Old 20th October 2019, 05:43   #1101  |  Link
TomSmith
Originally Posted by Patman View Post
Hi Tom,
i've done an encode with nearly the same setting as yours.
As indexer i've used ffms, because L-Smash causes me some problems. I'm already looking for a solution. Try to reinstall Python and Vapoursynth and then try again.
Originally Posted by stax76 View Post
@TomSmith
In error in the middle of an encoding could be a hardware issue, an issue with the source or with the source filter, that are the most likely causes, I've not seen this happening before.
I googled for "fwrite() call failed when writing frame" and found that other staxrip had this error using VapourSynth before but I did not really understand what was the cause, can be found here:
https://forum.videohelp.com/threads/...de-vpy-scripts
I installed Python and Vapoursynth (R48-RC1) again and will try it again asap (using ffms2).
I tested my RAM using memtest86 also but no errors. RAM seems to be OK. It is also listed in the compatibility-list of the motherboard.
Thank you for your help!
TomSmith is offline   Reply With Quote
Old 20th October 2019, 19:02   #1102  |  Link
Bahamuth
@Bahamuth
That would be a bug, I will examine it if you create a ticket on the tracker. In your startup template I assume that your filter setup is vapoursynth and not avisynth?
I'm honest, it might have been my error. I never used VapourSynth before so I didn't even knew, there is this "Filter Setup" setting if you right click on the filters.
In my defense, I didn't find "filter setup" at the Docs from https://staxrip2.readthedocs.io/en/latest/index.html when searching for it after reading your post.
Bahamuth is offline   Reply With Quote
Old 20th October 2019, 21:01   #1103  |  Link
Bahamuth
Is it normal that vspipe.exe uses 45% CPU usage?
edit: it did so on a DVD movie (with deinterlace). on a progressive BluRay movie vspipe.exe stays low it seems
Old 20th October 2019, 21:57   #1104  |  Link
sneaker_ger
The vspipe CPU usage includes the VapourSynth filter usage. So with complex filters vspipe usage will be high.
Old 21st October 2019, 02:51   #1105  |  Link
Natty
Noob
Updated
works fine. update custom ver too sometimes if you find it useful and have some free time. there are a few useful ones which others implement. eg keeping rc=crf in beginning of encoding settings.
Natty is offline   Reply With Quote
Old 21st October 2019, 17:35   #1106  |  Link
TomSmith
Originally Posted by TomSmith View Post
I 'reinstalled' Staxrip as well to have a clean version and changed the indexer.
It is the same error:
------- Error Video encoding using x265 3.2+5-gfbe9fef31 Patman -------
Video encoding using x265 3.2+5-gfbe9fef31 Patman failed with exit code: -1073741819 (0xC0000005)
The exit code might be a system error code: Die Anweisung in 0xp verwies auf Arbeitsspeicher bei 0xp. Der Vorgang s konnte im Arbeitsspeicher nicht durchgeführt werden.
---------- Video encoding using x265 3.2+5-gfbe9fef31 Patman ----------
"C:\Program Files (x86)\StaxRip-x64-2\Apps\Support\avs2pipemod\avs2pipemod64.exe" -y4mp T:\temp\StaxRip\smile2_temp\smile2.avs | "C:\Program Files (x86)\StaxRip-x64-2\Apps\Encoders\x265\x265.exe" --crf 13 --output-depth 10 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --hdr --repeat-headers --hrd --aud --frames 197674 --y4m --output T:\temp\StaxRip\smile2_temp\smile2_out.hevc -
avs2pipemod[info]: writing 197674 frames of 24000/1001 fps, 3840x1608,
sar 0:0, YUV-420-planar-10bit progressive video.
y4m [info]: 3840x1608 fps 24000/1001 i420p10 unknown frame count
raw [info]: output file: T:\temp\StaxRip\smile2_temp\smile2_out.hevc
x265 [info]: HEVC encoder version 3.2+5-gfbe9fef31
x265 [info]: build info [Windows][GCC 9.2.0][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x265 [info]: Main 10 profile, Level-5 (Main tier)
x265 [info]: Thread pool created using 16 threads
x265 [info]: Slices : 1
x265 [info]: frame threads / pool features : 4 / wpp(26 rows)
x265 [warning]: NAL HRD parameters require VBV parameters, ignored
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 3
x265 [info]: Keyframe min / max / scenecut / bias: 23 / 250 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2
x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0
x265 [info]: References / ref-limit cu / depth : 3 / off / on
x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress : CRF-13.0 / 0.60
x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip signhide tmvp b-intra
x265 [info]: tools: strong-intra-smoothing lslices=8 deblock sao
avs2pipemod[info]: finished, wrote 30524 frames [15%].
avs2pipemod[info]: total elapsed time is 4999.736 sec.
avs2pipemod[error]: only wrote 30524 of 197674 frames.
Old 21st October 2019, 17:59   #1107  |  Link
Atlantis
AviSynth+ 3.4.0 is released.
https://github.com/AviSynth/AviSynthPlus/releases
Atlantis is offline   Reply With Quote
Old 21st October 2019, 20:01   #1108  |  Link
stax76
stax76's Avatar
Maybe try an alternative way to narrow the cause, in staxrip there are always at least two ways:
AviSynth
VapourSynth
x264
x265
ffms2
l-smash
avs2pipemod
ffmpeg
etc.
I've bookmarked it, thanks.
Old 21st October 2019, 20:21   #1109  |  Link
Patman
Patman's Avatar
Hi Tom,
can you pls share a sample of your file with me? Send me pm and I will test your file with your settings.
Gesendet von meinem HMA-L09 mit Tapatalk
My Builds
Patman is offline   Reply With Quote
Old 21st October 2019, 20:29   #1110  |  Link
Patman
Patman's Avatar
I'm also updating the custom version of x265. I will look at further adjustments and, if useful, integrate them.
My Builds
Old 22nd October 2019, 03:18   #1111  |  Link
Exaris
Inspector Gadget
What are the differences between the included x265 and the Stable Branch VS2019 AVX2 releases from http://msystem.waw.pl/x265/ ?
Exaris is offline   Reply With Quote
Old 22nd October 2019, 17:48   #1112  |  Link
Patman
Patman's Avatar
The included x265 is compiled with gcc 9.2.0 and not with visual studio. An other difference is that the included x265 is packed with upx, what results in smaller filesize. And the included version based on master branch, not on stable branch.
stable branch:
x265 [info]: HEVC encoder version 3.2+5-a3a088a7262f
x265 [info]: build info [Windows][MSVC 1923][64 bit] 8bit+10bit+12bit
master branch:
x265 [info]: build info [Windows][GCC 9.2.0][64 bit] 8bit+10bit+12bit
My Builds
Old 22nd October 2019, 19:45   #1113  |  Link
TomSmith
AviSynth
VapourSynth
x264
x265
ffms2
l-smash
avs2pipemod
ffmpeg
etc.
I've used x264 and x265, avisynth and vapoursynth etc. it's always the same error... Sometimes x264 avisynth is successful but I woult like to use x265...
Old 22nd October 2019, 19:56   #1114  |  Link
stax76
stax76's Avatar
Maybe try another source file and another source filter, by default staxrip uses the filter FFVideoSource which belongs to the ffms2 plugin, except for MP4 where LSMASHVideoSource is the default, that belongs to the l-smash plugin. You can try LWLibavVideoSource as alternative to FFVideoSource. There are multiple ways to do this, for instance before you open a source file, right-click the source filter and then select the filter you want, after that you can open the source file. If that works better you might want to make this filter the default, in that case just ask how to do this. If it's reproducible with a certain file then please upload that file.
Old 23rd October 2019, 14:56   #1115  |  Link
videoh
Definitely sounds like a hardware issue, especially if it happens with other source filters as well. Have you looked into that?
Old 24th October 2019, 14:40   #1116  |  Link
IbrahimKh
Hi, any idea how do I can convert this type of video (VBR) into CBR?
Video
Format                      : HEVC
Format/Info                 : High Efficiency Video Coding
Format profile              : Main 10@L4@Main
Codec ID                    : V_MPEGH/ISO/HEVC
Duration                    : 22 min 35 s
Width                       : 1 424 pixels
Height                      : 1 080 pixels
Display aspect ratio        : 4:3
Frame rate mode             : Variable
Original frame rate         : 23.976 FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 10 bits
I indexed the video but the result was like this (using ffmsindex)
what filter I should use to get proper output?
IbrahimKh is offline   Reply With Quote
Old 24th October 2019, 17:09   #1117  |  Link
Patman
Patman's Avatar
Video
Format                      : HEVC
Color space                 : YUV
Bit depth                   : 10 bits
Test this ffms2 version. If result is still same, right-click into filter-window and add -> FrameRate -> AssumeFPS -> AssumeFPS and select FrameRate 24000/1001.
My Builds
Old 25th October 2019, 16:16   #1118  |  Link
TomSmith
Hi Tom,
Hi Patman!
Hi stax76!
I've done some testing and I get this error with different files and encoders - even at different frames with the same file/encoder.
As I'm the only one with this problem at the moment, I guess it is the x570 Chipset driver or motherboard bios that needs some improvement. Waiting for the next version to test it again. The RAM is good (memtest86 - no errors).
Thank you very much for your help!
Tom
Old 25th October 2019, 22:13   #1119  |  Link
Patman
Patman's Avatar
Hi Patman!
Hi stax76!
Tom
Hi Tom,
I plan to update my system (cpu: ryzen7 3800x, gigabyte x570 elite, g.skill trident z 32gb for AMD) which mainboard you use?
My Builds
Old 26th October 2019, 07:42   #1120  |  Link
Exaris
Inspector Gadget
From there being no commits since October 16th I assume the next stable build is being prepared, is this correct?
aac, hdr, hevc, staxrip, x265
