Old 10th August 2018, 09:12   #52021  |  Link
it is doing 4:2:0 -> 4:2:2 -> 4:4:4 with "simple" scaler.
why this is the case well i guess you have to ask madshi.
doing it in 1 shader should be faster if i remember it correctly Shiandow was testing this.
Old 10th August 2018, 10:55   #52022  |  Link
Asmodian
Originally Posted by ajp_anton View Post
"only if there would be motion judder without it..." - Smooth motion is turned off on VFR video, how can madVR think there won't be judder?
madVR makes this decision at startup and will use whatever value for the frame rate it is told by LAV, it doesn't analyze timestamps.
madVR options explained
Old 10th August 2018, 11:35   #52023  |  Link
Weirdo
Originally Posted by thighhighs View Post
You have all Windows 10 focus assist features disabled? It fix "frozen video" for me.
You were right, thanks. It's strange because Focus Assist was supposedly disabled, but problem went away only after unticking all options.
Win 10 Pro x64
Weirdo is offline   Reply With Quote
Old 10th August 2018, 19:20   #52024  |  Link
Asmodian
Yes, focus assist seems oddly behaved. It needs to be completely disabled or it damages performance even if it is not supposed to be doing anything.
Old 10th August 2018, 19:44   #52025  |  Link
Stereodude
Can we get the ability to go negative (below 0) in custom video levels in madVR? For example, being able to go to -16 would fix incorrectly encoded black levels on a laptop or PC system that maps 0 to black and 255 to white.
Stereodude is offline   Reply With Quote
Old 10th August 2018, 20:14   #52026  |  Link
control+alt+shift+i
maybe there is a tag name too
Old 11th August 2018, 04:42   #52027  |  Link
Stereodude
control+alt+shift+i
That affects both ends though right? From my quick test it seems to. I've seen content where the peak white levels are correct, only the blacks are mis-mapped. Hence the request.
Old 11th August 2018, 05:20   #52028  |  Link
Clammerz
Have you tried:
Originally Posted by changelog.txt
* added tag "blacklevel=%value%", value range [-50, +50]
If you CTRL+F for "tag" in the changelog you'll see others that may be of use.
Clammerz is offline   Reply With Quote
Old 12th August 2018, 16:54   #52029  |  Link
oldpainlesskodi
Hi fellows,
I'm sure I am not the only one following progress over on the AVS forum....waiting patiently.
Can anyone else with a HDR set confirm at this stage that madVRhdrTestFinalColor4.zip is producing a picture with far more depth, contrast, and better tone mapping than the latest version (today)? Maybe I am misunderstanding the latest builds in terms of what it is trying to achieve - are the latest builds purely about trying to restore detail, or is Madshi, using the results of Color test builds, and now on to restore details?
Forgive me if it's a stupid question, but on a HDR set, madVRhdrTestFinalColor4.zip is producing the best image of all test HDR to SDR builds to date (100, 100, 100, 75, 50, 25, off, off)
K
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema
oldpainlesskodi is offline   Reply With Quote
Old 12th August 2018, 18:05   #52030  |  Link
KoKlusz
Latest 3 test builds are only making changes to the detail restoration algorithm, the rest of tonemapping pipeline is not affected, as far as i know.
KoKlusz is offline   Reply With Quote
Old 13th August 2018, 01:35   #52031  |  Link
ajp_anton
ajp_anton's Avatar
Originally Posted by e-t172 View Post
The madVR options thread should have the answers to your questions.
I think I got it now, but they are not that well explained in the options panel. Still doesn't address the VFR issue.
But doesn't LAV know about it being VFR? At least mediainfo says it's VFR, so it should be known without even looking at the timestamps?
Old 13th August 2018, 01:52   #52032  |  Link
yes they could go and read the timestamps before starting playback and could choice the refreshrate and if or if not SM should be used.
but this sounds like a lot of work.
just the info if it is VFR is not enough. the first frame could be reported with a shorter frame time and the rest is CFR but the file would still be reported back as VFR. this is a real "problem" BTW. but real VFR is really uncommon.
you could add a tag to force SM. sorry i don't know the name of them but pretty sure there is one.
Old 13th August 2018, 06:56   #52033  |  Link
oldpainlesskodi
Ok thanks, that's what I was hoping for.
EDIT:
Just re-read what you said. Not sure the latest version is using the same tonemapping as madVRhdrTestFinalColor4.zip, as they look very different on my setup, to my eyes anyway.
Old 13th August 2018, 17:52   #52034  |  Link
that's messed up i try may r9 270 later.
edit: and with later i mean days i guess at week end.
sorry my r9 270 is working like a charm.
but my windows has a lot of changed settings to make it usable.
Old 13th August 2018, 19:50   #52035  |  Link
kostik
Previously D3D11 fullscreen windowed was showing only 8 bit but now , OSD shows me D3D11 fullscreen windowed (10 bit) .
Both in HDR and SDR modes.
I am not sure whether nvidia 398.98 hotfix fixed it or the new Win10 18214 build or maybe the latest madVR test build.
kostik is offline   Reply With Quote
Old 13th August 2018, 21:25   #52036  |  Link
KoKlusz
EDIT:
Well, I wrote that just minutes before latest version dropped, which did changed how madVR reads metadata.
Old 13th August 2018, 22:04   #52037  |  Link
Siso
Soul Seeker
Siso's Avatar
Where is this thread in the AVS forum?
Old 13th August 2018, 22:19   #52038  |  Link
videoh
Useful n00b
https://www.avsforum.com/forum/24-di...projector.html
Old 14th August 2018, 00:05   #52039  |  Link
ryrynz
ryrynz's Avatar
Test build fixed it. Surprised madshi didn't release an interim build or quick fix release here, he's pretty dedicated to avsforum and playing with HDR right now so I guess that's why.
Old 14th August 2018, 03:43   #52040  |  Link
ajp_anton
ajp_anton's Avatar
If there's a lot of "fake" VFR, then that's a problem for sure. But VFR isn't as rare as you think. All of my recent smartphones record VFR video. Sometimes frames are skipped or delayed for whatever reasons... CPU throttling because of overheating, background tasks, who knows. Learned it after many hours of pulling my hair when trying to re-encode my videos using tools that assume CFR.
