Old 21st March 2015, 19:19   #1021  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Hey, I'm in luck today
I found out that the very first thing done by my cleaner function is the one that starts acting up.
SetFilterMTMode("DEFAULT_MT_MODE", 2)
DGSource("hotfuzztest.dgi")
Flux5framesT(th=2,chromamotion=true)
Prefetch(4)
and Flux5framesT along with what it needs:
function Flux5framesT(clip c, int "th", int "thC", bool "chromamotion")
th  = default(th,7)
thC = default(thC, (chromamotion == true) ? th : 0)
med  = c.TMedian2(chromamotion=chromamotion)
avg  = c.temporalsoften(2,th,thC,24,2)
medD = mt_makediff(c,med,U=chromamotion?3:1,V=chromamotion?3:1)
avgD = mt_makediff(c,avg,U=chromamotion?3:1,V=chromamotion?3:1)
DD   = mt_lutxy(medD,avgD,"x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?",U=chromamotion?3:1,V=chromamotion?3:1)
output = c.mt_makediff(DD,U=chromamotion?3:1,V=chromamotion?3:1)
return output
function TMedian2(clip c, bool "chromamotion")
Median2( c.selectevery(1,-2), c.selectevery(1,-1), c, c.selectevery(1,1), c.selectevery(1,2), chromamotion=chromamotion )
Function Median2(clip "input_1", clip "input_2", clip "input_3", clip "input_4", clip "input_5", string "chroma", bool "chromamotion")
{# median of 5 clips from Helpers.avs by G-force
chromamotion = default(chromamotion, true)
chroma = default(chroma, (chromamotion == true) ? "process" : "copy first") #default is "process". Alternates: "copy first" or "copy second"
#MEDIAN(i1,i3,i5)
Interleave(input_1,input_3,input_5)
chroma == "process" ? Clense() : Clense(grey=true)
#chroma == "process" ? MedianBlurT(0,0,0,1).merge(last,0.5).MedianBlurT(0,0,0,1) : MedianBlurT(0,-1,-1,1).merge(last,0.5).MedianBlurT(0,-1,-1,1)
m1 = selectevery(3,1)
#MAX(MIN(i1,i3,i5),i2)
m2  = input_1.MT_Logic(input_3,"min",chroma=chroma).MT_Logic(input_5,"min",chroma=chroma).MT_Logic(input_2,"max",chroma=chroma)
#MIN(MAX(i1,i3,i5),i4)
m3  = input_1.MT_Logic(input_3,"max",chroma=chroma).MT_Logic(input_5,"max",chroma=chroma).MT_Logic(input_4,"min",chroma=chroma)
Interleave(m1,m2,m3)
selectevery(3,1)
chroma == "copy first" ? last.MergeChroma(input_1) : chroma == "copy second" ? last.MergeChroma(input_2) : last
Return(last)
I think these two plugins are the only ones that are needed: https://drive.google.com/file/d/0Bze...ew?usp=sharing
EDIT: when replacing the two "chroma ==" lines with the MedianBlurT version in the Median2 function, I just get a crash when opening the script.
EDIT2: In fact, in AVS+ the function doesn't seem to do anything. Comparing it with the original clip doesn't show any differences, with SEt's MT build the changes are obvious.
Old 21st March 2015, 20:54   #1022  |  Link
ultim
AVS+ Dev
ultim's Avatar
Originally Posted by Boulder View Post
I was thinking more on the lines of finding out if there are possible problems in memory handling as ultim said he's looking to make the cache handling more robust. Then again, I seem to get the script to stall even with SetMemoryMax(256) and two threads.
Yes the caches need some fine tuning. Currently they work great until memory starts running out.
It would certainly help a lot to be able to test with your scripts. If you use a lot of helper scripts, just post them too If you don't want to make them public, maybe you can PM or e-mail them to me?
EDIT: Oh, you made a new post while I wrote my own. Thanks, I'll check it out.
AviSynth+
ultim is offline   Reply With Quote
Old 22nd March 2015, 06:50   #1023  |  Link
colours
colours's Avatar
reallylongscript
I know this is not very relevant, but I'm seeing a whole lot of optimisation potential there. Not tested, but should produce identical results and be faster.
function Flux5framesT(clip c,int "th",int "thC",bool "chromamotion")
	th  = default(th, 7)
	thC = default(thC, chromamotion ? th : 0)
	med = chromamotion ? ytouv(c.utoy8().median5t(), c.vtoy8().median5t(), c.median5t()) : c.median5t().mergechroma(c)
	avg = c.temporalsoften(2, th, thC, 24, 2)
	output = interleave(c, med, avg).clense(grey=!chromamotion).selectevery(3,1)
	return output
function median5t(clip src)
{ # from here
	function min(clip a, clip b) {return mt_logic(a, b, mode="min")}
	function max(clip a, clip b) {return mt_logic(a, b, mode="max")}
	src
	last + trim(framecount()-1,-1).loop(5)
	bcmin = min(SelectEvery(2, -1), SelectEvery(2, 0))
	bcmax = max(SelectEvery(2, -1), SelectEvery(2, 0))
	demin = bcmin.SelectEvery(1, 1)
	demax = bcmax.SelectEvery(1, 1)
	x = max(bcmin, demin)
	y = min(bcmax, demax)
	a = SelectEvery(2, -2)
	f = SelectEvery(2, 3)
	Interleave(a, x, y, f).Clense(grey=true).SelectEvery(4, 1, 2)
	trim(0,length=src.framecount())
Say no to AviSynth 2.5.8 and DirectShowSource!
colours is offline   Reply With Quote
Old 22nd March 2015, 10:06   #1024  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thanks for those, I'll test them and replace the old ones if they are indeed faster The old ones have sometimes been posted here on this forum and I've borrowed them as a small pre-cleaner function to the MC'd denoiser.
Old 22nd March 2015, 11:47   #1025  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Flux5FramesT needed just the line "chromamotion = default(chromamotion, true)" so I added that one since I very rarely disable chroma motion detection.
However, the initial problem still remains, a test with AVSMeter stalls the process at some point. I'm also getting CPU usage below 25% (1 core) even with four threads, maybe that's something to look at (caching again?)
Old 22nd March 2015, 11:47   #1026  |  Link
jones1913
random user
Originally Posted by noee View Post
I've been testing with AVS+/MT mode w/QTGMC. So far, I haven't checked numbers against SETs 2.6RC1, but fwiw, in 64bit version, AVS+ will complete an encode that fails with the older (JoshyD?) 64-bit build.
Have you tried yet? If so, what kind of numbers do you see?
Do you mean that you run QTGMC with 64 bit AVS? Until now I assumed that not all needed plugins are available as 64 bit version.
Here are my results with QTGMC in MT mode on AMD FX 8320 (8 core):
AVS 2.6:
SetMTMode(3, 4)
LWLibavVideoSource("sample.m2v")
SetMTMode(2)
QTGMC(Preset="Medium")
SelectEven()
Distributor()
AVSMeter 1.9.8.0 (x86)
AviSynth 2.60, build:Feb 20 2015 [03:16:45] (2.6.0.5)
Active MT Mode: 2
Number of frames:                 1754
Length (hh:mm:ss.ms):     00:01:10.160
Frame width:                       720
Frame height:                      576
Framerate:                      25.000 (25/1)
Colorspace:                       YV12
Frames processed:               1754 (0 - 1753)
FPS (min | max | average):      5.680 | 91306 | 43.94
Memory usage (phys | virt):     585 | 604 MB
Thread count:                   65
CPU usage (average):            74%
Time (elapsed):                 00:00:39.919
AVS+:
SetFilterMTMode("DEFAULT_MT_MODE",2)
SelectEven()
Prefetch(4)
AviSynth+ 0.1 (r1779, MT, i386) (0.1.0.0)
Frame width:                       720
Frame height:                      576
Colorspace:                       YV12
FPS (min | max | average):      3.676 | 114785 | 33.88
Memory usage (phys | virt):     398 | 414 MB
Thread count:                   104
CPU usage (average):            56%
Time (elapsed):                 00:00:51.768
BeHappy Audio Transcoder > <Doom9 forum> <Gleitz forum> <GitHub>
MP4.tool GUI for MP4Box & L-SMASH muxer > https://www.mediafire.com/folder/3i6y6cbkyhblm/MP4.tool
jones1913 is offline   Reply With Quote
Old 22nd March 2015, 12:43   #1027  |  Link
Stereodude
I've got it working several years ago with AVIsynth x64. I don't recall it being much faster in 64-bit though. It was a giant pain to find x64 versions of all the plugins.
Stereodude is offline   Reply With Quote
Old 22nd March 2015, 13:03   #1028  |  Link
noee
Yes, that seems to be the case. My scripts with QTGMC are quite simple and when it would work in 64bit, it was about 3% faster than 32bit MT (SET).
Win7Ult || RX560/4G || Ryzen 5
noee is offline   Reply With Quote
Old 22nd March 2015, 13:05   #1029  |  Link
Groucho2004
Groucho2004's Avatar
Distributor()
Don't put that in the script unless you specified "InvokeDistributor=0" in AVSMeter.ini.
That goes for pretty much every application that uses AVISynth(MT) except ffdshow and some piping tools that don't call Distributor() internally.
Old 22nd March 2015, 13:46   #1030  |  Link
jones1913
random user
I have indeed set "InvokeDistributor=0" because initially I had some problems get this to run with AVS+, so I tried several things.
OK I didn't know that, thanks.
Old 22nd March 2015, 14:17   #1031  |  Link
chainik_svp
1. You need to set SetFilterMTMode("LWLibavVideoSource",3)
2. If you want to compare performance do it either in singe-threaded mode or with maximum CPU load (with 9+ threads). Your comparsion with 4 threads on 8-threads CPU shows nothing.
SVPflow motion interpolation
chainik_svp is offline   Reply With Quote
Old 22nd March 2015, 15:43   #1032  |  Link
Groucho2004
FYI - The "InvokeDistributor()" setting is ignored in all Avisynth versions that don't implement "Distributor()".
Old 22nd March 2015, 15:47   #1033  |  Link
Groucho2004
He used 4 threads in both cases, I don't see anything wrong with that.
Maximum CPU load or CPU load in general means very little. The most sensible thing would be to put CPU load and processing time in relation and compare that.
Old 22nd March 2015, 18:10   #1034  |  Link
chainik_svp
Because AVS and AVS+ have completely different thread schedulers and "4" is not a "number of threads" but just one of input parameters to the scheduler. For AVS+ official point of view is given in the function name "Prefetch" - "4" is number of frames calculated in advance. Which is also not true .
Those numbers can only be compared after normalization to 100% CPU load.
AVS: 43.94 fps / 74% CPU load = 59.38 fps
AVS+: 33.88 fps / 56% CPU load = 60.05 fps
But such estimation gives too much error value.
Old 22nd March 2015, 18:41   #1035  |  Link
jones1913
random user
You're right, I wrongly assumed that the LWLibav filter is already specified in avs_plus_mt_modes.avsi file.
Though that has only a small effect on the result:
SelectEven()
Prefetch(4)
Frame width:                       720
Frame height:                      576
Colorspace:                       YV12
FPS (min | max | average):      3.741 | 121742 | 35.30
Memory usage (phys | virt):     350 | 366 MB
Thread count:                   68
CPU usage (average):            55%
Time (elapsed):                 00:00:49.690
Well, "shows nothing" is maybe a little exaggerated. Also I have never stated to perform an absolute valid and technical perfect test.
Anyway I repeated the test with your suggestions:
SetMTMode(3, 10)
SetMTMode(2)
SelectEven()
Active MT Mode: 2
Frame width:                       720
Frame height:                      576
Colorspace:                       YV12
FPS (min | max | average):      3.636 | 167395 | 54.97
Memory usage (phys | virt):     634 | 674 MB
Thread count:                   107
CPU usage (average):            96%
Time (elapsed):                 00:00:31.906
SelectEven()
Prefetch(10)
Frame width:                       720
Frame height:                      576
Colorspace:                       YV12
FPS (min | max | average):      2.018 | 87337 | 48.62
Memory usage (phys | virt):     703 | 731 MB
Thread count:                   123
Time (elapsed):                 00:00:36.077
The gap becomes smaller, but the tendency remains the same.
You posted this while I typed my above text and I have no idea if my results are meaningful, but I'll leave it as it is now...
Old 22nd March 2015, 19:15   #1036  |  Link
Groucho2004
Originally Posted by ultim View Post
You enable MT by placing a single call to Prefetch(X) at the *end* of your script, where X is the number of threads to use.
Hm. So, ultim's explanation of "prefetch" is wrong in this post?
Old 22nd March 2015, 20:18   #1037  |  Link
martin53
so you are writing your own avisynth plugin (cool!), and obviously one of the first things you have to do in your code is to include the avisynth header. But which one? ...
what about avisynth+'s header?
the headers of avisynth+ are up to date in every aspect and provide the greatest possible compatibility. By using avisynth+'s headers, applications and plugins can cleanly compile and run in 32-bits and 64-bits. It is 100% compatible to the latest 32-bit development on the old avisynth 2.6 project, while supporting all 64-bit binaries. And of course, you can use it regardless if you support multithreading or not. Furthermore and importantly, it is fully compatible to installations of the avisynth 2.6, avisynth-mt, avisynth64, and of course the avisynth+ projects, so your plugin/application will be able to run on any user's machine.
I'm sure there is reason in the things explained in that post, but:
Avisynth+'s header includes <avs/config.h>, <avs/capi.h> and <avs/types.h> which in turn include <avs/cpuid.h> and so on.
I feel this is not plugin writer friendly.
#include <...> in contrast to #include "..." makes success with the Filter SDK compiling instructions harder because it requires to further extend the standard library directories settings in the compiler.
Though I think I'd personally be able to manage that, and the files are on GitHub (easy to download), I still feel it's complicated and should not be like that. At quick glance I couldn't find what happened to the GetVarDef function in the avisynth+ header, either, so I'll preliminarily stick to the standard Avisynth 2.6 one.
martin53 is offline   Reply With Quote
Old 22nd March 2015, 21:19   #1038  |  Link
chainik_svp
I'm just saying "4 threads" in AVS are different from "4 threads" in AVS+. Performance of AVS and AVS+ can't be compared in that way.
So there're only two reliable ways for comparsion: single thread performance and full system performance with 100% load.
Old 22nd March 2015, 21:28   #1039  |  Link
chainik_svp
yeah, and now it IS interesting thanks, I think now I should test the performance myself... (for the SVP usage )
Old 23rd March 2015, 01:13   #1040  |  Link
qyot27
qyot27's Avatar
https://github.com/AviSynth/AviSynthPlus/pull/54
From https://github.com/AviSynth/AviSynthPlus/pull/53:
partial-2   GetVarDef is one of a group of several similar functions that seem to be gone in
        avsplus, so don't bother with it.
