5th November 2014, 23:40 | #41 | Link | |
eg. subtract(filtered, original).Levels(127, 1, 129, 0, 255) But how useful a mask like that would be on actual footage instead of a still is debatable... or at minimum you would have to tweak different masks for different shots If you still feel something in masktools is contributing to it, and it's not from the pre-exisiting artifacts (which exist in all 3 channels, you can visualize the chroma channels by UtoY() and VtoY() , then test on a clean clip with similar blue gradient. Even a CG gradient will demonstrate an issue if there is a math calculation bug. I just think it's not merely a coincidence that you get "blocks" of magenta here and there that just happen to coincide with the h264 compression artifacts The other sharpening algorithm in Edius probably isn't using this approach of blurring and subtracting. That probably has something to do with it. And even if it is, "subtract" is defined differently in avisynth than other programs like photoshop, after effects , probably Edius etc... .Not only is the formula different, those other programs are working in RGB for their channel operations Last edited by poisondeathray; 5th November 2014 at 23:44. |
6th November 2014, 00:58 | #43 | Link | |
What I meant is you refined the mask for a still, not the video. Unless he uploaded the video somewhere? He mentioned something that suggests holes in the mask. Well there were hardly any holes when I looked, there were no magenta shifts like the unmasked version. It was a very good mask for that still in terms of using masktools, almost as good as if you rotoed it. So I am assuming he is checking and referring to the actual video. What I am saying is there are other scenes, other content, other characteristics to the video, other types of edges. And that perhaps you need to adjust the settings in other shots, threshold values - Or did you think this would work perfectly for everything with those settings without looking at them ? Last edited by poisondeathray; 6th November 2014 at 01:06. |
6th November 2014, 01:30 | #45 | Link | |
But I don't see any big holes with your script on the still image. But what he says suggests either he's messed it up, or actually checking the video (not the stilll), or another video "For some strange reason flat blue here and there becomes flat magenta" - I don't see that with the mask Since we don't know what is going on for sure it's hard to suggest something, so I would wait for clarification I think the artifacts have everything to do with this. I would treat the underlying problem first |
6th November 2014, 07:37 | #47 | Link |
Hi everybody - thank you for your precious contribution.
I am most happy do upload a short video sample. Would 1 or max. 2 seconds be ok ?, because I have very very low upload speed and canopus avi are huge. Would it be best to just upload the out of camera original ? Could you recommend a storage site where I could upload without any registersoftwaredownloadwhatever hassel ? I can do it only on the weekend cause I got that stuff at home. Thanks. |
8th November 2014, 22:22 | #52 | Link |
I am back. After some research I realized, that I made a terrible mistake. Though I have to admit, it was tricky: The magenta artefacts did not derive from the sharpening nor from the quality of the original MOV, it happened in virtual dub! Without being clear how important they were I used default values for color depth which were: Decompression format: Autoselect Output format to compressor/display: 24 bit RGB (888) The latter caused a significant drop of fine color resolution hence magenta artefacts and fince color blocks. It occured with a simple avisource() command already. After having changed output format to "Same as decompression format" the artefacts and tonal influences were gone! I am so sorry, guys, for having driven you mad with this. Anyway I appreciated a lot that you were trying to help me. I am sure now that all we discussed will make a very good fine sharpening solution - miles better than standard or in-camera sharpening. I'll be back soon with a summary. Thank you all! Last edited by Hotte; 8th November 2014 at 22:31. |
9th November 2014, 16:43 | #53 | Link |
I'm Siri
comparisons (mcdeconvsharp (yeah, I decided to name dat bad ass slow filter this) screenshot will be added when the process is done since its just wicked slow, changed some things, the result would be different from (slightly better than) the screenshot showed earlier, and it runs even slower now, 0.000fps according to x264)
9th November 2014, 22:08 | #54 | Link |
thank you for this comparison. mcdeconvsharp clearly makes the race! However watching at this samples I come to the conclusion that our finesharpening approach is not the right solution for low-res material like this clip. It enhances small blocks way to much. Bottom line I find LSFmod better. But things are completely different when it comes to 1920x1080 material. Here #1 (Hotte) and #25 (feisty2) of this thread are doing a very good job to pull out fine detail. 1. Original. Intentionally sort of soft: https://mega.co.nz/#!AlBHAZQC!vUTmGb...97f_hLW5wtnUJw 2. Edius internal sharpener with moderate strength of 22. No bad detail but too much edge halo, shimmery stones, too much detail contrast. Not so pleasing: https://mega.co.nz/#!hspGCRBQ!nKwjH0...t5u7qzAVuxgEsA 3. #25 from this thread. Very good detail enhancement. Well controlled edge halos/detail contrast: https://mega.co.nz/#!x14zmYJT!pDgzym...KP0iSif-IRliXg 4. My #1 from this thread with s=70, w=1 plus dehalo_alpha to reduce edge halos and supersampling=1.5. Very fast. sharpening technique seems similar to 3. dehalo-alpha improves edge halos. https://mega.co.nz/#!ZlYV1D5C!28oXZN...lpcfC9AfZ-vzbg 5. LSFmod (defaults="slow"). For me seems much closer to 2. than to 3. or 4. https://mega.co.nz/#!UxZXAByY!nO4vGn...vb5lX-bKidU3jo Fine detail can be seen best in the trees of the forest on the left side under the description text. Edge halos show nicely at the edge of the castle wall. Last edited by Hotte; 10th November 2014 at 06:31. |
10th November 2014, 01:25 | #55 | Link |
I'm Siri
yeah, the kernel of mcdeconvsharp is deconvolution, sure it brings hell lot of noises, but noise is not the concern of this (sharpen/deconvolution) step, all sharpen filters enhance noise more or less, just deconvolution enhances noise more wildly
thats why it aint done yet, i'm writing a denoise suite to clean the craps (including deconvolution noise) i dont see noise as an artifacts at the step of "sharpening" cuz we are gonna remove it right afterward |
10th November 2014, 01:45 | #56 | Link |
I'm Siri
personally I think the most important feature that a sharpening filter must have is keeping the image looking natural not oil painted after the process
thats the reason i decided to write a new sharpening filter at the first place |
10th November 2014, 06:38 | #57 | Link |
I think oilpainted effects are in most cases a result of edge halos in mid detail regions where outlines get doubled into one another. With the castle clip this makes stones "shimmer". The used approach does not really provoke the effect with FullHD material and Dehalo_alpha helps to put this down additionally. I feel this is very controlled here. I also tried to reduce grain with Mdegrain2 and Mdegrain3. The effect is very subtle. Is there something more effective with motion compensation ?
10th November 2014, 07:48 | #59 | Link |
feisty2, I am trying to understand how degrain works here. (How) can the very subtle degraining effect in this code being made stronger ? Changing thSAD only makes a very minor difference. Thanks.
source = (source clip) sharp0 = (sharpened clip) sharpD = mt_makediff(source,sharp0) zeroD = sharpD.mt_lut("x",Y=-128) sup1 = source.MSuper(pel=2,sharp=2) sup2 = sharpD.MSuper(pel=2,sharp=2,levels=1) bv1 = sup1.MAnalyse(isb=true, delta=1,overlap=4) fv1 = sup1.MAnalyse(isb=false,delta=1,overlap=4) bv2 = sup1.MAnalyse(isb=true, delta=2,overlap=4) fv2 = sup1.MAnalyse(isb=false,delta=2,overlap=4) bv3 = sup1.MAnalyse(isb=true, delta=3,overlap=4) fv3 = sup1.MAnalyse(isb=false,delta=3,overlap=4) sharpD.MDegrain3(sup2,bv1,fv1,bv2,fv2,bv3,fv3,thSAD=400) source.mt_makediff(last,U=2,V=2) |
detail, fine, full-hd, sharpen, unsharp mask |
