Old 23rd August 2010, 14:56   #1  |  Link
svavaroe
Incompatible AVI's from mencoder on PS3 ?
Hello.
I'm having trouble encoding XVID AVI files with mencoder on my Mac and be able to play
them on my PS3 system.
I'm currently using the xvidenc package from (http://xvidenc.sourceforge.net/).
Now, the PS3 system dosn't like any of those AVI files. Just dosn't play them at all.
Tho, if I take the AVI file and regenerate a new AVI from AVIMUX or some other Windows program
it will play just fine. So the encoding must be OKEY ?
I'm curious about the XVID encoding options. Maybe they are confusing ps3 ?
Currently I use these options in mencoder :
"vqmax=5:me_quality=6:vhq=3:max_bframes=2:bvhq=1:trellis:quant_type=mpeg:chroma_me:chroma_opt:hq_ac:nolumi_mask:closed_gop:noqpel:nogmc:autoaspect"
Dosn't matter if I use DIVX, DX50 or XVID as a Fourcc option.
Also I have changed from nopacked, and to packed bitstream option.
Any success stories with mencoder generated AVI files for PS3 ?
Thanks in advance.
Best regards,
Svavar - Reykjavik - Iceland
svavaroe is offline   Reply With Quote
Old 23rd August 2010, 15:24   #2  |  Link
Inspector.Gadget
If re-muxing fixes your issue, the problem is likely to be either the structure of the AVI container itself (OpenDML versus non-OpenDML), the type of interleaving used in writing the file, or perhaps (because some applications default to one or the other) whether or not your bitstream is "packed".
Inspector.Gadget is offline   Reply With Quote
Old 23rd August 2010, 16:25   #3  |  Link
svavaroe
Also, passing the "-noodml" option to mencoder does not work.
So with OpenDML, and skipping the OpenDML does not work from mencoder.
Old 23rd August 2010, 16:34   #4  |  Link
svavaroe
These are technical info from the files.
FILES That work (after i remuxed them with AVIMUX)
#1 With OpenDML
General
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 69.4 MiB
Duration : 2mn 35s
Overall bit rate : 3 752 Kbps
Writing application : AVI-Mux GUI 1.17.8, Aug 30 2008 12:36:58
Video
Format : MPEG-4 Visual
Format profile : AdvancedSimple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 2mn 35s
Bit rate : 3 294 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.318
Stream size : 60.9 MiB (88%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 2mn 35s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 8.28 MiB (12%)
Alignment : Aligned on interleaves
Interleave, duration : 64 ms (1.60 video frames)
Interleave, preload duration : 192 ms
#2 With NO-OpenDML
General
Format : AVI
Format settings : rec
Duration : 2mn 35s
Overall bit rate : 3 751 Kbps
Video
Codec ID : XVID
Duration : 2mn 35s
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Colorimetry : 4:2:0
Audio
Format : AC-3
Codec ID : 2000
Duration : 2mn 35s
Bit rate : 448 Kbps
And here is the file straight from mencoder that dosn't work.
#3 With NO-OpenDML
General
Format : AVI
File size : 93.5 MiB
Duration : 2mn 36s
Overall bit rate : 5 028 Kbps
Writing application : MEncoder SVN-r29352-snapshot-4.0.1
Writing library : MPlayer
Video
Format settings, Matrix : Default (MPEG)
Muxing mode : Packed bitstream
Codec ID : XVID
Duration : 2mn 35s
Bit rate : 4 599 Kbps
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.444
Stream size : 85.1 MiB (91%)
Audio
Format : AC-3
Codec ID : 2000
Duration : 2mn 36s
Bit rate : 448 Kbps
Resolution : 16 bits
Video delay : 40ms
Stream size : 8.33 MiB (9%)
Alignment : Split accross interleaves
Interleave, duration : 497 ms (12.43 video frames)
Interleave, preload duration : 500 ms
avi, mencoder, ps3, xvid
