29th September 2012, 13:23 | #161 | Link |
Thanks for fixing 'remember window position' in 1.0.3.1.
Another issue I often encounter is when launching fullscreen is enabled, exiting fullscreen has inconsistent behavior. To test: 1. Enable options>playback>fullscreen 'launch files in fullscreen' 2. close the player and open a new file 3. Exit fullscreen Result is on primary display it minimizes and takes 2 clicks to open the window, on extended display (no taskbar) it goes to a window. Expected is it goes to a window no matter if it's primary or extended display. |
29th September 2012, 13:41 | #162 | Link |
Try this build http://aleksoid.tosei.ru/Test/mpc-be...ew_hang_fix.7z - fix hang/crash when preview enable and open BD/m2ts and quick close Explorer.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
29th September 2012, 15:28 | #163 | Link | |
I would like to use the player in "Frame Only" mode but then the only way to close it is by pressing ALT+F4 (as far as I know at least), and I would prefer a way through the GUI. Some questions: 1) I used the "old" MPC-BE and I knew that updates to MPC-HC would be included in it, so is it still the same? 2) I was wondering if it makes sense to disable all DXVA since I have a powerful enough PC (Intel Core i5-2500 & ATI 5770)? I've heard that DXVA can cause artifacts sometimes. 3)How should I set the subtitle options for best quality (in particular regard to anime)? I've set "Sub pictures to buffer" at 0, "Maximum texture resolution" at dekstop, "allow animation when buffering" enabled and "round up to power of two" disabled. Thanks. |
29th September 2012, 16:09 | #164 | Link | |
Thanks ! I'll do more testing later
Intel UHD Graphics 750; Win 10 22H2 |
29th September 2012, 16:45 | #165 | Link |
Just trying out MPC-BE. I tried to setup its options exactly as mpc-hc. One major difference for me. By default with MPC-BE it seems to play some unforced japanese subtitles in blu-rays. I'm using LAV Splitters and have it set to only display forced subtitles. In mpc-hc I get exactly as I expect, only forced subtitles.
Whats making MPC-BE override this? Should LAV Splitter be deciding what subtitles to play, not mpc? Whatevers in mpc is overriding this, its picking the wrong language :P I love the interface though, the seekbar is lovely, and meant I can hide the "Status" bar, to make more room for playback. Cheers devs Last edited by mark0077; 29th September 2012 at 16:47. |
29th September 2012, 17:20 | #166 | Link | |
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) |
29th September 2012, 17:57 | #167 | Link | |
DXVA can save power, if you have a damaged file, better to disable it for these. |
29th September 2012, 18:35 | #169 | Link |
Is this possible?
Player view default to compact mode (2), seekbar default to check (Ctrl+1) and minimize, maximize and exit at the right corner... like the image below or this ---> http://archangelx2.deviantart.com/ar...-v-1-200263705 Last edited by ney2x; 29th September 2012 at 18:39. |
29th September 2012, 20:00 | #170 | Link |
Not sure how they'd do that ney, wouldn't it overlap the video? I think they could put an exit button on the control bar. How about there is an option for a minimal control bar, and an advanced, or just allow us to select which buttons we want with tick boxes in options?
29th September 2012, 22:28 | #173 | Link |
30th September 2012, 03:13 | #175 | Link | |
http://forum.doom9.org/showpost.php?...&postcount=138 in next release.
30th September 2012, 11:22 | #176 | Link | ||
30th September 2012, 12:45 | #177 | Link |
30th September 2012, 16:43 | #180 | Link |
Why is it every player of this sort requires DirectX 9.0c update? Aren't it already included inside Windows 7 and Windows 8? Do Newer Direct X not compatible with previous version? And can we not get rid of this dependencies?
