Old 25th September 2018, 18:12   #8621  |  Link
Zathor
Please update either to 2876 (stable) or 2884 (development) and try it again.
Zathor is offline   Reply With Quote
Old 25th September 2018, 20:08   #8622  |  Link
Danette
OK. I am now in 2876, but cannot import my presets from 2836. When I try, I get the message: "MeGUI encountered a fatal error and may not be able to proceed. Reason: Size mismatch between central header(18321) and local header(769)"
Danette is offline   Reply With Quote
Old 25th September 2018, 20:13   #8623  |  Link
Zathor
Could you please upload those presets for me?
Old 25th September 2018, 20:22   #8624  |  Link
Danette
Can't. Says a "security token is missing" Ugh ...one thing after another.
Old 25th September 2018, 20:34   #8625  |  Link
Zetti
Just upload them to any online service, Zippayshare.com, Upload.ee, Dropbox, Google Drive or any other and post link.
Zetti is offline   Reply With Quote
Old 25th September 2018, 20:49   #8626  |  Link
Danette
Here is the link:
https://www110.zippyshare.com/v/QODlEKm9/file.html
Thanks, Zetti.
Old 25th September 2018, 21:00   #8627  |  Link
Zathor
Are you sure that this is the correct upload? It seems to me that this is the 2836 plan installation folder and therefore without any presets.
Old 25th September 2018, 22:17   #8628  |  Link
Danette
Yes: it is the file I intended to upload. However, you are right: it is the installation zipped folder. When I saved the settings, I selected to over-write that installation folder with the settings. I was asked if I wanted to replace that installation zip file and chose "Yes." I then received the confirmation message from MeGUI that it was successful but, that was an error. I just repeated this action to verify it.
You may want to look into this saving procedure as it seems that it does not over-write files when it says that it does.
In any case, the original issue with the
-[Warning] MediaInfo
--[Information] [9/25/2018 10:15:07 AM] File: C:\Users\Main\Desktop\Videos\Vietnam In HD\3 x264, Audio & Chapters
--[Warning] [9/25/2018 10:15:07 AM] The file cannot be opened
warning has been solved by upgrading to 2876. Thanks for the help.
Old 26th September 2018, 04:58   #8629  |  Link
Danette
FPS v2836 vs 2876
Running a One-Click job using the script:
TFM(slow=2)
TDecimate()
In 2836, the output is 23.976 FPS as it should be. In 2876, the same script creates a file having 19.181 FPS and, of course, the playback is not smooth.
Old 26th September 2018, 07:50   #8630  |  Link
LigH
LigH's Avatar
Almost seems like after a decoder already applying IVTC (or just "not applying Telecine" – e.g. DGMPGDec is able to respect or ignore Telecine flags in MPEG-2), TDecimate adds an IVTC attempt on already progressive FILM material. So it may depend on the available source format and the used decoder, too.
New German Gleitz board
Old 26th September 2018, 14:35   #8631  |  Link
Danette
The source is definitely the 3:2 telecined pattern (MPEG based NTSC TV shows from DVD). I considered the possibility of duplicate deinterlacing, but the One-Track configuration does have the "Automatic Deinterlacing" un-checked. I simply imported the 2836 settings into the 2876.
Version 2836 is perfect, but 2876 has this odd FPS on the same files. Both are using DGindexNV.
Old 26th September 2018, 21:55   #8632  |  Link
Zathor
TFM(slow=2)
TDecimate()
Please post both logs. Otherwise we can only guess what is going on.
Old 26th September 2018, 22:23   #8633  |  Link
Zathor
Thanks, good catch. It seems to be that way since ancient times and noone reported it.
Old 2nd October 2018, 05:01   #8634  |  Link
tuanden0
How meGUI trick to pass the AVS to make it as the input of neroAacEnc?
I tried to write batch to auto downmix to stereo 200 audio files using neroAacEnc and AVS. I tried to use meGUI to get the example cli but can't see how they pass the AVS input (neroAacEnc only support WAV input).
This is cli in my log:
--[Information] [02-Oct-18 10:47:10 AM] Job command line: E:\Soft\MeGUI\tools\eac3to\neroAacEnc.exe -ignorelength -q 0.2 -if - -of "E:\Download\5.m4a"
edit: I did it, just using avs2pipemod to pipe.
tuanden0 is offline   Reply With Quote
Old 8th October 2018, 20:27   #8635  |  Link
koberulz
Error loading Job
Job D:\DVD Files\Software\MeGUI_2624_x86\jobs\job504.xml could not be loaded. Delete?
Yes No
job504.xml is an empty xml file, as are the rest that I checked between 504 and 808. Manually deleting all 304 doesn't really appeal.
If I just wipe the folder completely from within Windows Explorer, I get a fatal error and MeGUI won't start.
koberulz is offline   Reply With Quote
Old 8th October 2018, 21:44   #8636  |  Link
Zathor
Which MeGUI version are you using?
In general you can reset all jobs if you delete all files in \jobs and the file joblists.xml
Old 8th October 2018, 21:57   #8637  |  Link
LigH
LigH's Avatar
Just don't delete the folder jobs as such. Leave it there, empty.
Old 9th October 2018, 05:50   #8638  |  Link
koberulz
Where is joblists.xml?
I'm not sure which version I'm using, as I can't open it to check. It was up-to-date as of a couple of days ago, I think?
What's with having to answer a question to post on here?
Old 9th October 2018, 07:22   #8639  |  Link
LigH
LigH's Avatar
MeGUI usually stores all data below its installation directory; that's the reason why it should not be installed in the UAC monitored Program Files area. I have a joblists.xml where the MeGUI.exe is located.
Old 9th October 2018, 07:33   #8640  |  Link
koberulz
It's not there. Ran a search and found it in a 'backup' folder.
Deleted it, cleaned out the jobs folder and we're up and running.
megui
