13th November 2013, 10:30 | #12523 | Link | |
Nope.
23rd November 2013, 12:06 | #12524 | Link |
Sorry if this has been asked before - but this thread is really long...
Last time I looked eac3to could not handle AAC audio files, probably because I do not have Nero 7 installed. Since I have no intention to install Nero 7 I would like to ask if current versions of eac3to can handle AAC sources by using other decoders like ffdshow or faad. Cheers manolito |
23rd November 2013, 12:14 | #12525 | Link |
From the help screen:
eac3to v3.27, freeware by madshi.net ... Supported source formats: ... (6) AAC audio |
23rd November 2013, 12:22 | #12526 | Link |
Yes, I'm weird.
Actually, eac3to still need "Nero Audio Decoder 2" (from Nero 7) to decode AAC. Currently, it can't use any other DirectShow decoders or libavcodec to do that.
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain |
23rd November 2013, 14:21 | #12528 | Link | |
All you need is Nero AAC Codec, Free. http://www.nero.com/eng/company/about-nero/nero-aac-codec.php Download (~2 MB), unzip & drop the .exe's into your eac3to directory. |
23rd November 2013, 14:53 | #12529 | Link | ||
Of course I have tried your recommendation before I posted my question here, and it sure DOES NOT WORK. Quote:
Cheers manolito |
23rd November 2013, 17:32 | #12530 | Link |
eac3to never support mp4 container like input.
Also .m4a (only aac audio in mp4 container) is not supported. .aac input (with ADTS headers for instance) is only supported with Nero 7 installed.
24th November 2013, 14:56 | #12532 | Link | |
Something like this certainly does work, with eac3to & nero encoder:
eac3to.exe INPUT OUTPUT OPTIONS DELAY eac3to.exe riot_INPUT.wav riot_OUTPUT.w.18-1350ms.speedup.m4a -quality=0.18 -speedup -1350ms Code:
eac3to.exe SN.ac3 sn+2300.m4a +2300ms -quality=0.18 Code:
eac3to.exe ie.wav ie-speedup+2100.m4a -speedup -quality=0.75 +2100ms Quote:
24th November 2013, 20:29 | #12533 | Link | |
Seems like you did not read my question... I asked if eac3to handles aac audio without Nero 7 installed, and tebasuna answered my question in a very clear way. So the eac3to feature list is a little bit misleading. Cheers manolito |
25th November 2013, 11:19 | #12534 | Link |
"Misleading", indeed. If it is written in such a general form like
(6) AAC audio Therefore I would recommend to include such unexpected prerequisites in the help text: Code:
(6) AAC audio (ADTS only, requires Nero 7) |
26th November 2013, 11:50 | #12535 | Link |
How to extract an E-AC3 core?
Hi!
How do I extract the core AC3 stream of a combined E-AC3/AC3-stream? My file looks exactly like a combined DTS-MA/DTS-core stream, but eac3to always want's to convert the file to AC3: Code:
C:\eac3to\eac3to.exe german.ac3 out.ac3 -core E-AC3, 7.1 channels, 1:44:16, 896kbps, 48kHz (core: AC3, 5.1 channels, 1:44:16, 512kbps, 48kHz) Extracting E-AC3 core... Decoding with libav/ffmpeg... Remapping channels... Encoding AC3 <640kbps> with libAften... Creating file "coreac3.ac3"... Clipping detected, a 2nd pass will be necessary. -------^C |
26th November 2013, 19:50 | #12537 | Link | |
I got it to work: You have to create an output.ec3, though the result is an AC3 actually. So you also have to rename your .ec3 to .ac3 afterwords. Hmm. This should be considered as a bug: I'm creating a real AC3, no E-AC3. Why should I name my output ec3? And, additionally, where's the doc to this secret .ec3-switch? I never read about an ec3 file before... For .dtsma -> .dts -core the engine works correctly. Perhaps I should've used full paths in my first post (no audio issue for me) Code:
D:\monster>C:\eac3to\eac3to.exe german.ec3 coreac3.ec3 -core E-AC3, 7.1 channels, 1:44:16, 896kbps, 48kHz (core: AC3, 5.1 channels, 1:44:16, 512kbps, 48kHz) Extracting E-AC3 core... Creating file "coreac3.ec3"... eac3to processing took 5 seconds. Done. D:\monster>C:\eac3to\eac3to.exe coreac3.ec3 AC3, 5.1 channels, 1:44:16, 512kbps, 48kHz |
26th November 2013, 20:42 | #12538 | Link |
I wouldn't call it a bug per se but more of an unintended consequence of the relationship between E-AC3 and AC3, the fact that eac3to can natively encode AC3 (which it tries to do by default), and that eac3to only recently added support for extracting the E-AC3 core (from Blu-ray tracks only).
You don't have to name it .ec3.. you could choose .eac3 because, again, with .ac3 eac3to will try to transcode it by default, regardless of the -core switch. DTS, however, cannot be encoded by eac3to without additional software, hence the reason the -core switch works as you want it to. Try the following and you'll see what I mean: Code:
eac3to file.dtshd core.dtshd -core |
27th November 2013, 16:31 | #12540 | Link |
True. Maybe when (or should I say 'if') eac3to starts using ffmpeg for processing/conversion will it be a good idea to switch to its command line arguments style of specifying formats (-acodec, -vcodec, -f, etc.).
eac3to |
