Old 17th July 2008, 20:40   #41  |  Link
Romario
Romario's Avatar
Location: Qetchua mountains in Peru, and Klingon battlecruiser D'Mar
What's going on with Mplayer for Linux, can you compile it, dear LoRd_MuldeR ?
Live long and prosperLive long and prosperLive long and prosper
Romario is offline   Reply With Quote
Old 17th July 2008, 20:49   #42  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
When using Linux you should get MPlayer via your Package Manager.
Also compiling MPlayer yourself is much easier under Linux, because most distributions come with the required tools and libs.
I'm not planning to offer binaries for Linux. I don't make the Windows binaries either...
Old 19th July 2008, 16:44   #43  |  Link
LoRd_MuldeR
Software Developer
MPlayer for Windows 2008-07-19
[2008-07-19]
* MPlayer binaries updated to SVN-r27323
Note: This release is supposed to fix a crash regarding font-config.
Old 20th July 2008, 01:43   #44  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by hkazemi View Post
I'm getting a crash when trying to install 'MPUI.2008-07-13.Full-Package.exe' on WinXP SP3.
I did the following during a Custom Installation attempt:
-unchecked 'Set File Associations'
-unchecked 'Create Shortcuts' (included Desktop and Quicklaunch icons)
I get the crash right after I click next on the installation location screen. (MPUI.2008-07-13.Full-Package.exe has encountered a problem and needs to close. ...) The detail is a crash in nsisarray.dll, offset 00001da8
This crash most likely was caused by a limitation in NSISArray! A workaround has been added to UMUI recently:
Originally Posted by SuperPat
The crash happened when the script tried to read items (with the NSISArray:Read function) added in the eighth lists. To corrected it, I simply limited the search of subdirectory to only 7 levels instead of eight as before. NSISArray is limited to eight lists, I did not understand why it crashed when it read items at the eighth...
So the potential installer crash will be fixed in next release of MPlayer for Windows ...
Old 21st July 2008, 18:28   #45  |  Link
LoRd_MuldeR
Software Developer
Here is a new experimental test build of MPlayer for Windows:
MPUI.2008-07-21.Full-Package.TEST-1.exe
1. Updated NSIS to 2.38 and also updated UMUI to 2008-07-19
2. I disabled "skinned" buttons, because some people seem to encounter problems
3. The potential crash in NSISArray should be fixed
Old 26th July 2008, 20:04   #46  |  Link
LoRd_MuldeR
Software Developer
MPlayer for Windows 2008-07-26
[2008-07-26]
* SMPlayer updated to Version 0.6.1 (SVN-r1583)
* NSIS updated to v2.38, UMUI updated to 2008-07-19
* Workaround for "Vista missing buttons" bug
Old 27th July 2008, 21:23   #47  |  Link
Clobon
Chaotarch
Clobon's Avatar
I'm sorry to be troubling you again, but the newest package is crashing
no matter what...
It would only play back mp4 files but only after 30sec of... initialisation??
Ausgewählter CPU Typ:
  ·Intel Pentium 4 (MMX, SSE, SSE2)
Ausgewählte Einstellungen:
  ·Benutze 'Lanczos' Software Skalierung (Hohe Qualität)
  ·OpenGL Renderer anstatt Overlay benutzen (besser, aber benötigt OpenGL 2.0)
If I try to play back any other file it would tell me:
C:/Programme/MPlayer für Windows/MPlayer.exe
 -noquiet -nofs -sub-fuzziness 1 -identify -slave -vo
gl:yuv=2:force-pbo:ati-hack -ao dsound -zoom -nokeepaspect
-priority abovenormal -framedrop -wid 1446766
-monitorpixelaspect 1 -fontconfig -font Tahoma -subfont-
autoscale 1 -subfont-text-scale 5 -subcp ISO-8859-1 -subpos
100 -volume 100 -nocache -osdlevel 1 -vf-add screenshot -af
equalizer=0:0:0:0:0:0:0:0:0:0 -sws 9 -noslices
J:\_HL_FU~2.OGM
MPlayer Sherpya-SVN-r27323-4.2.4 (C) 2000-2008 MPlayer Team
CPU: Intel(R) Core(TM)2 Duo CPU     E6750  @ 2.66GHz (Family: 6, Model: 15, Stepping: 11)
CPUflags:  MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
Setting process priority: abovenormal
Playing J:\_HL_FU~2.OGM.
ID_VIDEO_ID=0
[Ogg] stream 0: video (FOURCC DIV3), -vid 0
ID_AUDIO_ID=0
[Ogg] stream 1: audio (Vorbis), -aid 0
ID_AUDIO_ID=1
[Ogg] stream 2: audio (Vorbis), -aid 1
[Ogg] stream 3: subtitles (SRT-like text subtitles), -sid 0
ID_SUBTITLE_ID=0
ID_AID_0_LANG=English
ID_SID_0_LANG=English
[Ogg] Language for -sid 0 is '-slang "English"'
Demuxer info Language changed to English
Ogg file format detected.
VIDEO:  [DIV3]  640x480  24bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
Clip info:
 Language: English
ID_CLIP_INFO_NAME0=Language
ID_CLIP_INFO_VALUE0=English
ID_CLIP_INFO_N=1
ID_FILENAME=J:\_HL_FU~2.OGM
ID_DEMUXER=ogg
ID_VIDEO_FORMAT=DIV3
ID_VIDEO_BITRATE=0
ID_VIDEO_WIDTH=640
ID_VIDEO_HEIGHT=480
ID_VIDEO_FPS=23.976
ID_VIDEO_ASPECT=0.0000
ID_AUDIO_FORMAT=vrbs
ID_AUDIO_BITRATE=0
ID_AUDIO_RATE=48000
ID_AUDIO_NCH=2
ID_LENGTH=1408.61
ID_SEEKABLE=1
[gl] using extended formats. Use -vo gl:nomanyfmts if playback fails.
Opening video filter: [screenshot]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffdivx] vfm: ffmpeg (FFmpeg DivX ;-) (MSMPEG-4 v3))
ID_VIDEO_CODEC=ffdivx
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
MPlayer interrupted by signal 11 in module: init_audio_codec
ID_SIGNAL=11
- MPlayer crashed by bad usage of CPU/FPU/RAM.
  Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
  disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
  It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
  gcc version. If you think it's MPlayer's fault, please read
  DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
  won't help unless you provide this information when reporting a possible bug.
The CPU was detected correct (Intel P4)...
The 2008-07-17 package (which I reinstalled) works perfectly.
Btw: OS is XP Pro 32, GraCa is a NVidia 8800 GS 320, driver version is 175.16
(drivers are working fine so far).
Does anyone else experience such behavior?
HF, Clobon
Clobon is offline   Reply With Quote
Old 27th July 2008, 21:36   #48  |  Link
LoRd_MuldeR
Software Developer
Well, between the "2008-07-17" release and the latest release, I have updated the MPlayer binaries:
MPlayer SVN-r27305 versus MPlayer SVN-r27323
The only problem I encounter with the latest builds so far is that some (most) of my Ogg/Vorbis files won't play
I tried to report the problem in the MPlayer IRC channel, but I didn't get much attention, because I use Sherpya's patched builds.
Already filed a bugreport on Sherpya's tracker at SourceForge, but no replay so far...
You may join the discussion here:
http://sourceforge.net/tracker/?atid...75&func=browse
Old 29th July 2008, 07:41   #49  |  Link
Hogge
Hi mulder!First of all thanks for a great mediaplayer the greatest i think.But the last 3 build i think is crashing,when starting avi files,sometimes it sound like an old vinyl hacking,like it trying to start,and then it crashes.I get the error code 62097.Now im using a build from 0426-2008 and its working flawless.Can you please check the logs Mulder.
C:/Program Files/MPlayer for Windows/MPlayer.exe -noquiet -nofs -sub-fuzziness 2 -identify -slave -vo gl:yuv=2:force-pbo:ati-hack -ao dsound -zoom -nokeepaspect -priority abovenormal -fontconfig -font Tahoma -subfont-autoscale 1 -subfont-text-scale 5 -subcp ISO-8859-1 -subpos 100 -volume 100 -nocache -osdlevel 1 -vf-add screenshot -channels 6 -af volnorm=2,equalizer=0:0:0:0:0:0:0:0:0:0 -sws 9 -noslices C:\Users\Hogge\Desktop\The.Key.2008.STV.DVDRip.XviD-DOMiNO\domino-thekey.avi
CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4400+ (Family: 15, Model: 107, Stepping: 1)
3DNow supported but disabled
3DNowExt supported but disabled
Playing C:\Users\Hogge\Desktop\The.Key.2008.STV.DVDRip.XviD-DOMiNO\domino-thekey.avi.
AVI file format detected.
ID_VIDEO_ID=0
[aviheader] Video stream found, -vid 0
ID_AUDIO_ID=1
[aviheader] Audio stream found, -aid 1
VIDEO:  [XVID]  672x368  12bpp  23.976 fps  996.5 kbps (121.6 kbyte/s)
Clip info:
 Software: VirtualDubMod 1.5.10.2 (build 2540/release)
ID_CLIP_INFO_NAME0=Software
ID_CLIP_INFO_VALUE0=VirtualDubMod 1.5.10.2 (build 2540/release)
ID_CLIP_INFO_N=1
ID_FILENAME=C:\Users\Hogge\Desktop\The.Key.2008.STV.DVDRip.XviD-DOMiNO\domino-thekey.avi
ID_DEMUXER=avi
ID_VIDEO_FORMAT=XVID
ID_VIDEO_BITRATE=996480
ID_VIDEO_WIDTH=672
ID_VIDEO_HEIGHT=368
ID_VIDEO_FPS=23.976
ID_AUDIO_FORMAT=8192
ID_AUDIO_BITRATE=256000
ID_AUDIO_RATE=0
ID_AUDIO_NCH=0
ID_LENGTH=4642.14
ID_SEEKABLE=1
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
ID_VIDEO_CODEC=ffodivx
Opening audio decoder: [liba52] AC3 decoding with liba52
AUDIO: 48000 Hz, 2 ch, s16le, 256.0 kbit/16.67% (ratio: 32000->192000)
ID_AUDIO_RATE=48000
ID_AUDIO_NCH=2
Selected audio codec: [a52] afm: liba52 (AC3-liba52)
AO: [dsound] 48000Hz 2ch s16le (2 bytes per sample)
ID_AUDIO_CODEC=a52
Starting playback...
VDec: vo config request - 672 x 368 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.83:1 - prescaling to correct movie aspect.
ID_VIDEO_ASPECT=1.8261
[swscaler @ 0pecdba4]No accelerated colorspace conversion found.
[swscaler @ 0pecdba4]using unscaled yuv420p -> rgb24 special converter
VO: [gl] 672x368 => 672x368 Planar YV12  [zoom]
And here is the other.
ID_VIDEO_ID=0
ID_AUDIO_ID=1
Clip info:
ID_CLIP_INFO_N=1
ID_DEMUXER=avi
ID_VIDEO_WIDTH=672
ID_VIDEO_HEIGHT=368
ID_VIDEO_FPS=23.976
ID_AUDIO_RATE=0
ID_AUDIO_NCH=0
ID_LENGTH=4642.14
ID_SEEKABLE=1
ID_AUDIO_RATE=48000
ID_AUDIO_NCH=2
ID_AUDIO_CODEC=a52
I would be happy if we can solve this i love your mplayer full version.Thanks Hogge
Hogge is offline   Reply With Quote
Old 29th July 2008, 14:06   #50  |  Link
LoRd_MuldeR
Software Developer
Your logs don't show any errors
Old 29th July 2008, 14:17   #51  |  Link
Hogge
Strange,it crashes and sorry not error code,exit code 62097...
I saw on Smplayer forum a guy with same problem exit code same as me.It sounds like its trying to start it like start engine of the car but the movie doesnt start.And the crash with 2 logs these 2 i posted on the second one it says exit code 62097..I guess i will have to use the older version.The only old i have is from 0426-2008.Its great.
Old 29th July 2008, 14:27   #52  |  Link
Hogge
Sorry for spamming,I updated my Nvidia card to latest drivers 175.19 and i tried the latest build and i keep the setting from the 0426 build,it seems to work for now strange.But i still like to know the exit code 62097 what does it mean.Do you know Mulder.Thanks again for a great Media Player!!!
Old 29th July 2008, 14:35   #53  |  Link
LoRd_MuldeR
Software Developer
I got no idea what the exit code means and unless there is some error message on the log I cannot help you...
Old 29th July 2008, 18:55   #54  |  Link
burro08
burro08's Avatar
LoRd_MuldeR how do u set the default aspect ratio??? when i open a file i want the AR to be automatically 5:4
thank you
burro08 is offline   Reply With Quote
Old 29th July 2008, 19:55   #55  |  Link
LoRd_MuldeR
Software Developer
MPlayer/SMPlayer will display each video with the correct aspect ratio by default.
If you really want, you can enforce the desired aspect ratio via "Video -> Aspect Ratio -> 5:4"
Old 29th July 2008, 21:10   #56  |  Link
Hogge
Now its stalling again,i guess i will have to use an older build!!
Old 29th July 2008, 21:18   #57  |  Link
LoRd_MuldeR
Software Developer
If you can reproduce the problem, please file a bug report at:
http://sourceforge.net/tracker/?group_id=205275
Old 2nd August 2008, 04:55   #58  |  Link
Martin H
Hi LoRd_MuldeR
Many thanks for your work on MPUI, it's much appreciated
Could you please tell me if your MPUI compile(v1.2-pre3.38) includes other changes besides the "-enable-color-console" fix and the little UI changes(sorry, i don't know delphi...) ?
Btw, on my P4 1.7GHz, then the MPlayer build that's included in the latest official MPUI package(dev-SVN-r26251-3.4.2 compiled with CPU runtime-detection), is faster and lighter than the P4 optimized "Sherpya" build(Sherpya-SVN-r27323-4.2.4)...
I have just tested it again with a DivX movie :
CPU : ~10% Vs. ~20%
RAM : ~18mb Vs. ~25mb
And it's a 1.8mb smaller build, as the MPUI author strips out some un-needed and non-media-player related stuff...
Do you have similar experiences and do you know if it's because of the stripped components, or if that older build where just faster in general ?
Personally, i would love if you in addition to your Light-installer, then also would provide a compressed archive with the optimized and UPX'ed "Sherpya" builds and the UPX'ed MPUI build, but that's just me...
Thank's in advance.
Martin H is offline   Reply With Quote
Old 2nd August 2008, 14:25   #59  |  Link
LoRd_MuldeR
Software Developer
I compiled the MPUI sources as you can find them on my homepage. That is a modified version, by me.
And there is no such thing as "configure" in Delphi. You just load the project file (.dpr) and click the "Run" button. That's it.
For my MPUI builds I use Delphi 7 Professional. You also need the "TNT Unicode Controls" for MPUI...
About the MPlayer builds: I simply grab the latest builds by Sherpya as those are usually up-to-date and they run stable.
Keep in mind that "optimized" binaries are often bigger, as they are optimized for speed, not for size (think of "loop unrolling" and stuff).
My installer will already UPX the binaries after extraction. If you don't want that, run it with /NOPACK switch...
Old 2nd August 2008, 16:35   #60  |  Link
Martin H
Yes, i know...
Yes, i know...
Yes, i know...
Yes, i know...
I just asked you if you had made other changes in your v1.2-pre3.38 build of MPUI, besides the "-enable-color-console" fix and the little UI changes ?
And then if you had noticed that the MPlayer build in the latest official MPUI package(dev-SVN-r26251-3.4.2 compiled with CPU runtime-detection) did use less cpu and ram than the P4 optimized "Sherpya" build in your latest installer(Sherpya-SVN-r27323-4.2.4) :
CPU : ~10% Vs. ~20%
Thank's in advance...
mplayer, mpui, player, smplayer, win32
