Old 24th October 2016, 11:53   #39821  |  Link
ryrynz
ryrynz's Avatar
Originally Posted by ashlar42 View Post
What's AR?
Anti-ringing.
Old 24th October 2016, 13:48   #39822  |  Link
adhara
Originally Posted by adhara View Post
Hi all,
This is about RGB output levels with a 10 bits display (so dithering 10bits and more activated in MadVr).
I know this is not a new question but I would like a clear explanation as we can read everything and its opposite arround this subject.
Basically there are 3 options:
Setup 1 :
GPU outputs 0-255
MadVr outputs 0-255
Display expects 0-255
Setup 2:
GPU outputs 16-235
MadVr outputs 16-235
Display expects 16-235
Setup 3:
GPU outputs 0-255
Problems:
-There is no way on my UHD (10 bits) TV to select limited or full range.
- Graphic Card GTX 1070: When output is set to 2160p(4k) - RGB Full range, bitdepth is limited to 8 bits / To have 10/12 bits outptut on the GPU, I have to lower outptu level to limited range (16-235).
So what is the best setting for my own use (4k) ?
Madvr (0-255 / 10 bits) --> GPU (0-255 / 8 bits) --> Display
OR
Madvr (16-235 / 10 bits) --> GPU (16-235 / 10 bits) --> Display
OR
Madvr (0-255 / 10 bits) --> GPU (16-235 / 10 bits) --> Display
OR (other ?)
Thanks
madshi, warner306, ... others that know the answer, any idea ? thanks
adhara is offline   Reply With Quote
Old 24th October 2016, 13:58   #39823  |  Link
Sunset1982
Hi all,
Setup 1 :
GPU outputs 0-255
MadVr outputs 0-255
Setup 2:
GPU outputs 16-235
Setup 3:
GPU outputs 0-255
Problems:
OR
OR
OR (other ?)
Thanks
I think 2106p60, 10 bit, RGB444 is not possible with current HDMI 2.0 a/b connection because of bandwidth limitations.
So you have to decide to go 2160p, RGB 444, 8 Bit or 2160p, 422, 10 bit.
I use 2160p, RGB 444, 8 Bit with my RX480 on my 4K TV with Setup Nr 1 (all 0-255)
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 24th October 2016, 14:02   #39824  |  Link
CarlosCaco
Man the second settings are wrong
If tv is expecting limites the right is
Madvr 16-235 gpu 0-255 tv 16-235
Also you can try
Madvr 0-255 gpu 16-235 TV 16-235 this can be a good choice for 10 bit on your system
Desktop, i5 2500, 8GB, N570 GTX TF III PE/OC
Asus X555LF, i7-5500U, 6GB Ram, Nvidia 930m/HD 5500
Windows 8.1 Pro x64
CarlosCaco is offline   Reply With Quote
Old 24th October 2016, 19:25   #39825  |  Link
Asmodian
I would say there is no point to sending 10-bit out of madVR if you then have the GPU compress 0-255 to 16-235.
Personally 10-bit or 422 subsampling is an easy choice for me. 8-bit 444 is always preferred. 10-bit is for that little extra improvement after everything else is perfect. Using the GPU to halve the color resolution and letting the TV up sample and do another color conversion is not perfect. Untouched properly dithered 8-bit RGB directly out of madVR is much better.
madVR options explained
Old 24th October 2016, 20:10   #39826  |  Link
pirlouy
_
Originally Posted by foozoor View Post
Did you look at this archive?
There is everything, even the deringing algo!
Wow. Indeed, I didn't read it carefully. With this tool, it looks like you can't protect your shaders. Don't know if it's a flaw.
Old 24th October 2016, 20:25   #39827  |  Link
Warner306
These are your options:
HDMI 2.0a/b (maximum output - 3840 x 2160):
- 10-bit RGB/Y'CbCr 4:4:4 at 30 Hz
- 10-bit Y'CbCr 4:2:2 at 60 Hz
- 8-bit RGB/Y'CbCr 4:4:4 at 60 Hz
Old 24th October 2016, 20:30   #39828  |  Link
i'm not going into the details but there are a lot of wrong numbers in there.
Old 24th October 2016, 20:37   #39829  |  Link
Warner306
madVR 16-335 -> GPU 0-255 -> TV 16-235
Messes up the desktop but the signal is untouched from madVR.
madVR 0-255 -> GPU 16-235 -> TV 16-235
Desktop remains accurate but GPU must do a color conversion. This is the simplest solution.
Old 24th October 2016, 20:38   #39830  |  Link
Warner306
This is from the official HDMI spec page:
HDMI 2.0a/b UHD Support:
Black fonts indicate formats supported by HDMI 1.4.
HDMI 2.0 supports 4:2:0 at 4K60.
*Cable lengths of 15' or greater require the use of an active HDMI cable to support 18.0 Gbits/s signals.
Old 24th October 2016, 20:46   #39831  |  Link
70MM
X Cinema Projectionist NZ
I currently use the JVC X9000 with the Lumagen Pro and MadVR.
I have never tried to use any 4K upscaling on my setup but would like to try...
Currently I use image doubling on everything set to always. Using the 1080 video card.
To try this out, do I set both the PC and Lumagen Pro to 4K, or just the Lumagen to upscale 1080p from the PC?
What is the resolution I should use 2160 x ???
I take it I turn off Image Doubling in MadVR with a 4K setup, is that correct?
70MM is offline   Reply With Quote
Old 24th October 2016, 21:32   #39832  |  Link
Warner306
1080p -> 2160p is 2x, so you want image doubling.
Set the PC desktop resolution to 3840 x 2160.
You don't use display mode switching, so nothing needs to be changed in madVR.
I'd experiment with NNEDI3 luma doubling. This should do a better job than the Lumagen.
Old 24th October 2016, 22:18   #39833  |  Link
kuchikirukia
Looks like they don't even know what they're talking about IMO. Waste of time.
This. They don't even know what the word "derivative" means.
kuchikirukia is offline   Reply With Quote
Old 24th October 2016, 22:33   #39834  |  Link
70MM
But do I set the Lumagen to 3840 x 2160 also?
Old 24th October 2016, 22:48   #39835  |  Link
sauma144
The most valuable post is from madshi, the original madshi not the clones.
Now the leak or dump seems to be legit and they already ported the enhance detail sharpener.
I hope this will not delay the release of the new version.
sauma144 is offline   Reply With Quote
Old 25th October 2016, 11:23   #39836  |  Link
ashlar42
Originally Posted by AngelGraves13 View Post
Change from Optimal to Adaptive for Power Management.
Where?
Old 25th October 2016, 11:34   #39837  |  Link
ashlar42
Anti-ringing.
As a SuperRes refinement, you mean? on 0.90.24 I have only super-xbr with or without anti-bloating under Image Doubling. Anti ringing is found in the regular Image Upscaling section. So, are you referring to SuperRes or, maybe, to AdaptiveSharpen/LumaSharpen with anti-ringing?
Old 25th October 2016, 11:56   #39838  |  Link
Ver Greeneyes
Where?
In the "Manage 3D settings" tab of the NVIDIA Control Panel. You can even make it a per-program setting by adding your media player of choice in the Program Settings tab.
Old 25th October 2016, 12:13   #39839  |  Link
ryrynz
ryrynz's Avatar
No, just super-xbr AR for chroma. Bang for buck it can't be beat. Bicubic, Jinc and NNEDI3 are good alternatives though depending on your preferences.
Old 25th October 2016, 17:49   #39840  |  Link
AngelGraves13
Where?
AngelGraves13 is offline   Reply With Quote
