Old 28th March 2019, 20:35   #55561  |  Link
SirMaster
Originally Posted by el Filou View Post
madVR features that don't work with DXVA/D3D11 native are: IVTC; black bars detection.
Are you sure that's really all?
I am certain that for DXVA (Native) vs. DXVA (copy-back) that under devices -> hdr the dropdown called (highlight recovery strength does not work in DXVA (Native), but it does work in DXVA (copy-back).
You are saying it should work in D3D11 Native?
https://i.postimg.cc/K8B4fVWf/hdr.png
Originally Posted by Asmodian View Post
Also the measure frame brightness for HDR tone mapping.
*EDIT* you beat me.
SirMaster is offline   Reply With Quote
Old 28th March 2019, 21:29   #55562  |  Link
el Filou
el Filou's Avatar
Nope, I also thought that before and it may have been the case at some point in the past, but all the HDR features now work with DXVA native. You can check easily with ShowRenderSteps.
Luminance measure has to work because madshi himself recommends D3D11 native for the standalone measurement tool.
Highlights recovery is also easy to check even without ShowRenderSteps because it uses quite a lot of processing power (at least on my GPU )
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 28th March 2019, 21:36   #55563  |  Link
SirMaster
Excellent, thanks! Yes it must have changed somewhere along the line in newer builds than I am originally remembering.
Old 28th March 2019, 23:34   #55564  |  Link
fourbigkids
fourbigkids's Avatar
Hi all.
Having a bit of trouble with judder in certain circumstances. I have two HDMI outputs from my HTPC. One from an Nvidia RTX2060, which goes to a pre-pro and then to the TV, and the other from the on-board Intel 630 video which goes direct to the TV. VLC plays video without judder through either route to the TV. But with MPC-BE and MadVR, judder is present, but only when using the Intel video output. MadVR is set for pretty low performance. I have attached two snips, one for the Nvidia and the other for the Intel. I see that the only difference is in the rendering rate, the Nvidia being three times faster than the Intel. Could this be the cause of the judder? The Nvidia card is new and I hadn't noticed judder on the Intel card beforehand.
Ideally I want to be able to use MPC-BE for both outputs and have the capacity to upscale the many old DVD movie rips we have with MPC-BE, and for MPC-BE to work smoothly with the Intel output.
You might ask why do I need both outputs. Well, my wife prefers minimal engagement with the system. Turn it on and press play - hence Intel straight to the TV. However, I am prefer to enjoy the full surround sound experience and the quality of the MadVR upscaling, even if it requires more action on my part. The only alternative I can see is changing the default player to VLC for my wife and then manually opening files in MPC-BE when I want to watch something.
Any suggestions on how to resolve?
Cheers,
Allan
Nvidia Card:
https://1drv.ms/u/s!Ajkfvd4XPdI2iNx1jOLe-dF0TCtLZQ
Intel Video:
https://1drv.ms/u/s!Ajkfvd4XPdI2iNx2hHmZmg_1Q1T9yg
edit:
It appears that the judder was present because MadVR wasn't able to change the refresh rate to match the source with Windows doing the cloning of the displays (the AVR and the TV). I have resolved this problem by using two outputs on the nvidia GPU, rather than one on the nvidia and the other on the Intel GPU. One goes via the AVR to the TV and the the other goes direct to the TV. This way nvidia controls the 'cloning'. I have set it up in the Nvidia control panel so that the AVR is the source of the clone when both routes are active. When the AVR is switched on I am able to play a video with MPC/MadVR through the AVR to the TV and the refresh rate is able to be switched to match the source, but not HTPC-TV direct. If I turn off the AVR then MPC/MadVR is able to switch the refresh rate HTPC to TV direct. :-) This may be possible in Windows but I haven't checked - very easy to setup in nvidia control panel. Only downside is that I can't play UHD discs on my HTPC but this is a non-issue given that the licencing controls keep screwing things up and I have a BSOD more often than not. It is just not worth the trouble - just bought a Panasonic player for $250, works like a charm.
fourbigkids is offline   Reply With Quote
Old 29th March 2019, 00:14   #55565  |  Link
fourbigkids
Having trouble posting images from url. I'll try again:
Nvidia:
Intel:
Edit
Nah. Screw it. Not working.
Old 29th March 2019, 00:34   #55566  |  Link
Asmodian
How fast is the Intel GPU in ms? What framerate video are you playing?
madVR options explained
Old 29th March 2019, 00:54   #55567  |  Link
fourbigkids
Hi Asmodian. The Average Stats show the Intel GPU rendering at 64.70ms in the video in the links above. It is a 23.976 fps movie in this case, but the judder is common to a range of sources.
Allan
Old 29th March 2019, 01:05   #55568  |  Link
Asmodian
Yes, the Intel GPU is too slow for your settings. A single 23.976 video frame is only displayed for 1000/23.976 = 41.70833 ms. This means you need the average rendering time to be below 41 ms, and there also needs to be some extra so I would target something lower, low enough madVR stops reporting dropped frames. Higher frame rates need to be rendered even faster.
Old 29th March 2019, 02:06   #55569  |  Link
fourbigkids
Thanks Asmodian. I thought that might be the case. Looks like I am going to have to run two players, one for each GPU. Cheers, Allan
Old 29th March 2019, 05:30   #55570  |  Link
jmone
Originally Posted by Klaus1189 View Post
I just updated that info here:
https://forum.doom9.org/showthread.php?t=176013
419.67 GRD 2019-03-25 stuttering issues
419.67 CRD 2019-03-20 stuttering issues
419.35 GRD 2019-03-05 stuttering issues
419.17 GRD 2019-02-22
418.91 GRD 2019-02-14 NO stuttering issues
Did anyone test 419.17 about the stutter issues?
I have no issues on 419.35 once I turned VSYNC ON.
jmone is offline   Reply With Quote
Old 29th March 2019, 05:59   #55571  |  Link
ryrynz
ryrynz's Avatar
Why are people even changing VSYNC in the control panel? Just use the default 'use the 3d application setting' and be done with it.
Old 29th March 2019, 06:05   #55572  |  Link
that's the issue it doesn't work with application controlled where it should use "on".
Old 29th March 2019, 07:13   #55573  |  Link
ryrynz
ryrynz's Avatar
Would madVR be capable of forcing Vsync?
Old 29th March 2019, 08:21   #55574  |  Link
i don't have a turing card so i can't check this in "detail".
but i'm pretty sure madVR wants vsync to be on so it is "forcing" it but it looks like it is doing something else.
Old 29th March 2019, 09:43   #55575  |  Link
Nicog
I'm facing another issue with MadVR (I suppose it comes from MadVR).
I would like to use the "zoom" function in windows in 2160p (from 100% to 200%).
When I do that, the picture displayed by MadVR is zoomed also of 200% and shrink then to fit to the screen. Conclusion : the native 2160p movie is displayed at 1080p !!! (MadVR OSD shows 2160p->1080p).
Is it normal? Any idea to solve this issue (my config in my signature)?
JRiver 25 in a Custom PC with i7 7700, Nvidia RTX 2070 (Zotac mini), Windows 10 1809, JVC X7900 in a dedicated black room :-)
Nicog is offline   Reply With Quote
Old 29th March 2019, 10:16   #55576  |  Link
if you didn't try that already restart the PC. i had something similar some years ago.
what so ever madVR has no effect on this. madVR only changes the resolution with it's build in display modes and 3D.
Old 29th March 2019, 10:46   #55577  |  Link
jmone
I was getting constant every second stuttering (that madvr was not reporting) with the default 'use the 3d application setting' and changing that to "on" fixes it when using Windowed Mode.
Old 29th March 2019, 11:18   #55578  |  Link
Klaus1189
Thanks, added in AMD, Intel and Nvidia driver issues and last recommended version
Old 29th March 2019, 15:36   #55579  |  Link
SirMaster
Make sure you make it clear that its only no stuttering with v-sync forced ON.
I'm pretty sure there is no stuttering in any driver versions with vsync forced ON.
Old 29th March 2019, 16:22   #55580  |  Link
clsid
Hi everyone,
I have made an optimized NVIDIA profile for MPC-HC/BE. Might be helpful for those who struggle with the configuration. Try it out.
This is NVIDIA Profle Inspector tool with a profile file and a .bat to import that profile.
Download
Most important settings it uses:
Power management mode = Adaptive
VSync = on
GSync = off
SLI = off
Prefer NVIDIA on Optimus systems
