Old 14th March 2009, 04:17   #301  |  Link
squid_80
gpD3D->GetAdapterCount() returns the number of video adapters in the machine.
gpD3D->GetAdapterIdentifier() fills out a D3DADAPTER_IDENTIFIER9 struct for a specific adapter.
cuD3D9GetDevice checks if a given device supports CUDA.
Basically the code iterates through each video adapter in the system until it finds one that supports CUDA. Then uses the given adapter number as the first parameter when calling gpD3D->CreateDevice instead of D3DADAPTER_DEFAULT.
squid_80 is offline
Old 14th March 2009, 04:51   #302  |  Link
tomos
I doubt it will work as a secondary. You'd have to ask Nvidia or try it for a definitive answer.
might end up trying it. could always make it pri if needs be i guess
tomos is offline
Old 14th March 2009, 15:52   #303  |  Link
Are you saying you KNOW that this will allow using an Nvidia card as a secondary adapter with my NV tools? Or are you suggesting it as something to try?
Guest is offline
Old 14th March 2009, 15:56   #304  |  Link
If you like, I'll work with you to try to get it working, assuming squid_80's idea works.
Guest is offline
Old 14th March 2009, 22:39   #305  |  Link
squid_80
I can't confirm that exact code will work as designed, since I can't test the "find first CUDA capable card" loop properly - my last ATI card fried 18 months ago and all my Nvidia cards are CUDA capable, so it always exits with adapter=0. But I have tested passing the adapter no. of a secondary Nvidia card to CreateDevice and it works.
squid_80 is offline
Old 15th March 2009, 00:26   #306  |  Link
OK, thank you. It seems at least worth trying. I need someone with dual adapters to step up for testing.
Guest is offline
Old 15th March 2009, 07:29   #307  |  Link
tomos
thanks
will be a few weeks till i get an nvidia card though. sorry. only one i have at the mo is an old 6800gt and i doubt it will work with CUDA
tomos is offline
Old 15th March 2009, 16:57   #308  |  Link
OK, ping me when you are ready to go. This could pull ATI users into the fold.
Guest is offline
Old 15th March 2009, 22:13   #309  |  Link
tomos
screw it, i just ordered a gts250. think it's like a 9800 or thereabouts. will hopefully get it tues/wed time. it's going to be on vista x64. will update once it's installed
tomos is offline
Old 16th March 2009, 02:33   #310  |  Link
Send me a PM when you are ready, as I will need to send you a special build. Thank you for your willingness to help.
Guest is offline
Old 20th March 2009, 02:51   #311  |  Link
~bT~
н∂-αиαтι
i have two cards in sli. i can try maybe?
~bT~ is offline
Old 20th March 2009, 03:06   #312  |  Link
OK, I'll add the code from squid_80 and make a binary available.
How does that SLI stuff work? Is there still a primary adapter?
Guest is offline
Old 20th March 2009, 03:13   #313  |  Link
~bT~
н∂-αиαтι
^ errrmm...no idea.. sorry.
~bT~ is offline
Old 20th March 2009, 10:37   #314  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
If it's anything like ATI's Crossfire you'll have two separate adapters and an option somewhere in the driver to link them, at which point the second adapter disappears from a program's point of view.
now playing: [artist] - [track] ([album])
Leak is offline
Old 20th March 2009, 10:51   #315  |  Link
squid_80
It won't be a very good test for the code I posted anyway since even if they exist as 2 separate devices they will both be CUDA capable.
squid_80 is offline
Old 20th March 2009, 13:07   #316  |  Link
But I can make the code ignore the first one just for testing.
Guest is offline
Old 31st March 2009, 08:00   #317  |  Link
crasus
neuron2, just a small question. I have the nvcuvid.dll that came with the latest nVidia drivers & CoreAVC Pro in system32 and your version in the program directory.
Considering that MPC-HC is set up to use the CoreAVC Pro CUDA function, can I run a x264 encode with DGVC1DecNV's avs function while watching a movie in MPC-HC?
crasus is offline
Old 31st March 2009, 14:07   #318  |  Link
I don't recommend it. If you do it, I take no responsibility for what happens.
Guest is offline
Old 31st March 2009, 15:59   #319  |  Link
crasus
Thanks for the reply, neuron2! As I'm curious, do you have any ideea to what might happen?
crasus is offline
Old 31st March 2009, 16:09   #320  |  Link
laserfan
Aging Video Hobbyist
Lessee, your movie playback fails 90% in, and you have a crowd of people in your HT. At the same time the encoding that's been cranking-away for 16 hours and counting craps-out and you have to start over. Why risk it?
laserfan is offline
