Old 30th November 2008, 15:25   #61  |  Link
DGVC1DecNV Version 1.0.0
Have at it, gals and guys!
http://neuron2.net/dgvc1decnv/dgvc1decnv.html
The updated CUVID Server supports both the AVC and VC1 source filters. Be sure to upgrade nvcuvid.dll also.
Guest is offline
Old 30th November 2008, 15:44   #62  |  Link
Sharc
Sharc is offline
Old 30th November 2008, 16:19   #63  |  Link
Sharc
m2ts file (from the log):
Stream Type: Transport [192]
Profile: Advanced
Level: 3
Frame Size: 1920x1088
SAR: 16x9
Display Size: 1920x1080
Frame Rate: 23.976024 fps
Colorimetry: BT.709* [2]
Frame Structure: Progressive
Frame Type: I
Coded Number: 924
Playback Number: 924
Frame Repeats: 0
Field Repeats: 0
Bitrate: 28.009
Bitrate (Avg): 18.469
Bitrate (Max): 39.658
Audio Stream: 1100: PCM 48K 16bit 3/2lfe
Audio Stream: 1101: AC3 3/2 640
Audio Stream: 1102: AC3 3/2 640
Audio Stream: 1103: DTS C+L+R+SL+SR 48 1536
Audio Stream: 1104: AC3 3/2 640
Audio Stream: 1105: DTS C+L+R+SL+SR 48 1536
Audio Stream: 1106: AC3 3/2 640
Audio Stream: 1107: AC3 2/0 192
Elapsed: 0:00:07
Audio:
When I "Select All" and Save Project => crash
When I select e.g. "stream 1101" only and Save Project => ok
Added:
Apparently it is the DTS streams (1103, 1105) which cause the problem.
Sharc is offline
Old 30th November 2008, 18:43   #64  |  Link
rica
Hi Don, thanks for the release.
I've made some trials with both prealpha edition and the fist release.
I've seen interlaced artifacts and pixelization on MC interlaced clip.
Both CD and MC clips play at 20-22 fps even the original was 29.97 interlaced.
Here is my avs:
LoadPlugin("C:\users\rica\desktop\DGVC1\DGVC1DecodeNV.dll")
VC1Source("G:\MC\video.dgv")
fielddeinterlace()
FW 178.24, GPU 8600GTS, CPU E6750, RAM 2GB/800, OS Vista SP1 32bit Ultimate.
rica is offline
Old 30th November 2008, 19:59   #65  |  Link
woah!
i am still getting a error 700 decode problem on untouched m2ts files
what driver set are you working with? maybe that should be mentioned as i am running the newest nvidia drivers 180.48 WHQL from here:
http://www.nvidia.com/object/winxp_180.48_whql.html
woah! is offline
Old 30th November 2008, 20:39   #66  |  Link
woah!
well i just downgraded back to the 178.24 drivers, but now i still get the error and now i cant continue to process the vc1 file, as DGVC1IndexNV just crashes straight away now
i have no issues with AVC files at all with the other program of yours.
i am using a 260GTX...
woah! is offline
Old 30th November 2008, 21:14   #67  |  Link
Audionut
Sweet, thanks neuron2.
The requested URL /dgvc1decnv/cuvidserver102.zip was not found on this server.
Audionut is offline
Old 30th November 2008, 21:58   #68  |  Link
rica
This is already what nvida suggests to 200 series owners.
rica is offline
Old 30th November 2008, 23:03   #69  |  Link
woah!
ok sorry to get confusing here, but i am back on track now.
seems avisynth was playing a roll in this problem. i uninstalled avisynth, reinstalled it, loaded problem m2ts and i now get no issue with error700
but it crashed as soon as i tried to index
turns out to be if there is a DTS track this is causing the crash, as if i choose set no audio track, then it indexes fine
all is working fine now as long as i set no audio, would it be possible to have a drop down option to tick off audio demuxing?
woah! is offline
Old 30th November 2008, 23:25   #70  |  Link
rica
neuron2 states in his quickstart guide:
 DGVC1IndexNV saved your audio in a file(s). It will have a ".wav", ".ac3", or ".mpa" extension.
So, no dts support...
rica is offline
Old 30th November 2008, 23:42   #71  |  Link
Don't you know by now that I need a stream to duplicate the issue?
DTS demuxing should be working. If it is not, please provide a source stream sample.
Guest is offline
Old 30th November 2008, 23:44   #72  |  Link
Same answer as above.
Guys, I don't have a magic wand! I have to get the stream to re-create your issue. Thank you for your patience.
Guest is offline
Old 30th November 2008, 23:45   #73  |  Link
Is it once at the beginning or end? Or is it multiple times on one stream?
Guest is offline
Old 30th November 2008, 23:51   #74  |  Link
Fixed. Thanks for pointing it out.
Guest is offline
Old 30th November 2008, 23:52   #75  |  Link
Give me the darn stream and I'll fix it!!!
This gets frustrating to keep having to ask for the stream.
DTS should work. If you give me the stream I will fix it.
Guest is offline
Old 30th November 2008, 23:54   #76  |  Link
rica
Mariah Carey vc1 is hidden inside MC.ts i've already uploaded :
http://www.mediafire.com/?sharekey=6...e8f04935ff43a0
If you need a raw vc1, please tell me.
best.
rica is offline
Old 30th November 2008, 23:57   #77  |  Link
Sharc
Same here with DTS. Works fine with AC3 streams though.
You can turn DTS streams off by:
- Audio => Audio Demux
- Select from the Available Audio Streams table the DTS stream you want to remove
- Press Clear
..... etc.
- Press Done
Sharc is offline
Old 1st December 2008, 00:02   #78  |  Link
Sharc
I know, I know .... just presently a problem with uploading 50MB ...
Sharc is offline
Old 1st December 2008, 00:28   #79  |  Link
OK, I see it too. I'll have to ask Nvidia about it and get back to you on it. Thank you for pointing it out.
Guest is offline
Old 1st December 2008, 00:48   #80  |  Link
Sharc
Here we go:
http://www.mediafire.com/?sharekey=f...db6fb9a8902bda
Sharc is offline
