Old 19th October 2019, 15:18   #17561  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
24 GiB file copy test
And are those adapters suitable ??
yes
Old 19th October 2019, 15:37   #17562  |  Link
Pauly Dunne
Pauly Dunne's Avatar
Interesting, but I'm now undecided, I don't want to get 2 x 512Gb Pro's, meaning one for Temp, one for Encoding....which would benefit more with a Pro ?, as compared to say the Plus, or the Adata XPG ??
Not poorly done, just doin' it my way !!!
Pauly Dunne is offline   Reply With Quote
Old 19th October 2019, 15:53   #17563  |  Link
Atak_Snajpera
Adata xpg has very good write speed up to 60GiB so it should fit to your needs. You should be able to combine chunks and mux in less than 2 minutes. Still huge improvement from your old ssds with ~100MiB/s write speed.
Old 20th October 2019, 01:35   #17564  |  Link
Pauly Dunne
I think your crystal ball is working again, 'cause that's exactly what I was thinking...if it's good for 60Gb, that is about the size of the final encode.
OK, so most of these posts have been about getting the combining of chunks, and the muxing process done a lot faster...this should also affect the initial copying & indexing of the job, correct ??
And one other thought about the 970 Pro...would it be another option to get a 1tb "stick", and then partition it, in say a 60/40 split....I know it's 2 drives on the same "stick", but with the performance of it, it should be able to still read & write fast, at the same time.
Old 20th October 2019, 12:00   #17565  |  Link
Atak_Snajpera
Indexing will be most likely slowed down by performance of your CPU (single core). Remuxing is basicaly a copy process.
Old 20th October 2019, 12:31   #17566  |  Link
skylinekiller
So it appears the "Default.style" file is just for decoration. I just downloaded, updated and reinstalled the latest RipBot. No matter what numbers I change, the font is always the same. Where can i change the default subtitle characteristics? The RipBot264\Tools\AviSynth plugins\VSFilter seems to be a dead-end.
Is this something that can be remedied in the next update?
skylinekiller is offline   Reply With Quote
Old 20th October 2019, 17:57   #17567  |  Link
Atak_Snajpera
Latest version of VSfilter indeed stopped reading .style file for .srt subtitles. You will have to always convert .srt subtitles to .ass/.ssa and disable shadow directly. I could automate this process if this really annoys you.
Old 20th October 2019, 22:18   #17568  |  Link
skylinekiller
That what I have been doing since it broke. It does take away the luxury of it being automated. It would bee nice if you could automate the process with the attached settings in a future update. I'm sure there are more pressing things to fix, but I do a lot of foreign films with subtitles.
Thank you
Old 21st October 2019, 08:51   #17569  |  Link
Pauly Dunne
Originally Posted by Pauly Dunne View Post
And what of my simple feature request, on RB gui's main window, the current core version/build is displayed (for quick reference)
I thought you could do something like this :-
http://www.mediafire.com/file/o6ktod...d5/RB.jpg/file
There must be someway to "link" it to the info in the Tool's list, so that it updates itself.
Old 21st October 2019, 14:46   #17570  |  Link
slalom
slalom's Avatar
dtsma track is recognised as dts in the audio section of the job
dtsma track was recognised as dtsma in the past
i7 3930K @ 4.2GHz on GA-X79-UD3 16GB DDR3
i5-750 @ 3.36GHz 8GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 21st October 2019, 15:47   #17571  |  Link
Atak_Snajpera
Bug in mediainfo
https://forum.doom9.org/showthread.p...64#post1887964
Old 22nd October 2019, 18:50   #17572  |  Link
byteshare
ByteShare
byteshare's Avatar
Send me 100MiB sample with that BT.2020 (12-bit) transfer characteristics.
Not sure what you changed but is working with Core 2019.10.19 Thank you!
Old 22nd October 2019, 20:19   #17573  |  Link
Atak_Snajpera
Thank you
Done. Edit default.style in \Tools\SRTtoSSA folder
Old 23rd October 2019, 01:07   #17574  |  Link
Pauly Dunne
Got the latest update this morning, but something went wrong (tried it twice)
2019-10-23 10:00:25 : New section [SRTtoSSA] detected
2019-10-23 10:00:25 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/SRTtoSSA.zip to D:\RipBot264v1.25.0\Updates\SRTtoSSA.zip
2019-10-23 10:00:25 : [ERROR] File http://atak-snajpera.5v.pl/ripbot264update/SRTtoSSA.zip could not be downloaded!
2019-10-23 10:00:25 : Downloading finished.
And how do you access what this does ??
Such a shame that there isn't an easy .sub to .srt conversion
Old 23rd October 2019, 02:04   #17575  |  Link
ReinerSchweinlin
Just doing some encodes on some cartoon and anime stuff. While previewing, I noticed many duplicate frames. Some time ago, I used Donads DUP Filter to optimize this - so I tried to use it in Ripbot... But itīs too old, 32Bit, etc...
I could use some help implementing a filter like the old DUP. Any hints anyone?
Old 23rd October 2019, 03:36   #17576  |  Link
byteshare
ByteShare
byteshare's Avatar
Yeah, that is because .subs are imaged based so it isn't as simple to translate them.
Either you'll need to find an updated or alternative filter for 64B support or use an old version of RB
With anime it is pretty normal to have duplicate frames without variable frame rate. Using x265 I don't find it is a major impact on file size or encoding time.
Old 23rd October 2019, 13:49   #17577  |  Link
Pauly Dunne
Yep, thank goodness for SubtitleEdit
Old 23rd October 2019, 14:39   #17578  |  Link
skylinekiller
Thank you very much, but I don't see a default file in that folder. Do I copy the one from VSFilter folder and use it in the SRTtoSSA folder?
Attachments Pending Approval
File Type: jpg ripbot subs.jpg
Old 23rd October 2019, 15:02   #17579  |  Link
Pauly Dunne
Are you sure you have that folder ??
I got the latest update earlier today, and there was a problem downloading that item.
There's an ssatosrt folder, but not the srttossa..
Old 23rd October 2019, 15:05   #17580  |  Link
sneaker_ger
I tried the vsfilter from the package in the start post. It still works. Make sure the .style file ends with a newline.
