Old 17th October 2019, 21:44   #57641  |  Link
Asmodian
It is definitely doing something different... that target resolution can only be set by the player.
madVR options explained
Old 17th October 2019, 21:50   #57642  |  Link
Cowboydude99
I could see that, but what would do that!? ha
If it plays every other 4K video properly, it seems that either there is a problem with the file itself, or maybe an incorrect tag or something in the software player?
Cowboydude99 is offline   Reply With Quote
Old 17th October 2019, 21:52   #57643  |  Link
Asmodian
Try MPC-HC or Zoom Player... or something else? If it is reproducible there are many here who could investigate the technical details.
Old 17th October 2019, 21:56   #57644  |  Link
Klaus1189
Try MPC-BE
https://disk.yandex.ru/d/r7JYQ2NjHvE4lA/Beta/1.5.4
Old 17th October 2019, 22:06   #57645  |  Link
Cowboydude99
Thanks! I'll give it a shot.
Old 18th October 2019, 14:04   #57646  |  Link
Blight
Software Developer
Blight's Avatar
Has anyone using Windows 7 recently noticed MadVR leaking GPU memory?
For some reason, after playing some media, I see Zoom Player's GPU memory usage go up to 1.8gb (out of 2gb, with wdm/csrss taking the rest) and eventually MadVR will not be able to create the Direct3D device or just show an empty image.
Even after closing the graph, I can see that Zoom Player uses GPU memory (which it doesn't natively, only the filters allocate GPU memory), which leads me to suspect it's a leak.
I haven't been able to find that culprit, the only major piece of software I installed was office 365 and windows update patches.
Tried updating to the latest NVidia drivers, didn't make a difference.
Windows 7 64bit fully patch.
NVIDIA GT1030 latest drivers.
LAV Decoding (DXVA2 native).
MadVR set to use:
1. windowed overlay rendering.
2. 6cpu/6gpu queue size.
3. presenting (windowed mode) 6 frames in advance.
4. chroma upscaling : lanczos 3 taps
5. image downscaling : lanczos 3 taps
6. image upscaling : lanzos 3 taps
7. use DXVA chroma upscaling when doing (both).
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
Old 18th October 2019, 14:58   #57647  |  Link
Cowboydude99
Well you were right. I looked at the tags for the file within the software. It had some odd playback options set. Once I cleared them, it worked as expected.
Thanks so much. I didn't even realize the player had playback options per file.
All good now!
Old 18th October 2019, 15:40   #57648  |  Link
@Blight
i guess you are playing UHD with 2 GB vram?
i would not call it a leak but madVR can use more Vram from time to time. GPU-z and other tools Vram usages is sadly very inaccurate and
iknow that madVR uses more Vram when some settings setting are changed until it is restarted. the same can happening if a webbrowser in the back.
queues of 4 and a backbuffer of 4 gave me the best results on these systems with nvidia this was totally different with AMD.
DXVA2 native may cost more vram give copyback a try.
Old 18th October 2019, 18:31   #57649  |  Link
Blight
Software Developer
Blight's Avatar
@huhn:
With regards to the leak, I reported it after MadVR's graph was released, in theory it shouldn't leave any vram allocated to zplayer.exe in process explorer.
Yes, it's really bad with 4K video, but even at 1080P eventually it will ran out of vram and report the Direct3D device can't be created (and sometimes even ZP's regular windows UI will appear as completely white since there is no vram to display it).
I'll try copy-back, initial testing shows it drops vram use to ~1GB but nearly doubles the GPU usage (from ~40% to ~77%).
Sadly, there's is only 1 passively cooled card with more than 2GB vram I could find, the palit kalmx 1050, but it's not really available locally.
Shame there isn't an 1030 with 4GB.
Yaron Gur
Old 18th October 2019, 18:52   #57650  |  Link
Klaus1189
Take a look at semi passively cooled cards. Fans are off when using it for lighter loads.
Old 18th October 2019, 20:16   #57651  |  Link
there is something not working as intended there. if you mean 1080p output the source resolution shouldn't affect it to much.
most performance cards can be changed in a way that they can run passive. it's just quite some work.
MadVR's graph
is that from a test build?
Old 19th October 2019, 12:18   #57652  |  Link
Blight
Software Developer
Blight's Avatar
@hunn
No, the latest final release, but it may be a side-effect of running out of vram.
I'm aware that I can probably buy a water-cooling block for higher end cards, but it's too much of a hustle for me these days.
Yaron Gur
Old 19th October 2019, 17:15   #57653  |  Link
el Filou
el Filou's Avatar
I use a media center app that never exits even when putting the HTPC to sleep so it frequently runs for a month non-stop between Windows updates, and I've never had a problem with system or graphics memory leaks when using madVR with it. I have a very different software setup though.
@Blight Have you tested other players just to check if the same thing happens with them too or if it's just with ZoomPlayer?
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 22nd October 2019, 11:07   #57654  |  Link
mclingo
I havent been following the other HDR thread, out of interest has there been any news on the next MADVR update, V1.0, I thought it was coming soon.
OLED EF950-YAMAHA RX-V685-Win101809-4K 444 RGB 60hz-AMD RX580 19.9.2
KODI DS - MAD/LAV 92.14/0.74.1 - 3D / DIRECT3D11 / MADVR 10bit
Old 22nd October 2019, 11:55   #57655  |  Link
SamuriHL
SamuriHL's Avatar
I very much doubt it'll be soon but they're still working on tone mapping. And making huge gains.
Sent from my SM-G975U using Tapatalk
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 22nd October 2019, 13:57   #57656  |  Link
BetA13
cosmic entity
BetA13's Avatar
@Blight
i also have Windows 7 (fully patched) and using an gtx670 with 2gb Vram and i didnt notice those issues..
Since we have both win7 and a 2gb GFX Card, im offering my help for any testing if needed..
Best Regards, BeTa
BetA13 is offline   Reply With Quote
Old 22nd October 2019, 15:53   #57657  |  Link
Siso
Siso's Avatar
Does anyone encountered an issue - madvr detects the monitor as new, after each restart. I have to point the 3dlut path everytime, and to choose the display as a digital monitor.
Old 22nd October 2019, 16:29   #57658  |  Link
Manni
I had a similar issue with build 1806 that went away when I upgraded windows to build 1903. That's with the latest nVidia driver and the latest madVR test build. If you bring everything back in time it should work again
Win10 Pro x64 b1903 MCE
i7 3770K@4.0Ghz 16Gb@2.18Ghz EVGA GTX 1080 Ti SC2 11Gb@2GHz 436.48 RGB Full 8bits
MPC-BE/LAV/MadVR/jRiver/MyMovies V5.25
Denon X8500H>HD Fury Maestro>JVC RS2000
Old 22nd October 2019, 16:35   #57659  |  Link
Siso
Siso's Avatar
I'm on windows 7 ultimate 64 bit. Video drivers 385.28.
Old 22nd October 2019, 16:45   #57660  |  Link
Manni
No idea then, unless you're using more than one monitor, which can cause similar issues.
