on 709 material, my display is still getting reported BT2020. If I switch sources to my Oppo player it clears, but no matter what I do now on my computer it is stuck sending the BT2020 flag. Is there any way to clear this?
Edit: A full DDU uninstall of the drivers seemed to have fixed it. Isnt that option supposed to work as a toggle though? If I uncheck it, shouldnt it turn that flag off that nvidia is sending?
grendelrt is offline   Reply With Quote
Old 31st May 2019, 04:00   #56400  |  Link
is this screen pause? the OSD show very odd numbers.
