Old 13th April 2012, 21:32   #81  |  Link
Paddy97
If the source is interlaced how do I add deinterlacing to the video encode?
Paddy97 is offline   Reply With Quote
Old 14th April 2012, 23:32   #82  |  Link
millercentral
I noticed that file paths are using forward-slashes ("/") instead of ("\"). While this works okay for local files, it fails for networking paths. Can you change it so directories are separated by backward-slashes ("\") instead of forward-slashes?
millercentral is offline   Reply With Quote
Old 15th April 2012, 10:08   #83  |  Link
oreons
MkvToMp4 author
Paddy97,
For converting interlace-progressive need to run encoding, repacking will not work.
millercentral,
Network paths are supported, see the picture.
oreons is offline   Reply With Quote
Old 15th April 2012, 12:41   #84  |  Link
Paddy97
Originally Posted by oreons View Post
Paddy97,
The source I was trying with is MPEG2 so it will be recoded. Use the standards, the output is still interlaced.
Old 15th April 2012, 15:09   #85  |  Link
oreons
MkvToMp4 author
Paddy97,
The output is interlace? Do you have a sample for testing?
Old 15th April 2012, 15:37   #86  |  Link
Paddy97
Paddy97,
Sure, here you have a clip.
http://www.mediafire.com/?598883j3rfbkc8c
Old 15th April 2012, 16:18   #87  |  Link
oreons
MkvToMp4 author
At the output progressive video.
Complete name                            : D:\Trollkarlens Hemligheter.s01e07 (03).m4v
Format                                   : MPEG-4
Codec ID                                 : M4V
File size                                : 131 MiB
Duration                                 : 6mn 23s
Overall bit rate mode                    : Variable
Overall bit rate                         : 2 866 Kbps
Encoded date                             : UTC 2012-04-14 15:07:41
Tagged date                              : UTC 2012-04-14 15:07:41
Writing application                      : MkvToMp4 [www.mkvtomp4.ru] version 0.219
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 6mn 23s
Bit rate                                 : 2 693 Kbps
Maximum bit rate                         : 7 616 Kbps
Width                                    : 720 pixels
Height                                   : 576 pixels
Display aspect ratio                     : 16:9
Original display aspect ratio            : 16:9
Frame rate mode                          : Constant
Frame rate                               : 25.000 fps
Standard                                 : PAL
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.260
Stream size                              : 123 MiB (94%)
Writing library                          : x264 core 116 r2057 0ba8a9c
Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x3 / me=dia / subme=1 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language                                 : English
Tagged date                              : UTC 2012-04-14 15:07:44
Old 15th April 2012, 16:36   #88  |  Link
Paddy97
Ok, I see that. But if you look at the output it still looks interlaced. How do I remove that effect from the output?
There where some intersting parts in this thread since the source id DVB-T
http://forum.doom9.org/showthread.php?t=164682
Old 15th April 2012, 18:05   #89  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
in command line you forgot --tff
Old 15th April 2012, 20:32   #90  |  Link
Paddy97
Thanks for the tip! Just tried that. With this source it did not do anything.
Old 16th April 2012, 16:07   #91  |  Link
Atak_Snajpera
did you removed --no-interlaced command first?
Old 16th April 2012, 16:29   #92  |  Link
Faleny
hello! I'm from Brazil, I can not speak English, so I'm using a translator, so please have patience with me
I loved this topic, and this program, but I'm having the following problem:
"FFmpeg terminated with error: 1"
if I put several files to be converted in a row, several of them give an error in converting the audio, leaving the final file without sound, but if I put one at a time, there occurs less frequently, in this case was vorbis, but I think also happened to acc,, will have to correct this error?
thank you for your attention
Faleny is offline   Reply With Quote
Old 16th April 2012, 18:54   #93  |  Link
Paddy97
Did that but on this source its of no effect.
If I select deinterlace in ripbot it works great btw and the size of the file is reduced in half due to the corrected picture.
Old 16th April 2012, 19:58   #94  |  Link
oreons
MkvToMp4 author
Faleny,
Do you have a sample file, which is encoded with an error?
Paddy97,
For high-quality deinterlacing should be used AviSynch filters, my program does not support it.
Old 28th April 2012, 10:51   #95  |  Link
oreons
MkvToMp4 author
Version 0.220 - http://www.mediafire.com/?kxfjeg3qeknqakn
New in version:
1. Searching tags on sites TheTvDB and TheMovieDB.
To use searching must be fill the correct fields in the proxy settings, if it is used.
2. Select searching language in the program settings.
3. Loading artworks when searching tags and choose to use them.
This creates a cache of downloaded artworks in a temporary directory and re-search, artwork will be loaded from the cache.
4. Ability to search tags for a few episodes of a TV series in a single operation.
It is necessary select all of the series and click search, then the information on the series will be written into each file.
5. Jump to the IMDb site to search for information.
6. Ability to shutdown Windows after the end of the encoding.
First you need to put a flag in the settings "Enable windows shutdown button"
After that when you start encoding "Shutdown" button will be displayed.
If you click it, then the computer will be turned off after the end of the process.
7. Moving for files from the window tag editing. When you move the current tags are saved and is moved to the next or previous file.
8. Identify and record a new tag HD 1080p
9. Setting up the possibility of enable tags, and the enable optimization when loading a file.
10. If you move the mouse over the tag, it displays its contents in a window.
11. Ability to make Paypal donations to the program development.
12. Using a newer version of FFMpeg and Mp4Box
Old 29th April 2012, 14:37   #96  |  Link
eckyecky
You need to change the command for setting the level. There shouldnt be a decimal point in it. Using "...:level=4.1:..." sets it to High@L0.4 use "...:level=41:..."
But otherwise cheers for an awesome program
eckyecky is offline   Reply With Quote
Old 1st May 2012, 16:27   #97  |  Link
oreons
MkvToMp4 author
This is equivalent, see the log:
1. Tools\x264\x264 --crf 20.000 --preset superfast --no-interlaced --profile high --level 4.1 -o "Temp\video.h264" "D:/Video/76889.mov"
ffms [info]: 480x360p 0:1 @ 24004/1001 fps (vfr)
resize [warning]: converting from yuvj420p to yuv420p
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.1 Cache64
x264 [info]: profile High, level 4.1
2. Tools\x264\x264 --crf 20.000 --preset superfast --no-interlaced --profile high --level 41 -o "Temp\video.h264" "D:/Video/76889.mov"
Old 1st May 2012, 20:16   #98  |  Link
Mr. Monte
Question....I see the default AAC encoder is now Quicktime (might have been in past..not sure). Some time back...peeps advised that the Nero AAC encoder did a better job. Is Nero still the preferred?...or has Apple gotten better?
Mr. Monte is offline   Reply With Quote
Old 2nd May 2012, 02:38   #99  |  Link
eckyecky
The command in question is to MP4Box when it muxes extracted videos without conversion. It keeps exporting Level 0.4 instead of Level 4.1
Tools\MP4Box\MP4Box.exe -new -delay 1=1 -add "Temp\video.264":fps=25.000:lang=eng:level=4.1:name="" -add "D:/mkvtomp4/MkvToMp4_0.220/Temp/test.AC3"#1:fps=25.000:lang=eng:name="" -add "D:/mkvtomp4/MkvToMp4_0.220/Temp/test_internal_sub_2_change.ttxt":lang=eng:name="" -itags tool="MkvToMp4 [www.mkvtomp4.ru] version 0.220" "D:/mkvtomp4\test.m4v"
Highlighted bit should be 41 not 4.1
Old 2nd May 2012, 09:51   #100  |  Link
oreons
MkvToMp4 author
eckyecky,
Thanks, I will correct in next version.
Mr. Monte,
QT more quality at the same bitrate.
http://forum.doom9.org/showthread.php?t=161957
mkv, mkvtomp4, mp4, repack, video
