1st December 2016, 21:31 | #41082 | Link | ||||
Edit* spoke to soon. I tested going in to standby manually several times and thought it was fixed, however again when I left my computer with video paused in mpc hc and madvr it bsod and rebooted with ntoskrnl.exe VIDEO_SCHEDULER_INTERNAL_ERROR All of my BSODs seem to be related to 3 things causing it watchdog.sys nviddmkm.sys ntoskrnl.exe all are VIDEO_SCHEDULER_INTERNAL_ERROR i'm starting to wonder if it is driver related. Quote:
[s]I'm not sure in my case it is a driver related problem though because reducing my memory frequency seems to have fixed it (so far)[/s] turns out despite testing it doesn't help if I leave my computer. Seemed to work ok going in and out of standby manually though. Quote:
1st December 2016, 21:37 | #41083 | Link |
Your source is very obviously not larger than 1440p. You shouldn't compare downscales with it, unless you're using nnedi3 or ngu.
Edit: Didn't catch this at first, but you're using the algorithms to *upscale* according to the OSD. Bicubic 150 shouldn't be used to upscale, ever. It probably shouldn't even be selectable in madvr. Of course bicubic 150 looks like garbage on upscale. Last edited by har3inger; 1st December 2016 at 23:12. |
2nd December 2016, 03:45 | #41085 | Link |
Hi, I'm still getting a bug on the latest few versions where screenshots taken in MPC-HC just result in a white garbled mess. The only workaround is to scale the video first.
I'm using a GTX 1060, but it's been constant among driver versions also. |
2nd December 2016, 06:53 | #41086 | Link |
May I ask whether it will produce a better quality image if I use
-NGU-high chroma for upscaling to produce a 1080p image then use an AV-receiver to upscale it to 4K, or -use Catmull-Rom for chroma upscaling and NGU-low for luma doubling to upscale a 1080p image to 4K? I do not have a 4K monitor at the moment but I plan to get one in the near future but my GPU isn't quite powerful enough to use anything higher than NGU-low for luma doubling to upscale a 1080p image to 4K, so which is a better option? |
2nd December 2016, 18:23 | #41088 | Link |
For those interested, Kodi DSPlayer has been updated to the latest version of Kodi (v17) and is now compatible with the new settings dialogs.
This is a surprise release. I'm not sure if it will continue to have support in the future.
2nd December 2016, 18:25 | #41089 | Link |
Feedback on NGU Low:
NGU low is great in itself. I actually like its lesser sharpness as compared to the higher versions of NGU. I tend to get distracted by the disproportion that NGU high and NGU very high create in the image in terms of definition of the edges and the texture. Even “soften edges” doesn’t help much there. NGU low is better in that regard. The performance is great too. |
2nd December 2016, 18:57 | #41090 | Link |
I'm sorry for bothering everyone with my petty problem, but what could be the cause of madVR not detecting any display device at all? I've noticed that madVR stopped switching frequencies, then I've noticed that the display that I was using isn't marked as active (bold) in madVR. Then I deleted all devices from the list. Tries resetting to defaults, installing/uninstalling madVR, checked my computer for any unnecessary codecs to no avail. The list is now still empty under "Devices" in madVR.
Log: https: //yadi .sk/d/6J1PmbAN3235Ek (sorry for spaces, won't let me post this otherwise) I know it's completely off-topic, but I can't connect BlueSkyFRC filter with the playback chain. What's the standard troubleshooting procedure in that case? |
2nd December 2016, 23:27 | #41091 | Link |
It's a shame that NGU isn't scalable and just doubles, requiring huge resources to downscale back to native resolution. If that could be changed, it would actually be useable for all content and not just content that needs to be doubled.
1080p->1440p uses a ton of GPU resources, so much so that I've decided against using it as it causes my GPU to get rather hot and the fans are just too loud to enjoy the movie. Guess I'll stick with ReconSoft for Chroma and Jinc for all my scaling needs until something better comes along. |
3rd December 2016, 01:15 | #41094 | Link |
@Warner306 Wow this is really good news even if aracnoz doesn't continue to support it. Maybe he will release an update for major Kodi release.
On topic: NGU is working nicely with my Nvidia 1070. Thank you madshi for this awesome algo. I have a Panasonic plasma TV and NGU doesn't seem overly sharp with very high setting. I mostly watch HD movies and tv series, not much anime. Like others I have some low quality SD content and I have to use softcubic for them to hide the compression artifact, NGU is not suitable for them. Some thing to mask the compression artifact would be much appreciated. |
3rd December 2016, 01:53 | #41098 | Link |
Excellent. Thank you for the quick response. I can normally just get the answers by searching the forum, but it currently seems to be glitching out and throwing 500 errors on half of the pages I look at (in addition to being upset with quote attempts, as madshi mentioned).
3rd December 2016, 06:59 | #41100 | Link |
It is a custom filter.
madVR options explained |
