Old 30th November 2016, 11:33   #41021  |  Link
aufkrawall
Drivers are buggy enough even without multi-GPU.
Old 30th November 2016, 12:03   #41022  |  Link
thighhighs
Why it should be buggy? SLI (i use nvidia) in old games work fine with new drivers. I dont think that possible problems worse vs todays useless second gpu and negative scaling. But if SLI can boost madvr performance it will be great.
edit: I read some posts about multi-gpu here, but i don't understand, madshi don't want introduce it or it just impossible.
thighhighs is offline   Reply With Quote
Old 30th November 2016, 12:19   #41023  |  Link
fedpul
Hi guys. I have a challenge for you. You must download them and compare them in fullscreen and try to identify which Option goes with the right settings. After some time I will be posting the results.
This is the link: http://imgur.com/a/zmRYh
Movie Resolution: 720x480
Output Resolution: 1920x1080
In both options I just doubled resolution once and only in Luma, so downscaling algo is not relevant. So this test is basically to see if you are able to see differences after doubling between Jinc AR and Bicubic 60 AR.
One of the options is with 0.91.1. Settings:
Remove Banding: Medium/High
Chroma: NGU High
Luma Doubling: NGU High
Image Upscaling: Jinc AR
Downscaling: Not relevant.
Add grain and Soften Edges at 1
The other is with 0.91.3 version. Settings:
Chroma: NGU Very High
Luma Doubling: NGU Very High (all auto)
fedpul is offline   Reply With Quote
Old 30th November 2016, 12:21   #41024  |  Link
ashlar42
I thought it was due to PotPlayer that I sometimes got a black screen for a second or two when closing it but creating a "madVR\DontRenderAfterStop" empty folder fixed it as far as I can tell. Prolly unrelated to your problem, though as I always was able to at least open the taskmanager and kill PotP.
What's this option? I've never seen it mentioned before.
Old 30th November 2016, 12:31   #41025  |  Link
Backflash
Are you trying to say option 2 is jinc?
though that aliasing on the hat, option 2 looks better to me.
Backflash is offline   Reply With Quote
Old 30th November 2016, 12:32   #41026  |  Link
Dodgexander
I tried with mpc and evr and it doesn't happen but I think that's because the PC just doesn't go to sleep when using evr.
With zoom player and MadVR I disabled the screen saver and power saving prevention and it doesn't sleep.
So why is mpc hc sleeping with paused playback with madVR and not with evr? Why does it bsod even if it does?
Sent from my Nexus 5 using Tapatalk
Dodgexander is offline   Reply With Quote
Old 30th November 2016, 12:33   #41027  |  Link
pirlouy
_
@thighhighs:SLI/crosfire is complicated for developers:
http://www.gamedev.net/topic/666419-.../#entry5215019
Multi GPU (SLI/CrossfireX) is fucking complicated. You cannot begin to conceive of the number of failure cases that are involved until you see them in person
Windows 10 x64; 1080p 60" TV, GTX 750; mpv or madVR+LAV Filters+MPC-BE
Old 30th November 2016, 12:39   #41028  |  Link
fedpul
I won't tell you know. As I said I will post the results later. Just remember what options you pick.
Enviado desde mi MI 4LTE mediante Tapatalk
Old 30th November 2016, 13:13   #41029  |  Link
omarank
Looks like the image in Option 1 (u2xyyDQ.png) is the one scaled with Jinc after NGU doubling. I believe though this kind of challenge would be more fair for movie content and not anime content.
omarank is offline   Reply With Quote
Old 30th November 2016, 13:29   #41030  |  Link
Xaurus
Ok so I've jumped onto the latest madvr with this new NGU scaler (which is excellent), but I must have missed something about the change of all the settings. Where did image doubling go? I understand that the settings dialogues have been changed but I can't find any info from madshi in his latest updates in this thread.
My point is, I find the new settings kind of confusing, that's all. Especially with regards to the image doubling.
SETUP: Win 10, MPC-HC, LAV, MadVR
HARDWARE: Corsair 400Q | Intel Xeon E3-1260L v5 | Noctua NH-U9S | SuperMicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1060 | EVGA G2 750
Xaurus is offline   Reply With Quote
Old 30th November 2016, 13:39   #41031  |  Link
fedpul
This weekend I will be posting the results, and I will upload the same challenge but with a movie instead of anime, the next challenge will last one Week, from one weekend to another.
Old 30th November 2016, 13:50   #41032  |  Link
seiyafan
Doubling and upscaling have merged into one. So in upscaling if you choose NGU or NNEDI3 it's doubling.
seiyafan is offline   Reply With Quote
Old 30th November 2016, 16:12   #41033  |  Link
cork_OS
cork_OS's Avatar
Agreed, it's a bit more focused/sharp.
I'm infected with poor sources.
cork_OS is offline   Reply With Quote
Old 30th November 2016, 16:30   #41034  |  Link
kalston
Originally Posted by thighhighs View Post
People talk about g-sync here, but what about another game technology - multi-gpu support? Because some users now have two gpu's or dual gpu like 295x2 and for madvr it completely useless or negative. I hope madvr can support SLI\CF in future.
Multi-GPU is a complicated mess and everyone is giving up on it for a reason - game devs and AMD/nvidia are all dropping the ball. Only DX12 could save it but that requires extra work (and training) for the game/app developers. I think only ONE game has dx12 multi GPU support as of right now (the last Deus EX IIRC? and that's not a really well optimized game to begin with).
Just look at how few recent releases support multi-GPU and how bad it is most of the time when they actually do. Poor scaling, bugs, (micro)stuttering etc...
This is even more ridiculous than asking to support VRR for video playback IMO.
kalston is offline   Reply With Quote
Old 30th November 2016, 16:39   #41035  |  Link
ROKUGAN
ROKUGAN's Avatar
Originally Posted by Mistery 73 View Post
a greeting to all of you I need your advice on what video card to buy using madVR in 4k ... I was focused on this ZOTAC GeForce 1080 GTX AMP 8GB Extreme Edition .. accept any advice .. thanks
I can vouch for that card as it´s the same I have in my 4K setup. It comes with an excellent cooler (average temp 65C) and high frequencies out of the box (typically 2050-2100 Mhz).
Having said that:
- All GTX 1080 models perform more or less the same, with a 100-150 Mhz max variance depending on the quality of the cooler (Pascal is pretty temp sensitive). If you´re not also gaming, just buy the cheapest version you can find. Games @ 4K will stress the card much further than madvr.
- A 1060, 1070 or any other card will work as well in 4K, they will be just somewhat slower in rendering time. It all depends on how important is to you to crank up the quality settings in madvr. I had a 980ti previously (= 1070) in the same 4K setup and run without problems. I wouldn´t upgrade only for madvr. I would do it if you´re going to game in 4K as well.
- If money is not a factor, wait until 1Q'17 and buy instead a 1080Ti, which will be around 25-30% faster than the 1080. Expected to be a 850-900$ card, though.
ROKUGAN is offline   Reply With Quote
Old 30th November 2016, 17:52   #41036  |  Link
Neo-XP
Neo-XP's Avatar
If you choose to use NGU for luma doubling (and you will use it, because it is excellent), you won't be able to select the algorithms that you desire for chroma upscaling and luma upscaling/downscaling anymore, to use after the luma doubling.
For instance, NGU can't be used to upscale 720p to UHD with my config anymore, because of the rendering times of the forced algorithms to have approximately the same quality. But you can use the v0.91.1 version to pick the algorithms that you want to fine-tune the image quality vs rendering times for your configuration.
I have a perfect result with those with my little 970 GTX :
chroma upscaling : super-xbr - sharpness: 150 (only NNEDI3 and NGU give better results, but rendering times are awful)
image downscaling : Catmull-Rom (if you want soft) or Lanczos 3 (if you want sharp) [both AR + LL], but I prefer sharp
image doubling : double luma resolution - 2x supersampling - NGU, medium quality
image upscaling : Lanczos 3 AR (sharper than Jinc, and very good to use after luma doubling to upscale anything < FHD to UHD)
upscaling refinement : add grain 3-4 (new refinement, still testing which is best, 4 for now)
artifact removal : reduce banding artifacts (high/high) + reduce ringing artifacts only (reduce dark halos remove too many details)
dithering : Ordered Dithering + use colored noise + change dither for every frame (good rendering times and almost identical to Error Diffusion)
Neo-XP is offline   Reply With Quote
Old 30th November 2016, 18:38   #41037  |  Link
har3inger
I am also noticing far faster rendering on Dx9 compared to dx11--it's the difference between not being able to run NGU high at all and running NGU high comfortably.
Edit: Disregard that. After switching back and forth a couple times, they're the same (faster) speed now. No idea why.
Is there any reason not to use dx9, given that it seems more efficient? I'm guessing it may be faster on older GPU architectures.
I'm using NGU in conjunction with "reduce ringing artifacts". I definitely notice less source haloing and haven't really found enough ugly interactions between the two.
har3inger is offline   Reply With Quote
Old 30th November 2016, 19:25   #41038  |  Link
AngelGraves13
I'm also not a fan of bicubic for downscaling from NGU. Jinc is better
AngelGraves13 is offline   Reply With Quote
Old 30th November 2016, 19:40   #41039  |  Link
pose
Jinc was not available for downscaling in previous builds as well.
pose is offline   Reply With Quote
Old 30th November 2016, 19:40   #41040  |  Link
StinDaWg
For one, 10 bit is only available on D3D11 fullscreen exclusive. I don't know if it makes a huge difference, but IIRC it's supposed to help prevent banding.
StinDaWg is offline   Reply With Quote
