Old 24th February 2010, 16:46   #6961  |  Link
beb7089
Originally Posted by prettyboy85712 View Post
Obviously you didn't search this thread very hard.
I've read over the thread quite a bit for the last couple days. Tried a lot of the "here is what fixed my problem" resolutions with no success.
I'm asking for help...not criticism.
beb7089 is offline   Reply With Quote
Old 24th February 2010, 17:16   #6962  |  Link
beb7089
OK...Here's a real head scratcher..
Took [Base3.0] iPod profile and lowered level to 2.1 and double checked that ref = 1
Set video output to 480x272
Birate set to 512 and AAC to 128
iTunes still will not sync this file to my iPod but will play it fine in iTunes.
Old 24th February 2010, 21:35   #6963  |  Link
pacaveli211
this thread is ~350 pages....it takes years to sort through
you could at least give him a link to the post or something
pacaveli211 is offline   Reply With Quote
Old 24th February 2010, 22:18   #6964  |  Link
prettyboy85712
What's your source?
prettyboy85712 is offline   Reply With Quote
Old 24th February 2010, 22:30   #6965  |  Link
beb7089
What's your source?
MPEG2 720x480 .vob file
Old 24th February 2010, 22:38   #6966  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
http://www.mediafire.com/file/znzi5jgijiw/[BASE 1.3] iPOD 5.5.txt
copy this file to profiles folder
also use 320x240 resolution
BTW you don't need itunes to copy files to your ipod. http://www.floola.com/
Old 24th February 2010, 22:38   #6967  |  Link
beb7089
The problem appears to be with mp4box itself. If you look inside the job1_MuxFile.cmd you'll see variable "-IPOD". This variable is to ad an "atom" for ipods. It appears to be not working.
After search through other resources, I came across "nicMP4Box" and used it to wrap my 480x272 video and aac audio that were encoded with Ripbot. It would now sync to my ipod but due to the 480 resolution it would not fill the screen on the ipod display.
Testing a 640x480 resolution now and using the nicMP4Box.exe to wrap it up instead of MP4Box.exe that came with RipBot 1.15.0
Old 24th February 2010, 23:05   #6968  |  Link
beb7089
I downloaded the profile file and reduce resolution to 320x240 and bitrate to 512. Still the file would not sync to my ipod.
I use iTunes on my MacBook to sync with since I have purchased TV and Movies. I encode on my Windows machine and then transfer the file to my Mac to add to iTunes.
Old 24th February 2010, 23:17   #6969  |  Link
Atak_Snajpera
wouldn't be easier windows -> floola ?
Old 25th February 2010, 02:21   #6970  |  Link
pacaveli211
I use winamp for ipod stuff. I don't know if it'll do video though
Old 25th February 2010, 04:39   #6971  |  Link
beb7089
Found the issue.
RipBot264 uses MP4Box to wrap up the video and audio streams into a MP4 container. MP4Box uses variable -IPOD in the job1_MuxFiles.cmd file to add the uuid atom for iPod 5.5G models (aka iPod Classic). Unfortunately mp4box is not adding this special atom into the mp4 file. This atom tells iTunes that H.264 video, up to 1.5 Mbps, 640 by 480 pixels videos can be played on iPod 5.5G
Could not get mp4box to work for nothing.
Then I found nicmp4box.exe and it was "tweaked" to import this special atom automatically. nicmp4box.exe works great. It wraps up my video and audio into an mp4 container and will sync from iTunes to my iPod.
nicmp4box.exe
Old 25th February 2010, 05:51   #6972  |  Link
stinman
I read somewhere that I could use 64bit x264 with your gui?
Is this true?Do I just replace the x264 with the 64bit x264 in the tools?Or what.Thanks for a great program Atak_Snajpera
Oops,I just seen it was in the x264 folder,I guess it will use it automatically.Sorry about the n00b question,still gave me the chance to say thanks for your program.
stinman
stinman is offline   Reply With Quote
Old 25th February 2010, 20:28   #6973  |  Link
J33pman
I have run into an issue while ripping my Star Trek Original Series BDs. Season1 went fine, but 5 disks of Season 2, and now several of Season 3 fail to rip the first episode in the drop down. All subsequent eqpisodes rip and encode fine. I also tried ripping the disk to the hard drive first, with the same result: DirectShowSource: couldn't open file D:\Temp\RipBot264\job4\video.mkv: The system cannot find the file specified. (D:\Temp\RipBot264temp\job4\getinfo.avs, line2)
I looked through the site for a while, but didn't see a similar error. As I said, it's only the first "track" and the rest of the disk rips without incident.
Thoughts?
Thanks for your help!
J33pman is offline   Reply With Quote
Old 25th February 2010, 21:25   #6974  |  Link
pacaveli211
Thoughts?
demux the audio and video (if it's vc-1 mux back into an mkv instead of an m2ts)
Old 25th February 2010, 22:24   #6975  |  Link
beb7089
Found the issue.
nicmp4box.exe
UPDATE...
Well I thought NICMP4BOX.EXE would resolve my issue and it did about 25% of the time. Not a very good solution.
I took a video processed with RipBot using base3.0 640x480 1.5Mbps and gave it to my buddy to try on his iPod touch. It worked and synced with no issues.
I've decided that it was too much work and troubleshooting to get the iPod 5g atom applied to the mp4 file. Decided after 2 yrs of having my iPod 5G it was time to upgrade to an iPod touch.
Old 26th February 2010, 02:08   #6976  |  Link
xantius
@xantius
http://sourceforge.net/projects/ffdshow-tryout/files/
BTW. I had the same problem some time ago. Problem disapeared when I installed newer ffdshow version.
Atak_Snajpera, I've tried installing newer and different versions of ffdshow, but unless the last step isn't going into the video properties (where you set resize, crop, etc options) and clicking ok, like pacaveli211 suggested, the video doesn't resize properly, and encodes very very slowly (10 fps max as opposed to 100+ fps). Would you mind giving me the info or link to the exact version of ffdshow that you're using? I would just like to eliminate any doubt about weather or not it's the filter.
xantius is offline   Reply With Quote
Old 26th February 2010, 14:13   #6977  |  Link
Atak_Snajpera
Ok. I have the same problem. I didn't notice that before. I always check audio sync in preview so I always go to properties.
UPDATE: Ok I finally found the problem. It will be fixed in new version. New version will be released after NAL-HRD patch is 100% stable.
http://forum.doom9.org/showthread.php?t=152127
Temporary solution :
Usex264x64=0
Old 26th February 2010, 18:53   #6978  |  Link
J33pman
I guess I'm still a little confused, as I always choose MKV encoding. The app goes through the first "Demuxing selected streams" and goes to 100% on the first pass (they always go through this twice for some reason) but throws up the error on the second pass. Do I need to demux these with another app? If so, what do you recommend? Thanks!
Old 26th February 2010, 19:04   #6979  |  Link
Atak_Snajpera
demuxlog.txt should tell you what went wrong
Old 26th February 2010, 20:00   #6980  |  Link
Arbelisk
I can confirm your error. I am trying to convert the same discs and the error shows up with the first episode but the rest work fine. Seems to be a problem with the Arcsoft Decoder or the Blu-Ray files themselves.
M2TS, 1 video track, 4 audio tracks, 4 subtitle tracks, 0:50:40, 24p /1.001
1: Chapters, 6 chapters
2: VC-1, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 7.1 channels, 24 bits, 48khz
(core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz)
4: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
5: AC3, Spanish, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
6: AC3, French, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
7: Subtitle (PGS), English
8: Subtitle (PGS), Spanish
9: Subtitle (PGS), French
10: Subtitle (PGS), Portuguese
Creating file "D:\Temp\RipBot264temp\job1\chapters.txt"...
[s07] Extracting subtitle track number 7...
[v02] Extracting video track number 2...
[v02] Muxing video to Matroska...
[a03] Extracting audio track number 3...
[a03] Decoding with ArcSoft DTS Decoder...
[a03] Reducing depth from 24 to 16 bits...
[a03] Encoding FLAC with libFlac...
[a03] Creating file "D:\Temp\RipBot264temp\job1\audio_English.dtsma.flac"...
[s07] Creating file "D:\Temp\RipBot264temp\job1\7_subtitles_English_1080.sup"...
[a03] The ArcSoft DTS Decoder reported an error while decoding. <ERROR>
Aborted at file position 7906023424. <ERROR>
Arbelisk is offline   Reply With Quote
