Old 14th September 2008, 18:29   #1041  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Originally Posted by Sharktooth View Post
@bobor: if the problem is coreavc not decoding standard compliant streams, they should fix it or ppl have to use other decoding softwares.
i dont see the reason to cripple something to fix a problem related to another software...
that said, screw coreavc until it gets fixed. they get paid to do that...
request: fprofiled r968 (generic) + psy-rdo/psy-trellis + hrd & pulldown + new bframe decision (optional)
I am sorry you don't understand me.
The whole reason for NOT compiling with patches anymore is because the patches are no longer changing and are tested more than enough. It's up to the developers now to add it to GIT or drop it. Or possible resume on a later day.
If it's final: add to GIT, if it's not ready, put it on ice or start developing. If the same happens to psy_rdo as what happened to AQ, i am not going to wait and spend wasted time (auto compiling is a lot less time consuming) on compiling builds which are not "stable/signed by pengvado"!
Use skystrife's builds for now
As for CoreAVC i was just pointing out CoreAVC has a problem, and not the x264 patches.... so prepare it for GIT or put it on ice.
And if more tests are needed, all anyone has to do is shout and tons of testers ready!
bob0r is offline   Reply With Quote
Old 14th September 2008, 19:39   #1042  |  Link
lexor
From what bobor said, I don't get the impression that he dropped patch support to fix coreavc compatibility, I think he removed patches because he believes them ready for commit and thus not worth extra effort on part of builders.
I agree for psy_rdo and hdr patches. But new bframes still needs work. It is not linear time currently, aku promised to make it so by reusing motion vectors (or something), but there have been no patch updates for that. So bframe is still under development (I presume). The other 2 had no changes for a long time and only need updating because git keeps changing.
Geforce GTX 260
Windows 7, 64bit, Core i7
MPC-HC, Foobar2000
lexor is offline   Reply With Quote
Old 15th September 2008, 01:27   #1043  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
uh, sorry. i got the impression it was due to coreavc problems.
Old 15th September 2008, 06:27   #1044  |  Link
burfadel
Its good to see that the new b-frame decision is added as an option with 969, but just curious whether it will always be available an option or will it be the default once it is fully optimised? (it would be easy to set the default to 2 and have 1 as the original as is at the moment if that does every happen)!
Old 15th September 2008, 06:59   #1045  |  Link
bob0r
Pain and suffering
bob0r's Avatar
I am quite sure the best speed/quality trade off will be set as default, and that ofcourse is always the goal of the x264 devs.
So when its fast enough, it will replace the current b-frame methods.... maybe the old will be an option, maybe it will disappear.
Old 15th September 2008, 07:51   #1046  |  Link
ImmortAlex
Originally Posted by Dark Shikari View Post
... x264's improved B-frame decision will be patched into the official version within a few days ...
Sounds good!
ImmortAlex is offline   Reply With Quote
Old 15th September 2008, 13:24   #1047  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
trying to make a new build and getting some errors trying to access the git repository:
git.videolan.org[0: 91.121.111.144]: errno=No such file or directory
fatal: unable to connect a socket (No such file or directory)
git.videolan.org[0: 91.121.111.144]: errno=Invalid argument
fatal: unable to connect a socket (Invalid argument)
can anyone else confirm?
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 15th September 2008, 13:26   #1048  |  Link
Sagekilla
x264aholic
In r969, was the whole b-frame patch (the latest one anyway) applied or are there new parts to this that have been included? I've been reading through the description (Heh, are you uploading with --verbose now to git? ) and I'm seeing a few things I wasn't even aware of before.
Sagekilla is offline   Reply With Quote
Old 15th September 2008, 13:28   #1049  |  Link
skystrife
skystrife's Avatar
Confirmed.
$ git pull
git.videolan.org[0: 91.121.111.144]: errno=No error
fatal: unable to connect a socket (No error)
skystrife is offline   Reply With Quote
Old 15th September 2008, 13:30   #1050  |  Link
Sagekilla
x264aholic
accessing git.videolan.org seems to be a bit off lately. I tried checking last night too and the whole videolan.org site was down, with the git portion variably accesible.
Old 15th September 2008, 13:49   #1051  |  Link
komisar
komisar's Avatar
x264 GIT:969 source
http://komisar.gin.by/test/x264_969_src.7z
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
Old 15th September 2008, 14:47   #1052  |  Link
stanjr
Linux Encoder
yes, going to snv would be a lot better.. at least for linux users, since no one are building latest snapshot+patch for *nix
BHH
I could build this for you for 64bit Ubuntu Linux if you want.
stanjr is offline   Reply With Quote
Old 15th September 2008, 14:59   #1053  |  Link
buzzqw
HDConvertToX author
i actually can compile git versione without problem (./configure --enable-pthread --enable-mp4-output)
but.. i miss the patches
anyway.. on last git b-adapt is committed, just missing the psy-rd and hrd_pulldown
and.. btw i use 32bit debian sid
thanks a lot for your offer stanjr!
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 15th September 2008, 15:07   #1054  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
Originally Posted by komisar View Post
thanks for providing!
since it's CRLF, makes things more of a pain though
and stanjr should still be able to compile for x86 linux on his x64 one, by using
(iirc) --host=i686-pc-linux-gnu
which may or may not need --extra-cflags=-m32 as well
going to need the gcc multilib packages to do that tho.
Old 15th September 2008, 15:22   #1055  |  Link
ImmortAlex
Hey, GIT is on again and psy-rd is commited! Waiting for fresh builds...
Old 15th September 2008, 15:23   #1056  |  Link
martino
masktools2 (ab)user
martino's Avatar
BHH
Actually, I started after switching to Ubuntu.
My x264 builds (win32 only up to rev965) and useless AviSynth functions -- use at your own risk
martino is offline   Reply With Quote
Old 15th September 2008, 15:26   #1057  |  Link
buzzqw
HDConvertToX author
[OT]i am compiling too (for anyone speaking italian http://forum.divxmania.it/x264-linux.../t11427/n.html )[/OT]
@ImmortAlex
git is out for me... are you sure you can
git clone git://git.videolan.org/x264.git
BHH
Old 15th September 2008, 15:45   #1058  |  Link
Ranguvar
Ranguvar's Avatar
Git is back online
Ranguvar is offline   Reply With Quote
Old 15th September 2008, 15:52   #1059  |  Link
Comatose
Dead for me ><
Comatose is offline   Reply With Quote
Old 15th September 2008, 17:06   #1060  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Doesn't work for me either, I still get:
LoRd_MuldeR@MULDER_NEU /c/downloads/x264_git
$ ./build.sh
Initialize x264/.git
Initialized empty Git repository in c:/downloads/x264_git/x264/.git/
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
