Old 14th September 2017, 15:02   #1  |  Link
alitech
Frequent black screen, Nvidia vertical sync woes - Im going to kill myself, HELP
Guys
I am hoping you guys can help me with this problem I have. I have a 75inch Samsung TV. Its a newish model purchased in 2015. I have a Denon AVR 2300W and run everything through it. I also have a 1060 card on my HTPC and I am trying very hard not to throw out the Nvidia card that I just bought. It is a replacement for a 960 that I had.
I have issues where the TV goes blank for a few seconds (audio still playing) and then comes back on. This problem refuses to go away no matter how many combinations of settings I use in the Nvidia control panel. I even changed my card from a 960 to 1060 because I thought my GPU was faulty.
I have changed the HDMI cable twice too but I still get frequent black screens. They appear for a couple of seconds and then back to normal.
I have tried everything that I have read on numerous websites. The main purpose of my HTPC is to watch movies and the experience of watching movies with black screen every 3 minutes is frustrating. I have had to resort to using PLEX with Chromecast which I detest.
Has anyone had this issue? How did you resolve it? There are vertical sync settings which apparently are the culrpit.
alitech is offline   Reply With Quote
Old 14th September 2017, 17:34   #2  |  Link
pirlouy
_
Sorry, not enough information.
Does it appear after 1 minute or you have to wait a certain time ?
Have you tried without using your AVR ?
Your TV is 4k ? (I guess so, but no guess pls)
Old 14th September 2017, 19:13   #3  |  Link
and most important how long is the cable?
Old 14th September 2017, 23:34   #4  |  Link
alitech
Of course, here is more info
I had a 2 meter cable which is now changed to a 1 meter cable.
It is a 4k TV for sure. It supports 60hz and HDR HDMI 2.0a compatible.
I have not tried directly with the TV and I shall give that a go.
Ali
Old 16th September 2017, 03:18   #5  |  Link
Magik Mark
Same problem here. It has something to do with the latest madvr & lav filters. Try increasing GPU & CPU ques. Use asssubfilter instead
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR
Magik Mark is offline   Reply With Quote
Old 16th September 2017, 10:39   #6  |  Link
pirlouy
_
I seriously doubt it is the same problem but since alitech did not tell us when this behavior started, who knows.
Old 16th September 2017, 13:24   #7  |  Link
alitech
Yes, its not the same problem. My problem started a couple of years ago. The screen blacks out even in general PC use, no MADvr or LAV. Just using the PC for browsing or word processing.
Old 23rd September 2017, 00:29   #8  |  Link
AngelGraves13
I had an issue with my monitor randomly going black while the power was still on. Changed the power cable and the issue went away.
AngelGraves13 is offline   Reply With Quote
blank screen, nvidia, vsync
