Old 16th October 2019, 09:11   #28901  |  Link
FilipeAmadeuO
Originally Posted by AmigaFuture View Post
I came across this problem with multiple M2TS files with my older LG Blu-ray player (with Hard Drive). I really noticed it when I bought my copy of 50 Shades of Grey..ripped and processed it...and there were transition errors that you're typing about. Once I found another good LG player, and Ch3vr0n helped me realize that Cinavia isn't used as much anymore...I decided to get a new one. That movie, plus others..all the transition errors are gone. For a bit, I was thinking JD really goofed in BD-RB. Nope.. So, I'm with JD..I betcha it's your player, too. Now I have a note on that player.."Don't play non-original movies before 2015 or so with this." with a description of why. The newer player supports SRTs much better and other features the other didn't have (Don't care about the "apps".)
What I'm hoping is coming some time soon is the ability to play a Blu-ray root from USB..or ISO mount from USB.. Then not use BD-RE so much.. Would be useful for Cameras and more. Dreaming visionary is fun.
I understand that players can make some difference but only the rebuilded version have small shutter problem. If I play original there is no shutter.
I believe that it’s something not 100% perfect.
Regarding player the OPPO is considered the best player around so I am not talking about low quality player
FilipeAmadeuO is offline   Reply With Quote
Old 16th October 2019, 09:30   #28902  |  Link
Sharc
Experience has shown that the 'best' players are often the most picky ones. 'Nonames' are often more forgiving
Old 16th October 2019, 13:07   #28903  |  Link
FilipeAmadeuO
Picky and OPPO normally does not mix
I can assure you that it can play every format you can imagine
Even ISO BD /ISO UHD / Folder BD /Folder UHD / 80gb MKV / Atmos...
Old 16th October 2019, 17:08   #28904  |  Link
MrVideo
MrVideo's Avatar
Even [...]Atmos...
Any player that can send the raw audio bitstream down the HDMI pipe can play every audio format. It is up to the audio device to decode the audio bitstream.
My Total Eclipse 2017 Photos
Old 17th October 2019, 22:04   #28905  |  Link
AmigaFuture
AmigaFuture's Avatar
Nothing is ever perfect. I don't care how often people use that word today. When you use a ripper then the end result doesn't have what the original disc does. That's why there are stutter effects. My older BD Player plays originals well. Probably TSMuxer also adds to it too, ...at least for older/some players. Not wanting to argue, The Best isn't always The Best. Again, nothing is ever perfect, done, final, cannot be added to.
That doesn't qualify it as "The Best". But yet, you commented about stutters. Hmm.. Wink.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 17th October 2019, 22:19   #28906  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Hmmm... I can assure you that genuine OPPO players running official software don't support .ISO image files!
Old 17th October 2019, 22:50   #28907  |  Link
drmih
Just trying a UHD disc and it finished fine but the colours are off - is there an extra setting I'm missing.
https://mega.nz/#!N4EgRCwb!FNLukItz1...kx9Pl8G_fpx2AU
https://mega.nz/#!p0dkTYKD!g3GccuBZK...uzbkLMOT1vnZzI
drmih is offline   Reply With Quote
Old 18th October 2019, 15:06   #28908  |  Link
jdobbs
But... the rebuilt disc is on a BD-25 or BD-50 -- both of which have different maximum bitrates than the original disc.
Website: www.jdobbs.net
Old 18th October 2019, 16:25   #28909  |  Link
cartman0208
In the main movie?
I had a similar issue but only in the extras of the disc.
cartman0208 is offline   Reply With Quote
Old 18th October 2019, 18:45   #28910  |  Link
drmih
Originally Posted by cartman0208 View Post
In the main movie?
There was only a main feature - Tosca. I did use Good bd-25+ setting as the disc was no bigger than a bd-50, so it might be related to that if you used fast encode for the extras.
Old 18th October 2019, 21:06   #28911  |  Link
FilipeAmadeuO
The rebuild disc is BD-66 as the original
Only change is a subtitle replacement. No vídeo or audio encoding was done.
Old 19th October 2019, 05:32   #28912  |  Link
AmigaFuture
Appreciate this. I was wondering about that...seeing the list. I'm *not* up-to-date on all the new Tech. Oh, how I used to be.. Since I commented about BD root on USB.
Old 23rd October 2019, 19:22   #28913  |  Link
FilipeAmadeuO
Tested and it´s much better.
Now the FF works perfect.
The REW works perfect at speeds > 2x. The REW at 1x and 2x i can see bitrate changing on oppo player but image is freezed.
You are on the right track
Can you just please test other issue on LAST JEDI.
At 00:02:05 in a scene transition i have another "non smooth transition".
The transition is when it moves from 00007.m2ts -> 00018.m2ts on the 00800.mpls.
So something is still not perfect on m2ts transitions...
Have you found the FF/REW issue on Dolby Vision discs ?
The experimental build of BD-RB that you have sent me was much better
Old 23rd October 2019, 20:01   #28914  |  Link
jdobbs
No. The build I created for you to test just added the dolby vision track to the CPI() table. It improved things, but apparently didn't fix it. So I really don't have a good idea as to why you are having issues.
If it requires all the I frames of the dolby vision track to match those of the reencoded HEVC, that could become a problem for sources that require reencoding. I'd have to investigate how hard it would be to get around.
I may just add a hidden option to tell BD-RB not to include dolby vision, that way you could at least get an HDR version without FF/REW problems.
To All:
Is anyone else experiencing this issue? So far I think I've only gotten this report from FilipeAmadeuO. It would be nice to know if it is limited to only a certain player before I spend a lot of time on it.
Old 23rd October 2019, 20:36   #28915  |  Link
Michi
I can confirm the FF/REW issue on dolby vision discs. I test "the last jedi" and the 4 James Bond discs.
Michi is online now   Reply With Quote
Old 23rd October 2019, 20:56   #28916  |  Link
jdobbs
Thanks. What kind of player are you using?
Old 23rd October 2019, 20:59   #28917  |  Link
FilipeAmadeuO
No. The build I created for you to test just added the dolby vision track to the CPI() table. It improved things, but apparently didn't fix it. So I really don't have a clue why you are having issues.
To All:
Jdobbs
The improvement you have done it’s on the right track.
I think if there is there is no negative side effect it’s better than the working version.
Why not add the Dolby vision layer as a selectable video ? Then uses can select the layer or not.
Old 23rd October 2019, 21:46   #28918  |  Link
Michi
I'm using a Sony x800 MKII.
Old 24th October 2019, 01:15   #28919  |  Link
FilipeAmadeuO
Do you have any jerky video transition between m2ts on LAST JEDI (for example) ?
Old 27th October 2019, 17:58   #28920  |  Link
desierto300w
Estimado
Estaba comprimiendo el recital de The Cure – 40 Live (Curaetion 25 + Anniversary) (2019), Quality: Blu-ray
Container: BDMV
Video codec: MPEG-4 AVC
Audio codec: PCM, DTS
Video: MPEG-4 AVC Video / 35986 kbps / 1080i / 29,970 fps / 16:9 / High Profile 4.1
Audio 1: English / LPCM Audio / 2.0 / 48 kHz / 2304 kbps / 24-bit
Audio 2: English / DTS-HD Master Audio / 5.1 / 48 kHz / 5152 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Size: 40.27 + 43.57 GB
He intendado dos veces pero no se puede extraer las dos pistas de audio que tienen 5.152 kbps
Los registros del BD REBUILDER SON:
- [12:17:05] Processing: VID_00001 (4 of 4)
- [12:17:05] Extracting A/V streams [VID_00001]
- Extracting video streams [VID_00001]
- Extracting audio/subtitle streams [VID_00001]
- AV frame too large (53045 bytes). Increase AV buffer.
- Extracting audio streams [VID_00001]
- Error in attempt to extract audio.
[12:23:34] - Failed to retrieve audio, aborted
Hay alguna solución al problema?
desierto300w is offline   Reply With Quote
