Old 23rd August 2018, 08:18   #52141  |  Link
foobar2000
ngu 480p or 720p to 2160p screen, does require 1080ti card?
foobar2000 is offline   Reply With Quote
Old 23rd August 2018, 08:28   #52142  |  Link
foozoor
foozoor's Avatar
A GeForce RTX 2080 Ti should work too.
foozoor is offline   Reply With Quote
Old 23rd August 2018, 08:28   #52143  |  Link
ryrynz
ryrynz's Avatar
@fallen you should be in the Potplayer forum not here.
@foobar no it does not, you'd probably be fine with a 1060.. but 1070+ would be good.. I'd wait until the 20xx cards drop before buying anything though.
@foozor extra 50% performance over 1080Ti *Drool*
Old 23rd August 2018, 10:53   #52144  |  Link
Siso
Soul Seeker
Siso's Avatar
Originally Posted by fallengt View Post
Potplayer is using Lav filters.
Not sure what seem to be the problem. Downloading few more HEVC encoded videos to test it now.
Edit: nope potplayer still shows everything NV12
I'm pretty sure that potplayer's internal codecs are forcing this output...
Old 23rd August 2018, 11:42   #52145  |  Link
Bl4ze87
Sorry guys, what's the best nvidia driver version to havehdr working properly?
Bl4ze87 is offline   Reply With Quote
Old 23rd August 2018, 14:51   #52146  |  Link
Zaoshi
No, I have 1070 and I upscale to 2160p then downscale to 1440p.
Zaoshi is offline   Reply With Quote
Old 23rd August 2018, 16:18   #52147  |  Link
Manni
Everyone will give you a different version.
I use 385.28 because that the one with the least issues with my display (see sig).
Win11 Pro x64 b23H2
Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33
madVR/LAV/jRiver/MyMovies/CMC
Denon X8500HA>HD Fury VRRoom>TCL 55C805K
Old 23rd August 2018, 16:48   #52148  |  Link
Asmodian
I use the newest (398.82), they work perfectly for me.. custom resolutions and everything.
madVR options explained
Old 23rd August 2018, 16:57   #52149  |  Link
oldpainlesskodi
Can you select 12bit with a custom res?
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema
oldpainlesskodi is offline   Reply With Quote
Old 23rd August 2018, 18:24   #52150  |  Link
veggav
The only way to get 12bits with custom timings is calculating your timings with MadVR and using Custom Resolution Utility to add it to your driver.
Go a few pages back, I've explained how to do it and it worked for me and at least one other user.
veggav is offline   Reply With Quote
Old 23rd August 2018, 18:40   #52151  |  Link
Siso
Soul Seeker
Siso's Avatar
Is doubling better than image upscaling in your case?
Old 23rd August 2018, 18:45   #52152  |  Link
Asmodian
My TV has more banding with >8 bit so I do not want 12 bit, but no, I cannot use 12 bit with custom resolutions. >8 bit is the least important aspect of getting the image to the screen but it should work.
Old 23rd August 2018, 19:06   #52153  |  Link
foobar2000
isn't 12 bit just 8 bit/10 bit adding zero at the end of signal??
Old 23rd August 2018, 19:13   #52154  |  Link
Zaoshi
Yes. Doubled 720p is exactly 1440p. Quadrupled 480p becomes 1920p so it has to be scaled down. But due to scaling amount NGU makes it much better than other methods.
On the other hand, 1080p probably doesn't benefit much from NGU (I haven't tested), but I use it anyways.
Old 23rd August 2018, 19:34   #52155  |  Link
Siso
Soul Seeker
Siso's Avatar
My question was about 1080p movies. In my case I'm with a 29 inch 2560x1080p monitor. So for me image upscaling is OK, I was wondering if doubling will benefit.
Old 23rd August 2018, 20:21   #52156  |  Link
Zaoshi
In high bitrate case Antialias loses fine details. Sharp and Standard are much better in this case.
Jinc produces similar results, but edges aren't sharp.
In the end, unless you pixel hunt in screenshots there is no visible difference.
Edit: I tried to attach screenshots but they got scaled down so no reason to attach them.
Old 23rd August 2018, 20:29   #52157  |  Link
Siso
Soul Seeker
Siso's Avatar
Attaching images in the forum could take forever to be approved...
Old 23rd August 2018, 20:34   #52158  |  Link
Zaoshi
Yeh, images also were scaled down. Uploaded them here instead: https://imgur.com/a/CwI2xO5
Old 23rd August 2018, 21:06   #52159  |  Link
Asmodian
I thought so too but maybe not. You want 100% to be the same and 111111110000 is not 100% in 12 bit. There are several ways 8 bit could be converted to 12 bit.
Old 24th August 2018, 06:59   #52160  |  Link
x7007
I fixed it by disabling all the checkbox on the 8 bit in Lav Video Filter settings.
It still works fine for 8 bit and works with P10 with potplayer.
x7007 is offline   Reply With Quote
