Old 31st March 2019, 20:37   #55601  |  Link
ryrynz
ryrynz's Avatar
Have you tried changing v-sync to on with the latest driver? That's apparently is the cause of the stuttering.
Old 31st March 2019, 21:13   #55602  |  Link
el Filou
el Filou's Avatar
If you want to keep the same Windows version for a long time (how long exactly?) but also upgrade to a more recent graphics card later, be aware that later hardware may need a minimum Windows 10 version to work. For example GeForce 20 series released 09/2018 need Windows 1709 minimum someone using LTSC 2016 would be out of luck. An hypothetical GeForce 21 or 22 series may or may not work on Windows LTSC 2019.
If I increase this [queues] to 32/16 my fan speed is now 20% my clocks are higher, GPU usage is lower but predicted watts are almost twice that of the standard queues.
That's interesting. My clocks are basically the same with 16/8 and 32/16, but my card is passively cooled and lower power so maybe the power management is different.
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 31st March 2019, 23:43   #55603  |  Link
katodevin
Yep, Vsync is set to on. Power is set to prefer max performance.
katodevin is offline   Reply With Quote
Old 31st March 2019, 23:49   #55604  |  Link
TheProfosist
TheProfosist's Avatar
just based on my own experience of not having fixed it yet do you have HDR enabled or are playing back HDR content? This seems to be my sticking point at the moment.
Right now I'm running 419.67 with an RTX2060
TheProfosist is offline   Reply With Quote
Old 1st April 2019, 00:19   #55605  |  Link
Siso
Siso's Avatar
Originally Posted by chros View Post
385.28, I managed to screw it up, sorry.
No problem
Old 1st April 2019, 08:18   #55606  |  Link
katodevin
Windows HDR is off. I'm using MPC-BE and MadVR to pass through HDR to my LG C8. Worked perfect before I upgraded to this 1660 GTX. I've tried both 419.67 and 419.35 (the only 2 drivers that support the 1660 at this point in time). They both have huge stuttering issues. It is a bit strange though, when I initially installed .35 and enabled vsync in Nvidia control panel, everything seemed fine. After a couple of reboots and various video files, the issues came back. Really frustrating!
Old 1st April 2019, 09:47   #55607  |  Link
Limberjork
Hoping you guys can help me get deinterlacing working better on my setup. I just ripped my Buffy the Vampire Slayer season 1 NTSC DVDs to MKV files (no re-encoding of video or audio) with MakeMKV and I'm trying to play them back with MPC-HC and madVR (using MPC-HC's internal LAV filters). I don't have much experience at all playing back interlaced content - it's 2019, after all - so bear with me.
My first problem is that I can see a lot of combing artifacts in certain spots, typically in frames with motion that come immediately after a cut: Episode 7 01:00.277, Episode 11 00:11.713.
My second problem is that deinterlacing doesn't get activated on 3 out of the 12 episodes according to marVR's OSD. These happen to be the 3 episodes that start with a cold open (straight to the first scene of the episode), rather than the usual intro sequence. If I switch the deinterlacing setting in madVR from "if in doubt, deactivate deinterlacing" to "if in doubt, activate deinterlacing," then deinterlacing is activated on all 12 episodes.
Sample clips: First 15 seconds of episode 1, Clip from episode 7 (I see a lot of combing when the guy lights the lighter)
One last thing that I've noticed is that in every sequence except for the intro sequence, I get a ton of repeated frames. In fact, when I step through the video frame by frame, every frame is repeated once.
LAV Video settings
madVR deinterlacing settings
Limberjork is offline   Reply With Quote
Old 1st April 2019, 09:51   #55608  |  Link
Siso
Siso's Avatar
So the best driver for pascal cards is 385.28, also works good with madvr? I'm with 382.53, thinking about goin' for 385.28.
Old 1st April 2019, 10:15   #55609  |  Link
chros
chros's Avatar
Are you sure about this? I haven't seen any restrictions with 2xxx series (note, I don't have such card).
That's the latest one that doesn't brake lot of stuff , not necessarily the best. I wouldn't upgrade if everything works for you now, until you are bored
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
Old 1st April 2019, 10:23   #55610  |  Link
Siso
Siso's Avatar
Well, I don't have any issues with the version I'm using, so I guess I'll stick to 382.53
Old 1st April 2019, 11:21   #55611  |  Link
ryrynz
ryrynz's Avatar
He is correct.
Old 1st April 2019, 12:01   #55612  |  Link
DMU
Originally Posted by Limberjork View Post
My first problem is that I can see a lot of combing artifacts in certain spots...
Try to use ivtc (force film mode). It will not completely solve problems with combing artifacts in certain spots, but will solve the problem with the duplication of frames.
DMU is offline   Reply With Quote
Old 1st April 2019, 12:53   #55613  |  Link
Grimsdyke
Originally Posted by DMU View Post
... , but will solve the problem with the duplication of frames.
It's been a while but IIRC what I did to avoid the repeated frames issue when watching old US-DVDs was to choose 'DXVA2 native' in LAV Videodecoder.
Grimsdyke is offline   Reply With Quote
Old 1st April 2019, 14:11   #55614  |  Link
Limberjork
Yeah looks like this is the answer. I didn't realize that IVTC can't be performed in the automatic mode; I thought the deinterlacer would pick up on the need for it automatically.
Old 1st April 2019, 18:51   #55615  |  Link
seiyafan
Hi everyone,
I have made an optimized NVIDIA profile for MPC-HC/BE. Might be helpful for those who struggle with the configuration. Try it out.
This is NVIDIA Profle Inspector tool with a profile file and a .bat to import that profile.
Download
Most important settings it uses:
Power management mode = Adaptive
VSync = on
GSync = off
SLI = off
Prefer NVIDIA on Optimus systems
Thanks, your profile and 419.35 GRD fixed the issue on my 1660.
seiyafan is offline   Reply With Quote
Old 2nd April 2019, 09:36   #55616  |  Link
ryrynz
ryrynz's Avatar
So it would seem like the VSync setting isn't being respected after upgrading or with certain Nvidia driver versions..
Old 2nd April 2019, 19:23   #55617  |  Link
jkauff
A clean install will also wipe out any Control Panel settings.
Old 3rd April 2019, 09:54   #55618  |  Link
Sunset1982
I will do a clean installation of my htpc the next days. Any suggestion which windows version i should use as a stable patform?
I have used Windows 10 build 1809 but had random freezes with madvr/kodidsplayer/lavfilters.
I have an amd rx vega 56 gfx card...
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 3rd April 2019, 10:14   #55619  |  Link
Asmodian
Windows 8.1 is still ideal for a madVR box.
madVR options explained
Old 3rd April 2019, 10:20   #55620  |  Link
Sunset1982
Some time ago I read a post from madshi where he wrote some disadvantages of windows 8.1, but I can't find it anymore.
Wasn't there a problem with 10bit hdr and windows 8.1?
