Old 4th January 2018, 22:42   #48061  |  Link
mclingo
Originally Posted by xabregas View Post
Is the rx 550 you have able to decode 4k hevc 10 bits UHDBlurays without stressing the cpu??
What chroma algo can it handle while playing a 4k movie? Bicubic only or it can go to jinc?
Maybe the RX 560 thats 20$ more will handle a bit more??
I can have a rx560 for about $125 nearby... And then when nvidia volta cards comes i might upgrade or not. Rx 560 must be better than rx550 right?
Here is my setup
3rd gen I7
8 gig ram DDR3
250 gig SSD
RX 550
LG OLED EF950 4k
MADVR:
image upscale - NGU sharp medium
chroma upscale - Lanzos
I upscale everything to 2160p on PC.
PC:
desktop 3840x2160p
10 bit 4:2:0
Everything plays fine, no real tax on CPU, I could possibly push it harder with more tweaking but I decided I like the picture quality i'm getting.
I agree the 560 is a better choice, money was super tight at the time I bought this, I could use my GTX 1050 instead but I find my RX for stable on my particular setup, others would disagree and do frequently .
What I would say is that if you arent really into 3D then there really is no point getting an AMD card as it still requires FSE, if you are only playing 2D 4K movies go green.
Old 5th January 2018, 00:27   #48062  |  Link
Baffin what?? It doesnt say. Its the MSI RADEON RX 560 AERO ITX 4G OC model.
that the reason why this is issue is criminal in my eyes. a normal user can't see the difference on the name.
the MSI RADEON RX 560 AERO ITX is PCIe 16 with only 8 lanes.
but i don't see a msi version with buffin XT chip.
think about a 1050 ti if you want to use NGU about 2x speed for NGU.
@mclingo
i just used d3d11 FSE and 3D without any problem on windows fall update.
Last edited by huhn; 5th January 2018 at 00:31. Reason: it's an XT not XL the naming is killing me...
Old 5th January 2018, 00:30   #48063  |  Link
Asmodian
There are two 560s out there, one is the original one with 16 CUs and recently some have 14 CUs. There seems to be no difference between the two based on the box while one is 12.5% slower.
Based on the newegg page for it the MSI RADEON RX 560 AERO ITX 4G OC has the full 16 CUs for 1024 stream processors (instead of the lower 896) but it is hard to verify.
edit: I agree with huhn, NGU doesn't run well on polaris.
madVR options explained
Old 5th January 2018, 08:26   #48064  |  Link
PCI Express x16 (Uses x8) this should already disqualify this RX 560
Old 5th January 2018, 10:01   #48065  |  Link
Asmodian
True, but you have to be careful for more than just that when selecting RX 560s, they are hard cards to shop for today.
Old 5th January 2018, 10:42   #48066  |  Link
mclingo
well I found that NGU iage upscale was almost identical for me on my RX550 vs 1050, neither card could do more than NGU sharp medium without glitchy playback kon 4k and 3d MVC stuff, 2D 1080p stuff was fine, I could ramp that up to NGU high on both cards, there must be large difference in processing requirments between medium and high which neither card can meet.
@huhn - 3D works for me fine when I drop my PC into 1080p mode before starting KODI DS or MPC, ive created a script to do this. 3D always plays fine with D3D/FSE, the problem occurs when you stop the movie, one of three things will happen, it will either:
1. crash my PC (this happens far less with 17.10.2 ATI driver).
2. drop my HDMI connection completely, i have to turn my TV and reciever off to renegotiate, devcon reset doesnt always work so this is a pain.
3. It works fine.
There is a new ATI drivers coming soon, mainly has DX9 fixes but I'll see how stable that is with 3D.
As my system currently stands I have zero issues, it hasnt crashed for ages and all my movies play and stop fine with the above caveats, I can live with this for now.
Old 5th January 2018, 10:44   #48067  |  Link
ashlar42
Originally Posted by d3rd3vil View Post
Still no Dolby Vision passthrough
I've reported you. This is annoying to the extreme. Everybody here would love to have DV support but it's already been explained multiple times why that currently is not possible. Deal with it.
Old 5th January 2018, 10:44   #48068  |  Link
mclingo
do we not think full blown gaming cards are a bit of an overkilll for a HTPC, obviously if you are gaming as well then you need it but if you are running a 24/7 HTPC server on a budget the 1030/RX550 are the best options if your content is already mainly bluray and 4k quality.
Old 5th January 2018, 11:23   #48069  |  Link
because you should have 4GB vram for 4K playbacl(netflix needs 3 GB) so a card is already close to 100 bucks and the 550 is not worth it money it cost basicly the same as a 560.
idle power consumption is pretty much the same any way so no there is no reason to get a 550 ever.
Old 5th January 2018, 11:31   #48070  |  Link
[QUOTE=mclingo;1829380]well I found that NGU iage upscale was almost identical for me on my RX550 vs 1050, neither card could do more than NGU sharp medium without glitchy playback kon 4k and 3d MVC stuff, 2D 1080p stuff was fine, I could ramp that up to NGU high on both cards, there must be large difference in processing requirments between medium and high which neither card can meet.
3. It works fine.
i don't have to do anything to get anything running correctly what so ever. so don't assume this is a general issue.
1. so your system is again solid crashes and you change your option every couple days about this topic sorry but what?
2. had the problem to switching to nvidia fixed the problem and unlike other people i contacted AMD about this.
and i was talking about a 1050 TI. the 1050 is a 2 GB card.
Old 5th January 2018, 11:48   #48071  |  Link
d3rd3vil
NOTHING is more important than having the first software solution for DV worldwide, nothing! Especially not these extremely small improvements to the filters.
d3rd3vil is offline   Reply With Quote
Old 5th January 2018, 11:57   #48072  |  Link
mclingo
what is your problem exactly?, you've been told its not coming any time soon, if at all, deal with it.
Old 5th January 2018, 12:23   #48073  |  Link
v0lt
the 1060 is a 2 GB card.
GTX 1060 has 3 or 6 GB of video memory.
v0lt is offline   Reply With Quote
Old 5th January 2018, 12:28   #48074  |  Link
should have been 1050 my mistake will fix it.
Old 5th January 2018, 12:34   #48075  |  Link
strumf666
Feel free to develop it...
strumf666 is offline   Reply With Quote
Old 5th January 2018, 12:35   #48076  |  Link
Neo-XP
Neo-XP's Avatar
Reported for spam.
Neo-XP is offline   Reply With Quote
Old 5th January 2018, 13:02   #48077  |  Link
d3rd3vil
Well thats going to be difficult unfortunately
Old 5th January 2018, 13:09   #48078  |  Link
mclingo
[QUOTE=huhn;1829388]
Have you got nothing better to do than pick apart everything I say??, just let it go for goodness sake.
Old 5th January 2018, 13:15   #48079  |  Link
so you post stuff in the hope it get's ignored?
Old 5th January 2018, 13:26   #48080  |  Link
xabregas
Anything i should know about different models of 1050 ti or thats just a rx 560 thing??
xabregas is offline   Reply With Quote
