17th June 2011, 23:32 | #721 | Link | |
typo lover
my repositories |
18th June 2011, 20:16 | #722 | Link | |
18th June 2011, 21:03 | #723 | Link |
In MeGUI just check "Add pre-rendering job". That will first run the avisynth script to output a lossless huffyuv file, then encode that file in a second pass. The intermediate file will be around 200Gb per hour at HD. It will be deleted after processing if you have "Delete intermediate files" checked in Options.
If you don't have the temporary space: - Don't use a pre-rendering job - reduce settings/threads so it can cope - Use avs2yuv (or avs2pipe?) to pipe the avisynth output to a separate x264 process to do the encoding. Each process will get it's own memory space. I haven't tried this, I saw the idea here, though I'm sure others use this method for the same reasons. Last edited by -Vit-; 18th June 2011 at 21:06. |
19th June 2011, 15:05 | #724 | Link | |
I'll try and check how much my PC can do and how much faster it's compared to single thread. I have 24GB of RAM, so this should not be a problem. Andrew |
19th June 2011, 19:46 | #725 | Link | |
I have tried avs2yuv but it always seemed to go slower AND be less stable for me. I also tried reducing settings as per your guide but making it through anything longer than about 15-30min (real-time) of HD video is a crapshoot. I just wanted to make sure there wasn't some alternative that was as stable as, but faster than, simply running QTGMC in non-multithreaded mode. I don't seem to ever get crashes that way, and it's quicker than doing 2 passes (lossless via mencoder->lossy via x264), but obviously significantly slower than 1 pass running QTGMC in multithreaded mode. How much memory should one have to have a good chance of avoiding these crashes, anyway? I have 4GB (Windows 7 x64) with no other programs running besides basically bare minimum Windows processes and Microsoft Security Essentials. I just love this filter so much for interlaced content that I want to do everything in my power to get it into my workflow whenever feasible |
19th June 2011, 23:37 | #726 | Link |
You need 2Gb spare memory for 32-bit avisynth. 4Gb and a low system load sounds OK.
The alternative posted above, splitting an encode into chunks, is the other way to get more speed whilst retaining stability. It's not the speedup of SetMTMode but it can help. However, to take best advantage you may need more memory - that approach relies on creating several processes rather than several threads. Each process can have its own 2Gb. One other thing: mencoder was dropped from MeGUI quite a while ago, in favor of ffmpeg for lossless output. I use the dev builds, dunno if that change has made it to the stable builds yet. |
23rd June 2011, 16:30 | #727 | Link |
hi
how i could make a timecodes' file correctly with tdecimate? if i use qtgmc+selecteven+tdecimate(+ovr) then there are some zones to 24fps but that really are to 30fps (tfm+tdecimate+ovr detect them correctly ._.). Any idea for fix this? thx |
26th June 2011, 16:58 | #728 | Link |
partially-informed layman
PAL to NTSC
I've started testing the following script for PAL DV > NTSC-for-DVD conversion, as an improvement over my previous method of blending frames in Vegas Pro. Initial results are promising, although of course it's slow. I would welcome any comments or suggestions for improvement. Thanks
#Frameserve from Vegas Pro in YUY2. AviSource("d:\fs.avi") ColorYUV(levels="TV->PC") #Reverses frameserving levels squeeze QTGMC() Spline36Resize(720,480) #Could save lossless intermediate here super = MSuper(pel=2) backward_vec = MAnalyse(super, isb = true) forward_vec = MAnalyse(super, isb = false) MFlowFps(super, backward_vec, forward_vec, num=60000, den=1001) AssumeBFF() SeparateFields() SelectEvery(4,0,3) weave() |
26th June 2011, 18:35 | #729 | Link |
Nick,
Is your source interlaced? If so, does this script give correct results? [edit] Forget this post. I didn't see the QTGMC line. Last edited by johnmeyer; 26th June 2011 at 18:36. Reason: Realized QTGMC was used |
26th June 2011, 20:02 | #730 | Link |
Can use QTGMC's own motion vectors, which it exposes for later use. This will be faster and likely give better vectors. But then you must resize after the flow
#... QTGMC( SubPel=2 ) # SubPel must match pel in MSuper below super = MSuper(levels=1, pel=2) # Only need multiple levels for MAnalyse MFlowFps(super, QTGMC_bVec1, QTGMC_fVec1, num=60000, den=1001) Spline36Resize(720,480) #... This process is detailed in the QTGMC docs under the heading "Accessing QTGMC Motion Vectors" Or you could try Interframe to do the 50->60fps. The script is still essentially MFlowFPS, but it has been tweaked heavily. Last edited by -Vit-; 26th June 2011 at 20:39. |
26th June 2011, 21:57 | #731 | Link |
Thanks very much -Vit-. I hadn't realised that Interframe could do framerate conversions other than doubling.
So now I want to try your 2 suggestions; The MFlowFps script using QTGMC vectors and the following script using InterFrame: Code:
#Frameserve from Vegas Pro in YUY2 AviSource("d:\fs.avi") ColorYUV(levels="TV->PC") #Reverses frameserving levels squeeze QTGMC() Spline36Resize(720,480) InterFrame(FlowPath="C:\Program Files\AviSynth 2.5\plugins\") AssumeBFF() SeparateFields() SelectEvery(4,0,3) weave() Also, RemoveGrainSSE3.dll is in the InterFrame dependencies folder, but I'm running RemoveGrainSSE2.dll with QTGMC. I guess I should go for one or the other, but which? |
27th June 2011, 15:38 | #732 | Link |
I skimmed the SVP modded MVTools code a while back and the changes were fairly limited in scope, so I imagine it will still work for normal use [that's just a guess though, I don't actually use it myself]. Just note it's based on 2.5.11.1. The latest version is 2.5.11.2, which fixes a crash bug that affected QTGMC with certain resolutions/blocksizes. But that shouldn't affect your use case though.
Use RemoveGrainSSE2. There was a bug in RemoveGrainSSE3 until the final version, but that one has some changed and undocumented functionality so it shouldn't be relied on. There is no noticeable difference between the two anyway. |
27th June 2011, 23:56 | #733 | Link | |
The one with the highest number But seriously it won't make much difference, you can use either one |
28th June 2011, 12:01 | #734 | Link |
Thanks -Vit- and SubJunk. I ran the InterFrame script with the original RemoveGrainSSE2.dll and mvtools2.dll supplied in -Vit-'s required plugins pack and I had no problems.
I found little difference in the quality of the result, but in my single-threaded environment the MFlowFps method was about 7-8% faster than the InterFrame method. Also InterFrame doesn't support YUY2, and I prefer not to use YV12 in this case because it gives me this chroma shift error when I take interlaced YV12 into CCE Basic for MPEG-2 encoding. So anyway, the following script gives a stunningly good PAL>NTSC conversion compared to anything I've tried before (which is A LOT of software methods). So good in fact that I think I can start just offering NTSC DVDs instead of both PAL and NTSC depending on territory (my original footage is PAL, which won't play worldwide). Thank you! Code:
#Frameserve from Vegas Pro in YUY2 AviSource("d:\fs.avi") ColorYUV(levels="TV->PC") #Reverses frameserving levels squeeze QTGMC( SubPel=2 ) # SubPel must match pel in MSuper below super = MSuper(levels=1, pel=2) # Only need multiple levels for MAnalyse #super = MSuper(levels=1, pel=2, hpad=16, vpad=16) # For faster QTGMC presets MFlowFps(super, QTGMC_bVec1, QTGMC_fVec1, num=60000, den=1001) Spline36Resize(720,480) AssumeBFF() SeparateFields() SelectEvery(4,0,3) weave() |
28th June 2011, 12:37 | #735 | Link | |
(Though, straight from the guts, those jaggies don't really look like they're re-interlacing related, but rather like something's going seriously wrong. It pretty much looks like aliasing from a simple standard deinterlacer!) Oh, BTW ... if the frameserved output really has a PC-->TV levels squeeze, then that's not good at all ... in particular for underwater shots. (During level squeeze information is getting lost, and you won't get that loss back by expanding again....)
- We´re at the beginning of the end of mankind´s childhood - My little flickr gallery. (Yes indeed, I do have hobbies other than digital video!) Last edited by Didée; 28th June 2011 at 12:42. |
28th June 2011, 14:54 | #736 | Link | ||
30th June 2011, 19:17 | #737 | Link |
This is where I have ended up and I'm really happy with the results, but didn't test the NTSC>PAL script much since I don't have original SD NTSC footage.
(Note that Vegas works internally in RGB, so I'm using the path of least conversions) PAL to NTSC Code:
#Frameserve PAL source from Vegas in RGB24 format AviSource("d:\fs.avi") AssumeBFF() ConvertToYUY2(interlaced=true, matrix="PC.601") QTGMC( SubPel=2 ) #SubPel must match pel in MSuper below super = MSuper(levels=1, pel=2) #Only need multiple levels for MAnalyse #super = MSuper(levels=1, pel=2, hpad=16, vpad=16) # For very fast and quicker QTGMC presets MFlowFps(super, QTGMC_bVec1, QTGMC_fVec1, num=60000, den=1001) Spline36Resize(720,480) SeparateFields() SelectEvery(4,0,3) weave() Code:
#Frameserve NTSC source from Vegas in RGB24 format AviSource("d:\fs.avi") AssumeBFF() ConvertToYUY2(interlaced=true, matrix="PC.601") QTGMC( SubPel=2 ) # SubPel must match pel in MSuper below super = MSuper(levels=1, pel=2) # Only need multiple levels for MAnalyse #super = MSuper(levels=1, pel=2, hpad=16, vpad=16) # For very fast and quicker QTGMC presets MFlowFps(super, QTGMC_bVec1, QTGMC_fVec1, num=50, den=1) Spline36Resize(720,576) SeparateFields() SelectEvery(4,0,3) weave() Code:
#Frameserve 1080-50i source from Vegas in RGB24 format AviSource("d:\fs.avi") AssumeTFF() ConvertToYUY2(interlaced=true, matrix="PC.601") Spline36Resize(720,height) QTGMC("faster", sharpness=0, SubPel=2) #SubPel must match pel in MSuper below super = MSuper(levels=1, pel=2) # Only need multiple levels for MAnalyse #super = MSuper(levels=1, pel=2, hpad=16, vpad=16) # For very fast and quicker QTGMC presets MFlowFps(super, QTGMC_bVec1, QTGMC_fVec1, num=60000, den=1001) Spline36Resize(width,480) blur(0.0,1.0) sharpen(0.0,0.75) #Adjust 2nd value between 0.5 and 1.0 to taste SeparateFields() SelectEvery(4,0,3) Weave() Last edited by nhope; 1st July 2011 at 05:19. |
30th June 2011, 21:28 | #738 | Link | |
This v/hpad requirement is only there because QTGMC still contains a workaround for a bug in MVTools 2.5.11.1 and earlier, fixed in the latest version 2.5.11.2. I kept the workaround in case people didn't upgrade their MVTools. The next QTGMC version will drop the workaround and will use the default v/hpad in general (and will require the latest version of MVTools). |
1st July 2011, 08:33 | #740 | Link | |
Still, if the next version of QTGMC requires the latest MVTools, I do hope somebody can compile a 64-bit version of that. 64-bit has consistently been more stable and faster than 32-bit for me, although the newest version of NNEDI3 has somewhat closed the gap considerably. Also, on a slightly OT note, if somebody can post a guide on how we can do our own 64-bit compilations that would be great. |
