18th October 2009, 23:33 | #9422 | Link |
That won't work. The usual extenion for subtitles is either .sup, .sup, .ass. Count try .dvb as eac3to allows you to extract unrecognized formats with an extension of the format name.. though in this case, eac3to does recognize it, so who knows.
19th October 2009, 12:31 | #9425 | Link |
hi
i'am a newbie so sorry, have been looking for days in the this thread for a way to make multi wav from 6 or 8 mono wav. (1 wav with 6 or 8 channel mono) can you do this or is it only from other multi audio format like AC3 DTS etc. and go from 23.976 and 25.000 fps audio to 24.000 (-slowdown, -speedup) hope you can help. thanks |
19th October 2009, 13:48 | #9426 | Link | ||
Use Sox, WaveWizard, AviSynth methods, ... Quote:
eac3to input.ac3 output.ac3 -23.976 -changeTo24.000 With: -speedup equivalent to: -23.976 -changeTo25.000 -slowdown equivalent to: -25.000 -changeTo23.976
19th October 2009, 16:05 | #9428 | Link |
Extracting from the root directory of Almost Famous R1 Blu-Ray. Weird EVO error even though it's a m2ts file
eac3to v3.17 command line: eac3to .\ 1) 2:\af.h264 3:\af.flac ------------------------------------------------------------------------------ M2TS, 1 video track, 2 audio tracks, 20 subtitle tracks, 2:41:30, 24p /1.001 1: Chapters, 16 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB (embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB) 4: AC3, Polish, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB 5: Subtitle (PGS), English 6: Subtitle (PGS), Polish 7: Subtitle (PGS), Portuguese 8: Subtitle (PGS), Spanish 9: Subtitle (PGS), Chinese 10: Subtitle (PGS), Korean 11: Subtitle (PGS), Thai 12: Subtitle (PGS), Arabic 13: Subtitle (PGS), Bulgarian 14: Subtitle (PGS), Croatian 15: Subtitle (PGS), Czech 16: Subtitle (PGS), English 17: Subtitle (PGS), Hebrew 18: Subtitle (PGS), Hindi 19: Subtitle (PGS), Hungarian 20: Subtitle (PGS), Icelandic 21: Subtitle (PGS), Romanian 22: Subtitle (PGS), Slovak 23: Subtitle (PGS), Slovenian 24: Subtitle (PGS), Turkish [v02] Extracting video track number 2... [a03] Extracting audio track number 3... [a03] Extracting TrueHD stream... [a03] Removing TrueHD dialog normalization... [a03] Decoding with libav/ffmpeg... [a03] Encoding FLAC with libFlac... [v02] Creating file "D:\af.h264"... [a03] Creating file "D:\af.flac"... [a03] The original audio track has a constant bit depth of 16 bits. [a03] Superfluous zero bytes detected, will be stripped in 2nd pass. This doesn't seem to be a valid EVO/VOB file ($0). <ERROR> [a03] Starting 2nd pass... [a03] Decoding FLAC... [a03] Reducing depth from 24 to 16 bits... [a03] Encoding FLAC with libFlac... [a03] Creating file "D:\af.flac"... [a03] The processed audio track has a constant bit depth of 16 bits. Video track 2 contains 232321 frames. eac3to processing took 52 minutes, 16 seconds. Done. |
20th October 2009, 17:11 | #9434 | Link |
on W7 x64 ? How did you install it ?
Ah, now it works. I use standard NEro7 installer now (only Showtime). The BluRAy/HDDVD plugin is properly registered Its a TrueHD+AC3 Track, now i get this : Extracting TrueHD stream... Decoding with DirectShow (Nero Audio Decoder 2)... The DirectShow audio decoder didn't accept the input stream. <ERROR> Aborted at file position 262144. <ERROR> Last edited by ACrowley; 20th October 2009 at 17:45. |
20th October 2009, 18:00 | #9436 | Link |
yes, it works...eac3to finds teh Nero7 Decoder.
Can you decode TrueHD with it ? The DirectShow audio decoder didn't accept the input stream. <ERROR> EDIT2: It works! i had to register the.ax manually Last edited by ACrowley; 20th October 2009 at 18:23. |
20th October 2009, 20:43 | #9438 | Link |
Hi...I just got started using eac3to (thanks for this great tool, madshi!) and I have a real noob question.
Is this the correct Nero Blu-ray plugin that I want to use: http://www.nero.com/enu/store-blu-ra...authoring.html If not, could some kind soul please direct me to where I can purchase the correct one? |
20th October 2009, 21:39 | #9439 | Link |
That's not it (and only for Nero 9 as well). It seems "BD/HD DVD Playback Plug-in" license is now only available in Asian-Pacific region and costs about $30 USD.
http://www.nero8.com/cht/store-blu-ray.html |
eac3to |
