Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 11th October 2019, 11:29   #161  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffhevc 3.8.5 and ffx264 3.8.4
* Support hardcoding external or embedded subtitles. Requires libass support in FFmpeg
* Fixed a typo in the subtitles code
Old 13th October 2019, 06:40   #162  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.8.6
* Fixed a typo in the keyframe code
* Use readlink -e and realpath -e where needed
* Updated default encoding options and CRF value
* Updated the preset.txt example file
ChangeLog for ffx264 3.8.5
Old 14th October 2019, 15:36   #163  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.8.7 and ffx264 3.8.6
* Support scanning for multiple video tracks in the input file
Old 15th October 2019, 05:01   #164  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.8.8
* Bugfix: use correct video mapping for crop detection
* Cosmetics
ChangeLog for ffx264 3.8.7
Old 16th October 2019, 06:25   #165  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.8.9 and ffx264 3.8.8
* Support the fftdnoiz denoise filter
Old 17th October 2019, 06:43   #166  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffx264 3.8.9
* Support the WMV container format
Old 18th October 2019, 06:04   #167  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.9.0
* Bugfix: use correct video track for crop preview with MPlayer
* Renamed variable SCAN_MULTIPLE_VID_TRACKS to SCAN_MULTI_VID_TRACKS
* Some reordering in the config file
* Add option hrd and vui-hrd-info when encoding HDR video
* Add LPCM detection for audio copy
* Add support for cover art for the mp4 and mov containers. Requires MP4Box from GPAC
* Set Catmull-Rom as default Bicubic/Spline tuning
* Some code optimization
ChangeLog for ffx264 3.9.0
* Bugfix: in the video_field_parity_func() function. $vidtrack was missing for ffprobe
* Bugfix: missing ;; in the additional container formats code
* Add support for cover art for the mp4, m4v and mov containers. Requires MP4Box from GPAC
Old 19th October 2019, 08:21   #168  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.9.1 and ffx264 3.9.1
* Use atomicparsley to add cover art for the mp4/m4v containers. This removes dependence on MP4Box and makes it possible to copy over metadata info in an easy way
* Add +frag_keyframe to the -movflags option when output is mp4
* Renamed variable METACOVER to MKVCOVER
* Updated the man page
Old 20th October 2019, 05:45   #169  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.9.2
* Added support for embedding of SRT/SSA/ASS subtitles in the MP4 container
* Moved back to MP4Box for adding cover art to MP4/MOV. Apparently, after lots of testing, atomicparsley creates files that hang during playback
* Cosmetics
ChangeLog for ffx264 3.9.2
* Added support for embedding of SRT/SSA/ASS subtitles in the MP4/M4V containers
* Moved back to MP4Box for adding cover art to MP4/M4V/MOV. Apparently, after lots of testing, atomicparsley creates files that hang during playback
* Cosmetics
Old 21st October 2019, 04:43   #170  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.9.3 and ffx264 3.9.3
* Add support for verbose logging to a log file
* Bugfix: -map_metadata and -map_chapters where not set to 0 when the respective options in the config file were set to "y"
Old 21st October 2019, 09:49   #171  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.9.4 and ffx264 3.9.4
* Renamed variables $MDATA and $CHPS to $METADATA and $CHAPS
* Add $METADATA and $CHAPS to the remuxing code
Old 22nd October 2019, 05:26   #172  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.9.5 and ffx264 3.9.5
* Add support for SRT/SSA/AAS subtitles for the MOV container
* Add color characteristics to MP4Box if output is MOV
* Use smpte170m for option 0 in the color primaries code
* Update colormatrix in the video_colorspace_func() function to smpte170m for NTSC
* Some code optimizations
Old 23rd October 2019, 04:23   #173  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.9.6 and ffx264 3.9.6
* Added support for setting the VBV maxrate and buffer size
* Set default audio codec based on output container format
* Add colr option for MP4Box to the video_colorspace_func() function and the color primaries code. Only used for MOV
* Add -color_primaries, -color_trc and -colorspace to the FFmpeg command line options
Old 25th October 2019, 06:37   #174  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.9.8
* Removed M4V from the case statements for cover art. I confused it with ffx264 which supports M4V while ffhevc does not.
* Detect audio bit depth and add it to the audio metadata
* Added detection for DTS Express and DTS-HD HR for audio copy
* Use -show_entries instead of -show_streams for detecting audio properties with ffprobe. Removes piping to grep and awk
* Support setting the FLAC bit depth for encoding
* Minor restructuring and variables renaming in the audio code
ChangeLog for ffx264 3.9.7
Old 26th October 2019, 08:10   #175  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.9.9 and ffx264 3.9.8
* Renamed audio variable aid[i] to aidx[i] and moved it outside of the if conditional that decides the audio codec. This removes the same code in three places and now uses the global aidx[i] variable
* HE-AACv2 only supports 2 channels. Update the audio code to reflect that
* When running in batch mode, add a warning about automatic audio metadata and offer an option to enable/disable it
* Added -tmp option to MP4Box to store temp files in the output directory
* Some minor improvements to the audio options
Old 27th October 2019, 09:33   #176  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.0.0 and ffx264 3.9.9
* Use 16 bits as bit depth metadata when encoding to TrueHD audio
* Removed an unneeded if conditional in the audio bit depth code
* Add director and cast metadata for the MKV container
* Reorder some code for the output shell file
* Cosmetics
Old 28th October 2019, 06:35   #177  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.0.1 and ffx264 4.0.0
* Added support for director/cast metadata for MP4/MOV/(M4V)
* Added +use_metadata_tags to the $movflags variable for MP4/MOV/(M4V)
* Support ADPCM encoding for DTS audio
* Fixed an issue where asking for director/cast occured multiple times if remuxing to other containers was enabled
Old 29th October 2019, 07:19   #178  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.0.2
* Removed an unneeded check for audio codec in the conerror_func() function
* Removed a stale "" in the case statement that checks the channels for AC3
* Support setting the matrixed stereo type when resampling stereo input
* Support setting the filter type of the audio resample filter
* Add the bsf bitstream filter to convert from length prefix to start code prefix when remuxing to m2ts/mts/ts
* Cosmetics
ChangeLog for ffx264 4.0.1
* Cosmetics
Old 2nd November 2019, 14:55   #179  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.0.3
* Merged two case statements in the metadata code for mkv/mp4/mov
* Support dithering when downscaling to 8-bit pixels
Old 4th November 2019, 17:33   #180  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.0.4
* Bugfix: Using ADPCM encoding for DTS audio wasn't possible due to wrong variable used in the if conditional
ChangeLog for ffx264 4.0.2
