Old 25th January 2019, 23:55   #54481  |  Link
actarusfleed
code do not work
Hi, I've tried to do the same thing on two different PCs...
I've installed only MPC-HC and last official build of Madvr.
I set a code to change automatically profiles but do not works ...
if (deintFps <= 25) and (srcWidth > 1920) "2160p24"
else if (deintFps <= 25) and ((srcWidth <= 1920) and (srcHeight > 1080)) "1080p24"
else if (deintFps > 25) and (srcWidth > 1920) "2160p60"
else if (deintFps > 25) and ((srcWidth <= 1920) and (srcHeight > 1080)) "1080p60"
Surely I've missed something ....
Any help?
thank you
actarusfleed is offline   Reply With Quote
Old 26th January 2019, 00:09   #54482  |  Link
Alexkral
just frame match and let the TV do it.
doing 5/1 instead of 5/2 interpolation is massively better anyway even through i would use neither.
That's unusable because of the input lag, and yes 5/1 is kind of what I'm doing.
Alexkral is offline   Reply With Quote
Old 26th January 2019, 00:46   #54483  |  Link
Asmodian
I think these greater than signs should be less than or equal to signs.
However, I would also rewrite it simpler:
If (deintFps < 26) and ((srcWidth <= 1920) and (srcHeight <= 1080)) "1080p24"
else if ((srcWidth <= 1920) and (srcHeight <= 1080)) "1080p60"
else if (deintFps < 26) "2160p24"
else "2160p60"
Remember, if an If statement validates it doesn't continue to the next statement so you only need to account for content in the next rule that doesn't match an earlier one.
madVR options explained
Asmodian is online now   Reply With Quote
Old 26th January 2019, 04:59   #54484  |  Link
austonrush
Any help?
thank you
I run 9 profiles for my scaling algorithms and below is my profile rules. I only run 4 processing profiles based on sd, hd, fullhd and 4k.
This allows me to max out and also micro adjust for 24fps versus 60fps on each resolution type.
if ((srcHeight <= 540) and (deintFps < 25)) "SD 24fps"
else if ((srcHeight <= 540) or (fileName = "*.avi")) "SD 60fps"
else if ((filename = "*3D*") and (srcHeight <= 720)) "HD 3D"
else if ((srcheight <= 720) or (fileName = "*720p*")) and (deintFps < 30) "HD 24fps"
else if ((srcheight <= 720) or (fileName = "*720p*")) "HD 60fps"
else if ((filename = "*3D*") and (srcheight <= 1080)) "FullHD 3D"
else if ((srcheight <= 1080) or (fileName = "*1080p*")) and(deintFps < 25) "FullHD 24fps"
else if ((srcheight <= 1080) or (fileName = "*1080p*")) "FullHD 60fps"
else if ((srcheight <= 2160) or (fileName = "*2160p*")) and(deintFps < 61) "4k"
If anyone knows a better way to activate a 3d playback profile other than with the filename please let me know!?
austonrush is offline   Reply With Quote
Old 26th January 2019, 13:04   #54485  |  Link
madjock
Any help?
thank you
I am confused, are you saying your profile has not changed the refresh rate ?, as it is a 23.976 file running at 60, you need to setup the refresh rate for that.
Old 26th January 2019, 13:45   #54486  |  Link
mclingo
Originally Posted by tp4tissue View Post
Is there a 10bit 8bit gradient test pattern confirmed to distinguish noticeably in Madvr..
https://forum.doom9.org/showthread.php?t=172128
OLED EF950-YAMAHA RX-V685-Win101809-4K 444 RGB 60hz-AMD RX580 19.9.2
KODI DS - MAD/LAV 92.14/0.74.1 - 3D / DIRECT3D11 / MADVR 10bit
Old 26th January 2019, 18:15   #54487  |  Link
brazen1
I'm hoping you folks can help me edit my profile(s). I like the idea of more madVR control based on FPS @austonrush exampled a couple posts up. (Side note - is FPS the same as Hz and refresh rate in this regard?) 2160p 23/24FPS allows more aggressive settings in Scaling vs 2160p 60FPS for example. Since I don't use a profile separating the two, I use less aggressive settings to meet the demands of 2160p 60FPS but desire to use higher settings for 2160p 23/24 FPS. I'd like this to automate based on a profile. I'd prefer not to add something in a file name to trigger and use metadata instead if possible (as I presently am) but will only if necessary. I'm only interested in separating 2160p 23/24 FPS and 2160p 60 FPS for SCALING at this time but would welcome others. Here are my present profiles:
DISPLAY profile for calibration tab based on BT.2020 vs BT.709
if (HDR) "BT.2020"
else "BT.709"
PROPERTIES profile based on 10-bit vs 8-bit native bitdepth setting (both currently set to 8bit and really not in use at this time but may be in the future)
If (deintFps <= 30) "10-bit"
else "8-bit"
PROCESSING profile based on 2160p, 1080p, 720p, and SD resolutions
if (srcWidth > 1920) "2160p"
else if (srcWidth <= 1920) and (srcHeight > 1080) "2160p"
else if (srcWidth > 1280) and (srcWidth <= 1920) "1080p"
else if (srcWidth <= 1280) and ((srcHeight > 720) and (srcHeight <= 1080)) "1080p"
else if (srcWidth > 960) and (srcWidth <= 1280) "720p"
else if (srcWidth <= 960) and ((srcHeight > 540) and (srcHeight <= 720)) "720p"
else if (srcWidth <= 960) and (srcHeight <= 540) "SD"
SCALING profile based on 2160p,1080p, 720p, and SD resolutions
RENDERING profile based on 3D, 2160p, 1080p, 720p, and SD resolutions
if (3D) "3D"
else if (srcWidth <= 720) and (srcHeight <= 576)"SD"
else if (srcWidth <= 1280) and (srcHeight <= 720)"720p"
else if (srcWidth <= 1920) and (srcHeight <= 1080)"1080p"
else if (srcWidth <= 3840) and (srcHeight <= 2160)"2160p"
*EDIT*
Maybe this will help others? I edited my '2160p' profile to '2160p 24fps' and used more aggressive settings.
I added another profile '2160p 60fps' and retained the old calmer settings.
I edited the SCALING rules to this: If someone knows of something more elegant...
if (srcWidth > 1920) and (deintFps < 25) "2160p 24fps"
else if (srcWidth <= 1920) and (srcHeight > 1080) "2160p 24fps"
else if (srcheight <= 2160) and (deintFps > 59) "2160p 60fps"
Now I can control 2160p 60fps and 24fps separately.
W10 1903 9604GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit
KODI MPC-HC/BE PDVD19 DVDFab 3 & 5
65JS8500 UHD HDR 3D
Old 28th January 2019, 03:16   #54488  |  Link
Oguignant
Oguignant's Avatar
hello, what is the latest version of nvidia drivers that work with madvr + hdr
"To infinity, and beyond!"
Oguignant is offline   Reply With Quote
Old 28th January 2019, 05:16   #54489  |  Link
Klaus1189
https://forum.doom9.org/showthread.php?t=176013
Old 28th January 2019, 06:14   #54490  |  Link
giulianoprs
Little curiosity, in devices / properties I set in the automatic "BIT", according to you is wrong? my tv is a plasma panasonic g20 is 8 bit.
When I look at the OS with a fullHD movie it tells me:
D3D11 fullscreen windowed (10BIT)
h264, 8 bit, 4: 2: 0 -> NV12, 8 bit, 4: 2: 0
do you think it's right or wrong?
giulianoprs is offline   Reply With Quote
Old 28th January 2019, 06:20   #54491  |  Link
technically plasma are 1 bit but as far as i know newer plasma panel except 12 bit which is then dithered.
but what so ever it shouldn't matter for the panel more if the processing can handle that properly and what i hear Panasonic didn't really do a great job back then.
so i recommend to set it to 8 bit just to be save.
Old 28th January 2019, 14:25   #54492  |  Link
Mykola
Have somebody compared scaling capabilities in modern GPU-s? I have found this, but it is three years old: https://github.com/zachsaw/MPDN_Exte...DXVA-HD-Scaler
Mykola is offline   Reply With Quote
Old 28th January 2019, 14:30   #54493  |  Link
madjock
Warners guide has a lot of info on scaling and what is Low/Meds/High, it is not based on GPUs as such but I think it does explain how taxing they all are.
As far as I am aware the newer cards as it the 2070s and the likes are still at such an early stage all these things are based on using 10XX GPUs for the most part.
https://forum.kodi.tv/showthread.php...942#pid2238942
Old 28th January 2019, 16:09   #54494  |  Link
Warner306
This is what it looked like the last time I tried researching this topic. I can't guarantee all settings are accurate and madVR might even tell you what is being used if you select DXVA2:
https://forum.kodi.tv/showthread.php...608#pid1966608
Old 28th January 2019, 16:55   #54495  |  Link
YGPMOLE
In a house of a friend of mine I tried to use madVR with an Nvidia GTX 1070 and we didn't get HDR Tone Mapping switch on a LG OLED C7.
O.S.: Windows 10 x64, HDR off (greyed out, not selectable)
LAV Video setting: Hardware decoding DX3D11 (but I also tried copy-back and Nvidia Cudic).
madVR settings are: HDR passthrough, output 10bit, metadata to the display, fullscreen exclusive.
Driver: the latest (15-01-2019).
The on-screen display shows output DX3D11, P010, 1000nits BT2020->DCPI3.
The same .mkv file played with a Zidoo (chinese mediaplayer) switches the display in HDR mode.
I use AMD, so I didn't know what else do: any suggestion?
Best Regards! Leo!
YGPMOLE is offline   Reply With Quote
Old 28th January 2019, 19:28   #54496  |  Link
brazen1
Try nVidia 385.28 driver.
If Windows HDR switch is greyed out, either Windows build is outdated/corrupt and/or GPU driver is broken.
65JS8500 UHD HDR 3D
Old 29th January 2019, 02:40   #54497  |  Link
tp4tissue
tp4tissue's Avatar
Also, if you got multimonitor, try it with only 1 connected. Sometimes it doesn't detect correctly.
Ghetto | 2500k 5Ghz
Old 29th January 2019, 07:40   #54498  |  Link
mrmojo666
on my system to get HDR autoswitch working, amd requires that bitdepth 10 or 12 bit is setup in driver settings
AMD Ry 1500x - 8GB - RX460 4GB
TV Philips 55pus6501+ Marantz 1608 avr
WIN10(1903) 4K/444RGB
Mediaportal - Mpc-hc
MADVR-D3D11/10bit
mrmojo666 is offline   Reply With Quote
Old 29th January 2019, 09:04   #54499  |  Link
madjock
It is an nVidia card he is using so should be easier as you do not need 10bit or FSE.
@YGPMOLE
The feed is not going through an older AVR is it ?, as if it is only 1.4, then you cannot get HDR to work correctly, try direct from the source to the TV to take things out of the loop.
Old 29th January 2019, 11:57   #54500  |  Link
iSeries
On the TV itself, is HDMI ULTRA HD Deep Color turned on for the HDMI port the PC is connected to?
iSeries is offline   Reply With Quote
