Old 11th November 2016, 22:55   #40061  |  Link
VictorLS
the image is very vivid in general your screen is just washed out.
Agree and I want correct it.
1-16 are NOT suppose to blink.
While playing HV001T01.EVO I've set so by increasing brightness a little - used 16-235 in madVR because with 0-255 I have to increase brightness very much. But nothing changed with trees "in fire".
Did someone try to play Samsung_HDR_Wonderland.ts? May provide screenshot as me?
VictorLS is offline   Reply With Quote
Old 11th November 2016, 23:16   #40062  |  Link
strumf666
@steakhutzeee and @strumf666, please ask LAV questions in the LAV thread, not here. Your questions are widely out of topic here.
Apologies, I was sure I am posting in the LAV thread, but apparently not.
strumf666 is offline   Reply With Quote
Old 11th November 2016, 23:19   #40063  |  Link
sheppaul
Some of you guys didn't like the name "NG1". I'm open for other suggestions. Please feel free to post your ideas. If there's no suggestion that jumps out at me, I'll probably stick with "NG1", though.
Why not "madshi1, madshi2"?
sheppaul is offline   Reply With Quote
Old 11th November 2016, 23:23   #40064  |  Link
Asmodian
There will be several quality/speed levels. NG1 "low" quality will probably have a similar speed to Jinc AR*) or super-xbr*). Or at least that's what I'm aiming at. I still need to test how much I can downscale the algorithm before quality breaks down completely. NG1 "high" quality (which both teasers are made with) will probably have a similar speed to NNEDI3-64*).
Wow very impressive performance targets! I am looking forward to it, like everyone else here.
madVR options explained
Old 11th November 2016, 23:26   #40065  |  Link
VictorLS
Not bad, if sort by timeso but, logically, if sort by quality so must be spaces between methods - may be in the future it will be necessary.
Old 12th November 2016, 07:33   #40066  |  Link
Betroz
Is this for real?
Betroz's Avatar
What about MadFX.
My HTPC : i7 6900K @ 4.2 | nVidia GTX 1080Ti | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
Old 12th November 2016, 08:10   #40067  |  Link
ryrynz
ryrynz's Avatar
MNEDI, MEDI, NGEDI or perhaps just Mad upscale/r
~64 NNEDI3 64 neurons worth of hogging isn't very demanding. I'd totally be up for further improvements if possible with double this requirement.
Old 12th November 2016, 08:10   #40068  |  Link
sauma144
I'm listening to your comments, but I'll reply to all old and new posts only after the new version is released.
Keep it simple!
- mad2X
- madDoubler
- madScale
- madSR
sauma144 is offline   Reply With Quote
Old 12th November 2016, 08:59   #40069  |  Link
it is the creators intent there is nothing to correct.
they just what to show of DCI p3 colors at least this is my guess i wasn't there when it was filmed.
https://abload.de/img/samsung_hdr_wonderlanfds8v.png
EVR can't handle BT2020 it is using BT709 which results in wrong colors.
Old 12th November 2016, 09:44   #40070  |  Link
Sunset1982
madScale NG
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 12th November 2016, 12:14   #40071  |  Link
VictorLS
Many thanks for explanation and screenshot. Now I am sure my system has well settings.
Old 12th November 2016, 13:02   #40072  |  Link
leeperry
Kid for Today
madScale / über-madScale
Old 12th November 2016, 13:30   #40073  |  Link
SmallGoD
MEninX
SmallGoD's Avatar
madVR Direct3D11 + Nvidea FastSync = fullscreen crash.
MPC BE 1.5.0 (build 2101) beta (x64)
P.S. Excuse for bad English. My native language Russian.
SmallGoD is offline   Reply With Quote
Old 12th November 2016, 13:45   #40074  |  Link
DigitalLF
How about Mad1 for the algorithm?
Gigabyte G1.Sniper Z87, I7 4770K (3.5ghz), Gigabyte Radeon 280x, Win8.1 x64, ATI 15.7.1, MPC-HC BE 1.4.6 1478, MadVR v0.90.21, LAV Filters 0.68.1,
XySubFilter 3.1.0.746
DigitalLF is offline   Reply With Quote
Old 12th November 2016, 14:55   #40075  |  Link
pirlouy
_
NG is like HD: already has-been.
Abbreviation can be a solution, but NNEDI is unpronounceable therefore bad choice. :/
GL finding an original name. Double, db, upscaling or up should be part of the name though. MDU (Madshi Double Upscaling) ?
Old 12th November 2016, 15:19   #40076  |  Link
madshi
Should have mentioned: In a future version (not the first) NG1 will probably also be able to directly triple or quadruple the resolution in one step. So anything with "2x" or "double/ing" in the name probably doesn't make too much sense.
Old 12th November 2016, 15:38   #40077  |  Link
sauma144
Why not madX, madXX or madXXX?
Old 12th November 2016, 16:33   #40078  |  Link
MS-DOS
madshi
madVS (video scaler) or could as well be just madVR, as madVR's own high quality algorithm. Not a fan of loud fancy names, personally.
MS-DOS is offline   Reply With Quote
Old 12th November 2016, 17:05   #40079  |  Link
petran79
MPC BE has no such issue, in contrast to Potplayer
petran79 is offline   Reply With Quote
Old 12th November 2016, 17:10   #40080  |  Link
ashlar42
I think madScaler/madScale/madScaleNG would be good names.
