Old 19th May 2016, 16:54   #38081  |  Link
sneaker_ger
Then you probably still have old XySubFilter.
Old 19th May 2016, 16:58   #38082  |  Link
we can't see your screen. it needs admin approval so think about uploading is somewhere.
looks like you are loading an old version.
maybe you have only update the 32 bit version but you are using a 64 bit player or something like that.
huhn is online now   Reply With Quote
Old 19th May 2016, 17:07   #38083  |  Link
Phantasmagorie
I am using MPC v1.7.10 (x86) and when I uninstalled xySubFilter it could not detect it any more so I can only assume it is uninstalling correctly, but when i reinstall it isn't installing the correct version.
Here is the error: http://i.imgur.com/Wn5oB7m.jpg
Here is my xysubFilter: http://i.imgur.com/N0PRkiR.png
EDIT: I wiped all of my filters, uninstalled the player and rebooted. After reinstalling everything I am no longer having the issue, thank you to everyone for your help.
Phantasmagorie is offline   Reply With Quote
Old 19th May 2016, 17:24   #38084  |  Link
XMonarchY
I was never big on subtitles because most of my content was in English, but I recently ripped and watched a foreign film, which came with English (NOT hard-coded) subtitles. I wasn't reading much of anything back when madVR just released subtitles settings because I could care less about them, until now...
I was HOPING madVR could MOVE subtitles to the very bottom black bar (for 21:9 content format, which this foreign film used), but no matter which settings I adjusted, I couldn't move the subtitles anywhere. The subtitles were integrated into the ripped MKV file itself and were not coming from a separate subtitles file. I know the subtitles were not hard-coded because I could turn them off completely...
Questions:
- Can madVR move non-hard-coded subtitles to the bottom of the screen, where black bar is located in 21:9 film content?
- If madVR CAN move the subtitles to the bottom of the screen (on the black bar), then which settings do I need to adjust and which values should I use for those settings?
Slightly off-topic side-questions:
- Can MPC-HC + LAV Filters + ReClock + madVR play films downloaded from Microsoft Store on Windows 10 Pro x64?
- If the above is possible, then where do I find these downloaded Store files and how can I make them run on MPC-HC + LAV Filters + ReClock + madVR?
8700K @ 5Ghz | ASUS Z370 Hero X | Corsair 16GB @ 3200Mhz | RTX 2080 Ti @ 2100Mhz | Samsung 970 NVMe 250GB | WD Black 2TB | Corsair AX 850W | LG 32GK850G-B @ 165Hz | Xonar DGX | Windows 10 LTSC 1809
XMonarchY is offline   Reply With Quote
Old 19th May 2016, 17:29   #38085  |  Link
sneaker_ger
How it works may depend on the subtitle, the subtitle format and the renderer. For MPC-HC's internal renderer you would go MPC-HC Options -> Subtitles -> Default Style and un-tick "Position subtitles relative to video frame". For XySubFilter you should go into madVR's "zoom control" and enable moving subtitles to the bottom of the screen.
Old 19th May 2016, 17:34   #38086  |  Link
omarank
At least it seems more logical that way. However, and here comes the weird part: If you read the BT.709, BT.2020 etc specs, they explicitly say that limited range 8bit video has peak white at 235, while limited range 10bit video has peak white at 940. Using this logic, it could be 65280 instead of 65535.
In any case, when analyzing those 16bit ramps, madVR understands both types of LUTs to be "linear". But when creating a linear 16bit ramp, madVR uses 257.
From what I remember, in some OSs and with some GPU drivers, 256 was used and sometimes 257.
Upon toggling the two states of "linear" LUTs (65280 ending and 65535 ending) while playing some movie content, I find the images look better (more natural) when the LUT is in the OS default state (ending at 65280). But this may be subjective.
I wish madVR could completely disable the LUT processing instead of setting the LUT linear. In that case even when the LUT is loaded, madVR could read the LUT and apply it internally in high bit depth like it does for Overlay mode.
omarank is offline   Reply With Quote
Old 19th May 2016, 18:13   #38087  |  Link
MariaX9
Originally Posted by chros View Post
No, you can use any directshow player. Lav expose couple of info that maybe other filters won't for madvr (3d, hdr, etc), so it's a safe bet to go for lav.
Originally Posted by Asmodian View Post
LAVfilter is a needed companion for madVR. To my knowledge it is the only filter that passes flags to madVR, otherwise a lot of assumptions are made. Those assumptions are often correct but it is much better to use the stream information if it is available.
However LAV has been integrated into MPC-HC and MPC-BE so you do not need to install anything else.
mpc-be has not integrated lavfilter.
mpc-be internal filter can't deal with ordered chapter while lavfilter can.
lavfilter can't deal with very exotic PS2 videos that are using a "special" type of PCM. the audio is ignored in this case while mpc-be internal filter can play them with audio.
these are just things i know the list should be way longer.
Thanks for the help, guys.
i will use MPC-HC now.
MariaX9 is offline   Reply With Quote
Old 19th May 2016, 21:21   #38088  |  Link
rvs75
Originally Posted by castaway View Post
Hello everyone
Any developer here ?
I have a player project, and would need to use mvrInterfaces but from the .NET library
I would mostly appreciate any help here, as I'm not a c++ developper (mvrInterfaces.h in c++).
(I tryed to compile it, adding CLR option, I could add it to my project but can't use the dll afterward).
You can find an old version here (2012).
From the same developer (ccrocker=KeyserSoze17) =>MeediOS - madVR Video Player, but i can't find source
rvs75 is offline   Reply With Quote
Old 19th May 2016, 22:14   #38089  |  Link
aufkrawall
Crimson 16.5.2 dramatically decreases madVR performance for me with my 390, I can't even use SuperRes 2 for 1080p -> WQHD Jinc, while with 16.5.1 even SR3 works.
Filled in a bug report, this driver gives also other users quite some problems.
Old 19th May 2016, 22:37   #38090  |  Link
sat4all
Lads, if you have to choose between bicubic50,sofcubic50,dxva for image upscaling, which one will you pick-up for 1:1 bluray > 2160p.
Intel dxva upscaling is something similar to lanzcos, right?
With bicubic or sofcubic my hd5000 gpu load is arround 83% while 43% using dxva2.
sat4all is offline   Reply With Quote
Old 19th May 2016, 23:04   #38091  |  Link
castaway
Thanks a lot for the link. Funny as I had found the player already and he did an impressive job here.
I will see if I can use this interface for my needs!
castaway is offline   Reply With Quote
Old 20th May 2016, 07:03   #38092  |  Link
ionutm80
Originally Posted by ashlar42 View Post
I created a custom resolution on my HTPC (Win 8.1 x64, Nvidia GTX660). It got accepted as 60, although it was for 59.940 (more 59.941 in my case, including clock deviation adjustment).
BUT
But apparently madVR, with FSE and DirectX11 path, decides to use the old 59 frequency from standard Nvidia Control Panel. A resolution I have no way of selecting manually, mind. And if I switch to Windowed DX11 or DX9 (both FSE and Windowed), madVR picks the correct resolution/refresh, the custom one I've created (which gives a repeat every 5.55 hours or so).
Your finding is exactly mine too, I thought that other tools that I'm using are to blame but in fact is madVR behavior ... I've also created a custom 59.941 resolution in my NVidia CP to try to match SVP output at 59.94 but strangely whenever I start a movie madVR shows for 1 sec 59.940 resolution for display but then immediately switch to 59.937xx which is in fact my NVidia resolution for 59Hz.
So you're saying that if I disable FSE my custom resolution should remain locked? (59.941 instead of 59.937xx)
ionutm80 is offline   Reply With Quote
Old 20th May 2016, 07:36   #38093  |  Link
Nevilne
why not change svp hz instead
Nevilne is offline   Reply With Quote
Old 20th May 2016, 07:46   #38094  |  Link
ionutm80
That could be an option too ... I will ask on their forum if it's possible to interpolate to 59.937 instead of 59.94.
Old 20th May 2016, 08:44   #38095  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
While interpolating to arbitrary framerates is possible, it's not a good idea. With 5:2 interpolation (24 * 5 / 2 = 60) you lose half of the original frames. But with 19998979:8000000 you basically lose all original frames.
vivan is offline   Reply With Quote
Old 20th May 2016, 09:34   #38096  |  Link
ionutm80
You lost me here, why am I losing frames? The original 24 should still be there, is just that I see more frames now (the computed and interpolated ones), or you are referring to the fact that I still do not have a perfect multiple of the original frames by an integer number?
Old 20th May 2016, 09:51   #38097  |  Link
Uoppi
Here's another user really liking the deringing feature! (And this is coming from someone who usually finds it hard to spot any clear PQ differences between various madVR settings. )
Uoppi is offline   Reply With Quote
Old 20th May 2016, 13:13   #38098  |  Link
ashlar42
In my experience I could both disable FSE or switch to DX9 rendering.
I ended up using CRU to completely redo all resolutions. That solved the problem with resolution switching but I now find myself needing to use Limited RGB range, whereas previously I was using Full RGB range. Results appear correct with madVR set to 0-255, if I set it to 16-235 colors are washed out.
I described the problem fully here, if anyone is familiar with CRU: http://www.monitortests.com/forum/Th...d=5375#pid5375
Old 20th May 2016, 13:52   #38099  |  Link
ionutm80
So it's enough to switch tp D3D9 w/o disabling FSE?
Old 20th May 2016, 17:15   #38100  |  Link
Plutotype
Has any reviewers tested GTX 1080 with madvr? Im looking at GTX 1070 as absolute overkill for HTPC, but wondering how these cards could perform in terms of all madvr features.
System: Intel Core i5-6500, 8GB RAM, GTX960/GTX1060, 55" Sony Bravia KDL-55HX850 @ 1920x1080 24p, Yamaha YSR-1100 surround bar
Setup: Win7/Win10 Pro, madvr/JRiver 24
Plutotype is offline   Reply With Quote
