8th September 2011, 17:42 | #5341 | Link | |
You know what you're doing. |
8th September 2011, 17:45 | #5343 | Link |
So some kind of language learning mode in my definition subtitles (closed captions) are first for hearing impaired people, and sure audio and subtitles should be in sync and changeable on demand
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 8th September 2011 at 17:51. |
8th September 2011, 18:16 | #5344 | Link | |
4:2:0 hater
8th September 2011, 18:33 | #5345 | Link | |
8th September 2011, 18:36 | #5346 | Link |
nevcairiel,
Not sure if it's very interesting but I ran a few tests with the 42 mbit/s Birds clip on my system (5 runs per decoder). http://www.megaupload.com/?d=1D4BX1U9 All output set as YV12. LAV Video 0.35: Avg: 187,6698 fps ffdshow Video rev. 3972: Avg: 184,0087 fps CoreAVC 3.0: Cuda avg: 47,3796 fps LAV CUVID 0.12: Avg: 47,2249 fps CoreAVC 3.0: No acc. avg: 40,4673 fps CPU: Intel Core i7 980x @ 4015 MHz (6 threads, HT off) GPU: Nvidia 570 GTX
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
8th September 2011, 18:37 | #5347 | Link | |
http://files.1f0.de/lavf/LAVFilters-0.35-P010-mmx.zip It *should* use the MMX version on any Athlon that has SSE2, but does not have SSE4a. Apparently the ffmpeg developers came up with that scheme to detect if a Athlon has slow SSE2. Sadly there is no easy way for you or me to make sure its using the MMX version, but maybe you'll see a speed difference. I sadly do not have a whole attic full of hardware to test one.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 8th September 2011 at 18:45. |
8th September 2011, 19:15 | #5348 | Link |
nevcairiel
Hi. Can you investigate why this sample test.mkv cause periodic flickering with LAV Video 0.35 + Haali Video Renderer (03/03/2011) and problems with seeking (also with Haali Video Renderer). Also why LAV Video doesn't work with Overlay Mixer at all? |
8th September 2011, 19:22 | #5349 | Link |
Unfortunately, there are exceptions for which this will not work. In some movies ("Gran Torino" is an example) the "forced" subtitles (English subtitles for another language within a predominately English film) are a separate shorter subtitle track rather than just a forced flag within a full length SDH English track. So manual selection will always be needed.
8th September 2011, 20:20 | #5350 | Link | |
MPC-HC 2.1.7.2 |
8th September 2011, 20:59 | #5352 | Link | |
4:2:0 hater
stream = none; if (user_settings) { stream = findtrack(); // All logic goes here. Sky is the limit. } else if (forced_flags) { stream = findfirstforcedtrack(); } else if (default_flag) { stream = finddefaulttrack(); } return stream; |
8th September 2011, 21:09 | #5353 | Link |
I really havent used Haali much, but i guess what you're saying is that once you configure a language in haali, you will always get subs, no matter what (unless you use that advanced config with a "off" setting)? The only difference to LAV Splitter being the behaviour without configuration, i guess.
8th September 2011, 21:14 | #5354 | Link |
Nev, guys,
now that you are on the subtitles subject can someone help me with the following problem (general as I see it): Is there any way to have internal and external subtitles working together? By "working together" I mean that the "cycle" function (next/prev subtitle track) should be able to go through both internal (via the stream switching interface exposed by the splitter) and external subtitle files (via the stream switching interface exposed by subtitle renderer - either VobSub/FFDShow or MPC's internal one). Is there a way that the media player can distinguish between the different tracks (audio/video/subs) exposed by the splitter and somehow combine only the subtitles ones with the ones from the subs renderer? This is something that a lot of non English speaking people who use external subs in their language need when they try to learn the foreign language.
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
8th September 2011, 21:17 | #5355 | Link |
The external subtitles are not managed by the splitter, and the way external subs are managed is different in every player out there, so its really a player task, imho.
I know that someone wanted to try combining those two in the MPC-HC subtitle selector, because right now you have to switch in two different menus.. There is a kind-of standard how streams are grouped in IAMStreamSelect, so it should be possible to do it.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 8th September 2011 at 21:20. |
8th September 2011, 21:32 | #5356 | Link | |
4:2:0 hater
8th September 2011, 21:37 | #5357 | Link | |
But then, a default setting will never be perfect, its really a matter of choice. I can certainly configure it like that. When no languages are configured (and settings not touched in general), use forced/default, but nothing else. I would tie that to the audio settings, though, so when the user configures audio languages, but no subtitle languages, then at least it trys to select a forced track that matches the audio language - if one is present. If no match is found, fallback to the old logic and try any forced track, and then the default track. I really don't have much MKVs with subtitles. How is the default flag really used? Do people typically keep it on the one stream that mkvmerge put it on, just because? Or does it have a meaningful use?
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 8th September 2011 at 21:43. |
8th September 2011, 22:45 | #5358 | Link | |
I suspect that noone has tested this heuristic for the lowend/low-power AMD chips (Bobcat core, a.k.a. Ontario/Zacate/E-350/C-50 etc). Those cpus reportedly have support for SSE1-3,SSSE3 and SSE4a (and no 3dNow), According to some unofficial info, the SSE instructions get split into two microops just like how it was on A64. OTOH that doesn't necessarily mean it also has to have SSE2 slower than MMX like K8, though. |
8th September 2011, 23:31 | #5359 | Link | |
I do use forced now however as you set up the option and I think it would be valubale to at least respect it for cases like "english for non-english parts" sub tracks. I went thru and changed all the desired tracks to 'forced' in my muxes (thanks to whoever suggested using mkvmerge header editor for that) so that I could still get the same on/off sub behavior. Last edited by glorp; 8th September 2011 at 23:37. |
9th September 2011, 00:28 | #5360 | Link | |||
4:2:0 hater
- When you want subs in your MKV but disabled by default, like in all other containers without flags. To do this, you set all of them as no in mkvmerge. Since there are no flags, Haali doesn't display any subs as intended. - When you have several subs in your MKV, and you want to display a track by default that isn't the first one. Both cases assume Haali default behavior: no subs unless the flag is set. |
